FlatZ Frontpage
mvveelen
Re: FlatZ Frontpage
Post by mvveelen »
You have to change the URL's it in the settings.js in the subfolder js
bickel
Re: FlatZ Frontpage
Post by bickel »
Tnx for the menu options and the webcamsupport!
jec_44
Re: FlatZ Frontpage
Post by jec_44 »
Hi guys,
Wonderfull ! i have a suggestion, could you add a traffic page based on google map ?
I added a new traffic.html page with
<script>
if ($.Traffic)
{document.write('<li class="active" ><a class="stay" href="traffic.html"><i class="icon-th icon-white"></i> Traffic</a></li>');}
</script>
Most difficult is to add correct javascript. It can be useful !
Thk
jec_44
Re: FlatZ Frontpage
Post by jec_44 »
I do it, not most beautiful coding but it works !
<!-- DONUT CHART -->
            <div class="col-sm-3 col-lg-3" style="width:75%;float: right">
               <div class="dash-unit " style="height:610px;overflow-y:scroll">
                  <dtitle>Traffic</dtitle>
                  <hr>
                  <!--<div class="info-user" style="float:right;padding-right:20px;">
                     <span aria-hidden="true" class="li_news fs2"></span>
                  </div>-->
                  <p id="map" style="width:100%; height:100%"></p>
               </div>
            </div>
         </div>
         <!-- /row -->
      </div>
      <!-- /container -->
	  <script src="http://maps.googleapis.com/maps/api/js?sensor=false"></script>
	<script type="text/javascript" charset="utf-8">
var address = 'Nantes, FR';
   var map = new google.maps.Map(document.getElementById('map'), {
       mapTypeId: google.maps.MapTypeId.TERRAIN,
       zoom: 12
	var trafficLayer = new google.maps.TrafficLayer();
  trafficLayer.setMap(map);
   var geocoder = new google.maps.Geocoder();
   geocoder.geocode({
      'address': address
   function(results, status) {
      if(status == google.maps.GeocoderStatus.OK) {
         new google.maps.Marker({
            position: results[0].geometry.location,
            map: map
         map.setCenter(results[0].geometry.location);
      else {
         // Google couldn't geocode this request. Handle appropriately.
</script>
jec_44
Re: FlatZ Frontpage
Post by jec_44 »
See the result
Traffic Page
Traffic Page
FlatZ Frontpage - Traffic.png (376.23 KiB) Viewed 5429 times
galadril
Domoticz version: latest
Re: FlatZ Frontpage
Post by galadril »
jec_44 wrote:See the result
Looks good :)
SweetPants
Re: FlatZ Frontpage
Post by SweetPants »
Where do I set the screen size?
I have an old Nexus 7 tablet but can't get it to fit this screen size
jec_44
Re: FlatZ Frontpage
Post by jec_44 »
galadril, i'am lokking for integrate it into settings.js to be able to enter parameters :
$.traffic = "Paris, France";
$.zoom = "15";
bu i 'don't how to do and how to use it on traffic.html
galadril
Re: FlatZ Frontpage
Post by galadril »
jec_44 wrote:but i 'don't how to do and how to use it on traffic.html
Thanks for the help.
I've added the Traffic page to the github project with two new settings in the settings.js
PeterFleur
Domoticz version: 2.4739
Re: FlatZ Frontpage
Post by PeterFleur »
Very nice indeed. The traffic part is very good!
Is it possible to add the variable "Refresh interval" on the settings.js file?
The graphs doesn't seem to work anymore (only 1 graph working) or is it a problem in my settings?
Peter
RaspberryPI
ZWave
RFXtrx433E
jec_44
Re: FlatZ Frontpage
Post by jec_44 »
Yes it's very nice Frontpage, congratulations. Some improvement ideas :
  • Change language for the Weather, for exemple, i know with openweathermap, you add &lang=fr in the javascript
  • An issue : on tablet or Smartphone : menu button (on top right) doesn't work
  • Add button to switch on Full Screen
SweetPants
Re: FlatZ Frontpage
SweetPants wrote:Hi,
nobody??
galadril
Re: FlatZ Frontpage
Post by galadril »
SweetPants wrote:Where do I set the screen size?
You could try to make your own mainNexus7.css
change/add:
.container {
    width: 1170px;
and set the width to your needs.
change settings.js to use your mainNexus7.css as the theme.
SwordFish
Domoticz version: V4.11375
Re: FlatZ Frontpage
Post by SwordFish »
@galadril
How youre doing with the implitation of scenes in the frontpage?
Just asking no rush ;)
dijkdj
Re: FlatZ Frontpage
Post by dijkdj »
I run it my RPI but my screen stays empty. I also tried to run from my laptop, also no result. I turned for example the camera page on, but no result.
Do some file need extra rights?
I Entered the right url and a few IDX switches.
Ierlandfan
Re: FlatZ Frontpage
Post by Ierlandfan »
I love the design!
Do you know if it's possible to add mjpeg streams to the camera page?
mikeoo
Re: FlatZ Frontpage
Post by mikeoo »
Very nice template and started today with it and have 2 questions and input.
1. How to combine Temp en Humidity in the frontpage. I have some Cresta Sensors the measure both.
2. I cannot find any weather info in settings.js
Maybe nice to add buienrader info (http://gratisweerdata.buienradar.nl/#Buienradar )
Brutus
Re: FlatZ Frontpage
Post by Brutus »
mikeoo wrote:Very nice template and started today with it and have 2 questions and input.
Change one of the camera URL's with this link:
http://api.buienradar.nl/image/1.0/Rada ... 6&h=256&t=
Greetings
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
mikeoo
Re: FlatZ Frontpage
Post by mikeoo »
Greetings
Indeed good one, but it's nice to get all weather things on it's own page. But for now indeed a good tip tnx.
mikeoo
Re: FlatZ Frontpage
Post by mikeoo »
Ierlandfan wrote:I love the design!
Just replace the webcam url in Settins.js with your stream url.
For Foscam streams you can try this way the get the stream working.
http://www.ipcam-shop.nl/media/Foscam%2 ... I9821W.pdf
