Hold on, will try to fix it!
Dashticz - Function - RGB-support
robgeerts
- Domoticz version: 3.7067
Re: Dashticz - [BETA]Function - RGB-support
Ok, didnt test with multiple lights (bought one for testing purposes, not 2
- EdwinK
- Domoticz version: BETA
I only have two because of Eneco's offer last year.
ztorm
- Domoticz version: 3.8153
Re: Dashticz - Function - RGB-support
Is is possible to remove the color selector? I have white HUE lamps so I don't need the selector.
robgeerts
The color selector should only appear if you configurated it as a RGBW-bulb in Domoticz?
ztorm
The problem is, I have two Hue lamps (white) above my kitchen table that I want to control (dim, on/off) together with one dimmer switch. I made a group of the two lamps in a Hue-app and apparently Domoticz imports the group as a RGBW-type. I'm tying to figure out if it's possible to change that or to make a dimmer switch in Domoticz which controls both lamps.
freakshock
I noticed RGB support only seems to work for Milight bulbs with type RGBW in Domoticz.
Type RGBWW (v6 of the protocol) does not give me a color selector switch in Dashticz.
'Hal licht' is the only RGBW bulb I have, the others are a RGBWW (v6) type.
EDIT: Fixed by Rob now!
- milightdashticz.jpg (32.4 KiB) Viewed 4367 times
robgeerts
Could you send me the json-output of domoticz?
freakshock
Sent via PM!
perkonix
I also experience the issue of having a RGB selector for a Hue group containing only ambiance (RGBWW) lights. I guess there is an issue with Domoticz not choosing the correct type as domoticz says the group is RGBW instead of RGBWW. A single light from the group doesn't get the RGB selector.
The slider is functional in dashticz. But the color selector is not useful and I'd like to get rid of it.
I also added commented on this issue here: https://github.com/domoticz/domoticz/issues/1202 I hope it can be in Domoticz itself. But for now, is there a workaround to hide it from dashticz?
freakshock
Rob temporarily removed the RGB colorpicker in the latest beta, so that's a solution until a better solution is found!perkonix wrote: Saturday 12 August 2017 14:19 But for now, is there a workaround to hide it from dashticz?
dutchdevil83
- Domoticz version: latest
mmm that`s why my color selector isn`t showingfreakshock wrote: Monday 14 August 2017 20:11Rob temporarily removed the RGB colorpicker in the latest beta, so that's a solution until a better solution is found!perkonix wrote: Saturday 12 August 2017 14:19 But for now, is there a workaround to hide it from dashticz?
hope this function is back soon...
maybe idea to make a changelog when putting beta`s online?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Frankieg60
Any news of the color selector? i would love to use it.
Swifty
Is the RGB selector still absent in Dashticz? - I've had a look through the github commits and can't see anything relevant, but wanted to check..
I will be rebuilding my dashboard later, so interested to know if this is working yet!
robgeerts
I disabled it because there were some complaints, but you can test it when opening main.js en search for (twice):
removeRGBW
AND
removeRGBWW
You have to remove 'remove'
removeRGBW
AND
removeRGBWW
Swifty
Thanks Rob, I will manually enable it for now and see how it performs
Are there any plans to re-add a new version at any point?
- htilburgs
I've tested this option also in combination with Yeelight RGB LED (Wifi).
Works fabulous!!
Works fabulous!!
Hardware:
robgeerts
Well, I'm not sure what the real complaints were..
If some people could test this too and share their results, please!
- gijsje
- Domoticz version: Stable
Works good for me with mylight
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
robgeerts
Ok, please wait a day too see if it causes any loading problems (slowing things down)
I'll turn it on tomorrow of it seems ok
- htilburgs
Until now no loading / slowing things down issues. Still working ok.
Maybe you can use a parameter, like config['use_rgb']=0 / 1 for showing or not??
Hardware:
