Dashticz - Bug report
Locked
EdwinK
Re: Dashticz - Bug report
Post by EdwinK »
Thanks. This fixed it.
Btw. I don't have js/main.custom so I guess it isn't needed to change there.
Wob76
Post by Wob76 »
EdwinK wrote:Thanks. This fixed it.
Now that I think about it I think those are my backup files when I made some changes to a couple of switches and removed the .0 from my thermostat :) what about the vendor folder, any idea on what that's for?
Sent from my SM-G935F using Tapatalk
EdwinK
Post by EdwinK »
No clue. :)
gielie
Domoticz version: latest β
Post by gielie »
Wob76 wrote: Friday 25 May 2018 1:15 A fix for the above, The Levelnames are now being base64 encoded.
I modified js/main.js and js/main.custom (I'm not sure if both are needed), I also noticed the same files under vendor/js/ can anyone comment on if these are used or not?
Change
var names = device['LevelNames'].split('|');
To
var names = atob(device['LevelNames']).split('|');
Wob
This doesn't work for me, none of my selector switches are showing correctly, they are just empty block with just a title. Someone has a clue how to solve this?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
yfands
Domoticz version: latest B
Post by yfands »
The 'build in' config editor errors at least two accounts after saving..
first:
It defaults to config['edit_mode'] = '0' wich wont work, the pages would not be refreshed anymore, changing it manualy into config['edit_mode'] = 0 works.
second:
Also any streetname (config['garbage_street'] = 1blablabla;) starting with a 1 like mine is treated as a number and the loading of the config will fail.
Maybe a general solution, treat numbers as numbers without the ' ' and strings as strings with the ' '
I downloaded beta version 2.3.5 comming from version 2 november 2017, Took me 3 days to look for a solution why the pages would not refresh
eventualy user Lokonli pointed me in the right direction of the edit_mode being wrong.
yfands
Post by yfands »
dashticz beta 2.3.5
Starting for the first time sliders at 100% will display 65535% after moving the slider it will display the rigth value.
regards
Frank
yfands
Post by yfands »
Dashtitcz beta 2.3.5
Selection switch display fault.
should be..
regards
Frank
Lokonli
Post by Lokonli »
yfands wrote: Thursday 07 June 2018 11:27 Hello,
first:
second:
A PR for the first issue has been created already. Probably will be merged with the new beta soon. I'll try to find a clean solution for the second issue as well. (without you having to relocate :) )
EdwinK
Post by EdwinK »
yfands wrote: Thursday 07 June 2018 11:45 Dashtitcz beta 2.3.5
regards
Frank
To fix this (until a new release) is to edit main.js
Change
To
DewGew
Domoticz version: V4.10618
Post by DewGew »
Lokonli wrote: Thursday 07 June 2018 12:56
In main.js I changed
to
then it worked. I have latest beta of domoticz I dont know if it work with erlier verisons of domoticz.
yfands
Post by yfands »
Thanks guys, fully up to date with the new (beta) versions now... ;-)
Frank
DewGew
Post by DewGew »
EdwinK wrote: Thursday 07 June 2018 13:19
regards
Frank
Change
To
This is fixed in the latest beta.
yfands
Post by yfands »
Hai
Dashticz version Beta 2.3.5
raspberry pi 3
Playing with the speak option
In the config.js
config['speak_lang'] = 'nl-NL';
and in a block definition the following dutch sentence (translated: The temperature has changed)
blocks['636_1']['speak'] = 'Temperatuur is gewijzigd';
The lady tries her best but can't pronounce the dutch sentence it is still english based.
So, what must I do for her to understand the sentence is dutch?
Isn't config['speak_lang'] = 'nl-NL'; in the config file enough ?
regards
Frank
DewGew
Post by DewGew »
yfands wrote: Wednesday 13 June 2018 11:52 Hai
raspberry pi 3
In the config.js
regards
Frank
What browser are you using? In edge speaks use windows standard. I suggest you try to set
config['speak_lang'] = '';
In chrome sometimes first speak after refresh browser it speaks english but after that it works. at least on my setup. The language is still little buggy.
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
i have a problem with a switch selector and Dasthicz.
have those lines in my switch selector:
In Dashticz i see this:
and not the list in first image.
Does someone know what this can be?
yfands
Post by yfands »
Hai Poudenes
I think we are missing an image..
but regarding the switch selector there is a fix, I modified js/main.js and js/main.custom (I'm not sure if both are needed)?
Change
To
regards
Frank
yfands
Post by yfands »
DewGew wrote: Wednesday 13 June 2018 13:32
raspberry pi 3
In the config.js
regards
Frank
I use firefox, but refuses to talk dutch, on the other hand Chrome speaks dutch out of the box, on windows at least 7 and on android.
DewGew
Post by DewGew »
yfands wrote: Thursday 14 June 2018 8:56 Hai Poudenes
Change
To
regards
Frank
poudenes
Post by poudenes »
Change
To
regards
Frank
Thanks. I will test this or update to latest with git pull
Verzonden vanaf mijn iPhone met Tapatalk Pro
dorenberg
Domoticz version: 4.10982
Post by dorenberg »
Hi Guys, I am new to dashticz and my dashboard is growing well. However I have a small issue with the forecast.io pane. The font is white, but when there is a refresh of the frame the font goes dark grey. Is this normal? What can I do to remediate this?
Locked
