FlatZ Frontpage
- mvveelen
Re: FlatZ Frontpage
You have to change the URL's it in the settings.js in the subfolder js
bickel
Re: FlatZ Frontpage
Tnx for the menu options and the webcamsupport!
- jec_44
Re: FlatZ Frontpage
Hi guys,
Wonderfull ! i have a suggestion, could you add a traffic page based on google map ?
I added a new traffic.html page with
Most difficult is to add correct javascript. It can be useful !
Thk
<script>
if ($.Traffic)
{document.write('<li class="active" ><a class="stay" href="traffic.html"><i class="icon-th icon-white"></i> Traffic</a></li>');}
</script>Thk
- jec_44
Re: FlatZ Frontpage
I do it, not most beautiful coding but it works !
<!-- DONUT CHART -->
<div class="col-sm-3 col-lg-3" style="width:75%;float: right">
<div class="dash-unit " style="height:610px;overflow-y:scroll">
<dtitle>Traffic</dtitle>
<hr>
<!--<div class="info-user" style="float:right;padding-right:20px;">
<span aria-hidden="true" class="li_news fs2"></span>
</div>-->
<p id="map" style="width:100%; height:100%"></p>
</div>
</div>
</div>
<!-- /row -->
</div>
<!-- /container -->
<script src="http://maps.googleapis.com/maps/api/js?sensor=false"></script>
<script type="text/javascript" charset="utf-8">
var address = 'Nantes, FR';
var map = new google.maps.Map(document.getElementById('map'), {
mapTypeId: google.maps.MapTypeId.TERRAIN,
zoom: 12
var trafficLayer = new google.maps.TrafficLayer();
trafficLayer.setMap(map);
var geocoder = new google.maps.Geocoder();
geocoder.geocode({
'address': address
function(results, status) {
if(status == google.maps.GeocoderStatus.OK) {
new google.maps.Marker({
position: results[0].geometry.location,
map: map
map.setCenter(results[0].geometry.location);
else {
// Google couldn't geocode this request. Handle appropriately.
</script>- jec_44
Re: FlatZ Frontpage
See the result
- Traffic Page
- FlatZ Frontpage - Traffic.png (376.23 KiB) Viewed 5426 times
- galadril
- Domoticz version: latest
Re: FlatZ Frontpage
Looks goodjec_44 wrote:See the result
Domoticz Android app:
https://play.google.com/store/apps/deta ... s.domoticz
SweetPants
Re: FlatZ Frontpage
Where do I set the screen size?
I have an old Nexus 7 tablet but can't get it to fit this screen size
- jec_44
Re: FlatZ Frontpage
galadril, i'am lokking for integrate it into settings.js to be able to enter parameters :
bu i 'don't how to do and how to use it on traffic.html
$.traffic = "Paris, France";
$.zoom = "15";Thanks
- galadril
Re: FlatZ Frontpage
Thanks for the help.jec_44 wrote:but i 'don't how to do and how to use it on traffic.html
I've added the Traffic page to the github project with two new settings in the settings.js
PeterFleur
- Domoticz version: 2.4739
Re: FlatZ Frontpage
Very nice indeed. The traffic part is very good!
Is it possible to add the variable "Refresh interval" on the settings.js file?
The graphs doesn't seem to work anymore (only 1 graph working) or is it a problem in my settings?
Peter
Peter
RaspberryPI
ZWave
RFXtrx433E
ZWave
RFXtrx433E
- jec_44
Re: FlatZ Frontpage
Yes it's very nice Frontpage, congratulations. Some improvement ideas :
- Change language for the Weather, for exemple, i know with openweathermap, you add &lang=fr in the javascript
- An issue : on tablet or Smartphone : menu button (on top right) doesn't work
- Add button to switch on Full Screen
SweetPants
Re: FlatZ Frontpage
nobody??SweetPants wrote:Hi,
- galadril
Re: FlatZ Frontpage
You could try to make your own mainNexus7.cssSweetPants wrote:Where do I set the screen size?
change/add:
.container {
width: 1170px;
}change settings.js to use your mainNexus7.css as the theme.
SwordFish
- Domoticz version: V4.11375
Re: FlatZ Frontpage
@galadril
How youre doing with the implitation of scenes in the frontpage?
Just asking no rush
Just asking no rush
dijkdj
Re: FlatZ Frontpage
I run it my RPI but my screen stays empty. I also tried to run from my laptop, also no result. I turned for example the camera page on, but no result.
Do some file need extra rights?
I Entered the right url and a few IDX switches.
Ierlandfan
Re: FlatZ Frontpage
I love the design!
Do you know if it's possible to add mjpeg streams to the camera page?
mikeoo
Re: FlatZ Frontpage
Very nice template and started today with it and have 2 questions and input.
1. How to combine Temp en Humidity in the frontpage. I have some Cresta Sensors the measure both.
2. I cannot find any weather info in settings.js
Maybe nice to add buienrader info (http://gratisweerdata.buienradar.nl/#Buienradar )
- Brutus
Re: FlatZ Frontpage
Change one of the camera URL's with this link:mikeoo wrote:Very nice template and started today with it and have 2 questions and input.
http://api.buienradar.nl/image/1.0/Rada ... 6&h=256&t=
Greetings
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
mikeoo
Re: FlatZ Frontpage
Indeed good one, but it's nice to get all weather things on it's own page. But for now indeed a good tip tnx.Brutus wrote:Change one of the camera URL's with this link:mikeoo wrote:Very nice template and started today with it and have 2 questions and input.
Greetings
mikeoo
Re: FlatZ Frontpage
Just replace the webcam url in Settins.js with your stream url.Ierlandfan wrote:I love the design!
For Foscam streams you can try this way the get the stream working.
http://www.ipcam-shop.nl/media/Foscam%2 ... I9821W.pdf
