Dashticz - Function - RGB-support
robgeerts
Domoticz version: 3.7067
Re: Dashticz - [BETA]Function - RGB-support
Post by robgeerts »
Ok, didnt test with multiple lights (bought one for testing purposes, not 2 :P)
Hold on, will try to fix it!
EdwinK
Post by EdwinK »
I only have two because of Eneco's offer last year.
ztorm
Domoticz version: 3.8153
Re: Dashticz - Function - RGB-support
Post by ztorm »
Is is possible to remove the color selector? I have white HUE lamps so I don't need the selector.
robgeerts
Post by robgeerts »
The color selector should only appear if you configurated it as a RGBW-bulb in Domoticz?
ztorm
Post by ztorm »
The problem is, I have two Hue lamps (white) above my kitchen table that I want to control (dim, on/off) together with one dimmer switch. I made a group of the two lamps in a Hue-app and apparently Domoticz imports the group as a RGBW-type. I'm tying to figure out if it's possible to change that or to make a dimmer switch in Domoticz which controls both lamps.
freakshock
Post by freakshock »
I noticed RGB support only seems to work for Milight bulbs with type RGBW in Domoticz.
Type RGBWW (v6 of the protocol) does not give me a color selector switch in Dashticz.
'Hal licht' is the only RGBW bulb I have, the others are a RGBWW (v6) type.
EDIT: Fixed by Rob now! :)
robgeerts
Post by robgeerts »
Could you send me the json-output of domoticz?
freakshock
Sent via PM!
perkonix
Post by perkonix »
I also experience the issue of having a RGB selector for a Hue group containing only ambiance (RGBWW) lights. I guess there is an issue with Domoticz not choosing the correct type as domoticz says the group is RGBW instead of RGBWW. A single light from the group doesn't get the RGB selector.
The slider is functional in dashticz. But the color selector is not useful and I'd like to get rid of it.
I also added commented on this issue here: https://github.com/domoticz/domoticz/issues/1202 I hope it can be in Domoticz itself. But for now, is there a workaround to hide it from dashticz?
Screen Shot 2017-08-12 at 13.58.27.png (98.19 KiB) Viewed 4300 times
Screen Shot 2017-08-12 at 14.15.23.png (49.45 KiB) Viewed 4300 times
freakshock
perkonix wrote: Saturday 12 August 2017 14:19 But for now, is there a workaround to hide it from dashticz?
Rob temporarily removed the RGB colorpicker in the latest beta, so that's a solution until a better solution is found!
dutchdevil83
Domoticz version: latest
Post by dutchdevil83 »
freakshock wrote: Monday 14 August 2017 20:11
mmm that`s why my color selector isn`t showing :lol:
hope this function is back soon...
maybe idea to make a changelog when putting beta`s online?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
Frankieg60
Post by Frankieg60 »
Any news of the color selector? i would love to use it.
Swifty
Post by Swifty »
Is the RGB selector still absent in Dashticz? - I've had a look through the github commits and can't see anything relevant, but wanted to check..
I will be rebuilding my dashboard later, so interested to know if this is working yet! :)
robgeerts
Post by robgeerts »
I disabled it because there were some complaints, but you can test it when opening main.js en search for (twice):
removeRGBW
AND
removeRGBWW
You have to remove 'remove' ;)
Swifty
Post by Swifty »
Thanks Rob, I will manually enable it for now and see how it performs :)
Are there any plans to re-add a new version at any point?
htilburgs
Post by htilburgs »
I've tested this option also in combination with Yeelight RGB LED (Wifi).
Works fabulous!!
Hardware:
robgeerts
Post by robgeerts »
Well, I'm not sure what the real complaints were..
If some people could test this too and share their results, please!
gijsje
Domoticz version: Stable
Post by gijsje »
Works good for me with mylight
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
robgeerts
Post by robgeerts »
Ok, please wait a day too see if it causes any loading problems (slowing things down)
I'll turn it on tomorrow of it seems ok :)
htilburgs
Post by htilburgs »
Until now no loading / slowing things down issues. Still working ok.
Maybe you can use a parameter, like config['use_rgb']=0 / 1 for showing or not??
Hardware:
