Dashticz - Bug report
- EdwinK
- Domoticz version: BETA
Re: Dashticz - Bug report
Thanks. This fixed it.
Btw. I don't have js/main.custom so I guess it isn't needed to change there.
Now that I think about it I think those are my backup files when I made some changes to a couple of switches and removed the .0 from my thermostatEdwinK wrote:Thanks. This fixed it.
Sent from my SM-G935F using Tapatalk
- EdwinK
No clue.
- gielie
- Domoticz version: latest β
This doesn't work for me, none of my selector switches are showing correctly, they are just empty block with just a title. Someone has a clue how to solve this?Wob76 wrote: Friday 25 May 2018 1:15 A fix for the above, The Levelnames are now being base64 encoded.
I modified js/main.js and js/main.custom (I'm not sure if both are needed), I also noticed the same files under vendor/js/ can anyone comment on if these are used or not?
Change
var names = device['LevelNames'].split('|');
To
var names = atob(device['LevelNames']).split('|');
Wob
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
yfands
- Domoticz version: latest B
The 'build in' config editor errors at least two accounts after saving..
first:
It defaults to config['edit_mode'] = '0' wich wont work, the pages would not be refreshed anymore, changing it manualy into config['edit_mode'] = 0 works.
second:
Also any streetname (config['garbage_street'] = 1blablabla;) starting with a 1 like mine is treated as a number and the loading of the config will fail.
Maybe a general solution, treat numbers as numbers without the ' ' and strings as strings with the ' '
I downloaded beta version 2.3.5 comming from version 2 november 2017, Took me 3 days to look for a solution why the pages would not refresh
eventualy user Lokonli pointed me in the right direction of the edit_mode being wrong.
first:
second:
yfands
dashticz beta 2.3.5
Starting for the first time sliders at 100% will display 65535% after moving the slider it will display the rigth value.
regards
Frank
regards
Frank
yfands
Dashtitcz beta 2.3.5
Selection switch display fault.
should be..
regards
Frank
should be..
regards
Frank
- domoticz_Keuzeschakelaar.jpg (29.92 KiB) Viewed 8285 times
Lokonli
A PR for the first issue has been created already. Probably will be merged with the new beta soon. I'll try to find a clean solution for the second issue as well. (without you having to relocateyfands wrote: Thursday 07 June 2018 11:27 Hello,
first:
second:
- EdwinK
To fix this (until a new release) is to edit main.jsyfands wrote: Thursday 07 June 2018 11:45 Dashtitcz beta 2.3.5
regards
Frank
Change
To
- DewGew
- Domoticz version: V4.10618
In main.js I changedLokonli wrote: Thursday 07 June 2018 12:56
A PR for the first issue has been created already. Probably will be merged with the new beta soon. I'll try to find a clean solution for the second issue as well. (without you having to relocate)
tovar names = device['LevelNames'].split('|');
then it worked. I have latest beta of domoticz I dont know if it work with erlier verisons of domoticz.var names = atob(device['LevelNames']).split('|');
yfands
Thanks guys, fully up to date with the new (beta) versions now...
Frank
Frank
- DewGew
This is fixed in the latest beta.EdwinK wrote: Thursday 07 June 2018 13:19To fix this (until a new release) is to edit main.jsyfands wrote: Thursday 07 June 2018 11:45 Dashtitcz beta 2.3.5
regards
Frank
Change
To
yfands
Hai
Dashticz version Beta 2.3.5
raspberry pi 3
Playing with the speak option
In the config.js
config['speak_lang'] = 'nl-NL';
and in a block definition the following dutch sentence (translated: The temperature has changed)
blocks['636_1']['speak'] = 'Temperatuur is gewijzigd';
The lady tries her best but can't pronounce the dutch sentence it is still english based.
So, what must I do for her to understand the sentence is dutch?
Isn't config['speak_lang'] = 'nl-NL'; in the config file enough ?
regards
Frank
raspberry pi 3
In the config.js
regards
Frank
- DewGew
What browser are you using? In edge speaks use windows standard. I suggest you try to setyfands wrote: Wednesday 13 June 2018 11:52 Hai
raspberry pi 3
In the config.js
regards
Frank
In chrome sometimes first speak after refresh browser it speaks english but after that it works. at least on my setup. The language is still little buggy.config['speak_lang'] = '';
poudenes
- Domoticz version: 3.8993
Hi All,
i have a problem with a switch selector and Dasthicz.
have those lines in my switch selector:
In Dashticz i see this:
and not the list in first image.
Does someone know what this can be?
yfands
Hai Poudenes
I think we are missing an image..
but regarding the switch selector there is a fix, I modified js/main.js and js/main.custom (I'm not sure if both are needed)?
Change
To
regards
Frank
Change
To
regards
Frank
yfands
I use firefox, but refuses to talk dutch, on the other hand Chrome speaks dutch out of the box, on windows at least 7 and on android.DewGew wrote: Wednesday 13 June 2018 13:32What browser are you using? In edge speaks use windows standard. I suggest you try to setyfands wrote: Wednesday 13 June 2018 11:52 Hai
raspberry pi 3
In the config.js
regards
FrankIn chrome sometimes first speak after refresh browser it speaks english but after that it works. at least on my setup. The language is still little buggy.config['speak_lang'] = '';
- DewGew
This is fixed in the latest betayfands wrote: Thursday 14 June 2018 8:56 Hai Poudenes
Change
To
regards
Frank
poudenes
Thanks. I will test this or update to latest with git pullDewGew wrote:This is fixed in the latest betayfands wrote: Thursday 14 June 2018 8:56 Hai Poudenes
Change
To
regards
Frank
Verzonden vanaf mijn iPhone met Tapatalk Pro
dorenberg
- Domoticz version: 4.10982
Hi Guys, I am new to dashticz and my dashboard is growing well. However I have a small issue with the forecast.io pane. The font is white, but when there is a refresh of the frame the font goes dark grey. Is this normal? What can I do to remediate this?
