Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
Shelly support by Domoticz
- Domoticz version: 2026.3
Re: Shelly support by Domoticz
BartSr
- Domoticz version: V2024.7
Apart from all fine and helpfull instructions:
Domoticz is running in docker on a HP T630 thin client with plenty of storage.
I bought cheapest Shellies at Hornbach. ChatGpt advised and learned how to get these to work using python and mqtt. Once that was done integration in dz using auto mqtt detect was piece of cake.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- imautohuttraeger
- Domoticz version: lat.beta
So you first had to make an own python script / plugin / whatsoever ?BartSr wrote: Thursday 19 November 2026 19:31 Apart from all fine and helpfull instructions:
Stop, look and listen.
gerardvs
- Domoticz version: latest-1
You could also make a little bash script. As an example this is the script I use to add my Shellies 1 Gen3. It is not that difficult.
** edit: better use of ' and " **
#!/usr/bin/env bash
# Basic settings
BROKERIP="<broker-ip>"
BROKERPORT="1883"
MQTTROOT="homeassistant"
# Change for each device
SHELLYDEVICE="shellyxyz-aabbcc1122"
SHELLYNAME="<name within Domoticz>"
# Add Relay
PAYLOAD=$(cat <<EOF
"name": "$SHELLYNAME",
"unique_id": "$SHELLYDEVICE-relay",
"command_topic": "$SHELLYDEVICE/command/switch:0",
"state_topic": "$SHELLYDEVICE/status/switch:0",
"value_template": "{{ value_json.output }}",
"payload_on": "on",
"payload_off": "off",
"state_on": "true",
"state_off": "false"
EOF
mosquitto_pub -h "$BROKERIP" -p "$BROKERPORT" -r \
-t "$MQTTROOT/switch/$SHELLYDEVICE/config" \
-m "$PAYLOAD"
# Add Temperature
PAYLOAD=$(cat <<EOF
"name": "$SHELLYNAME Temperature",
"unique_id": "$SHELLYDEVICE-temperature",
"value_template": "{{ value_json.temperature.tC }}",
"unit_of_measurement": "C",
"device_class": "temperature"
EOF
-t "$MQTTROOT/sensor/$SHELLYDEVICE/config" \
-m "$PAYLOAD"
# Add Input (be aware of button type in Shelly device)
PAYLOAD=$(cat <<EOF
"name": "$SHELLYNAME Input",
"unique_id": "$SHELLYDEVICE-input",
"state_topic": "$SHELLYDEVICE/status/input:0",
"value_template": "{{ value_json.state }}",
"payload_on": "true",
"payload_off": "false",
"device_class": "power"
EOF
-t "$MQTTROOT/binary_sensor/$SHELLYDEVICE/config" \
-m "$PAYLOAD"
Last edited by gerardvs on Saturday 21 November 2026 19:56, edited 1 time in total.
- gizmocuz
You're correct, it is generated by this script:waltervl wrote: Thursday 19 November 2026 9:21Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
https://github.com/bieniu/ha-shellies-discovery-gen2
But as these devices are so popular, I am looking about natively integrating them now.
(Also the company has been bought and we have to see what the feature remains)
- imautohuttraeger
Oh, that is great to hear - highly appreciated! This would be much more simple-user friendly than having to create scripts for every device.gizmocuz wrote: Friday 20 November 2026 9:53 But as these devices are so popular, I am looking about natively integrating them now.
- lemassykoi
- Domoticz version: 2025.1
why not using websockets (like I did in my plugin) ?
for pure data collection efficiency on Gen2+ devices, WebSocket RPC wins
WebSocket (native RPC)
- Real-time push of status events directly from the device, no broker hop, no polling, lowest latency
- Fewer moving parts: no broker to run, secure, or monitor. Devices just open an outbound connection to your collector
- This is what Home Assistant's native Shelly integration uses by default for Gen2/3/4, with zero config
- Limits: point-to-point only (one connection per client), max 6 simultaneous non-persistent RPC channels per device, and no buffering. If your collector is down, events are lost, there's no retention like a broker
- imautohuttraeger
Partly, am really using this as a workaround. At least I use http commands. I could be wrong, but for a slider device (e.g. roller shutter percentage) it is not feasible.lemassykoi wrote: Sunday 22 November 2026 20:25 why not using websockets (like I did in my plugin) ?
- gizmocuz
Native Shelly support should now be working in Domoticz beta 2026.4.18655 and can be added from the hardware page (Choose Shelly as HW Type)
Also consult the wiki documentation
https://wiki.domoticz.com/Shelly
Once you added the hardware you can press the setup button from the hardware list, and at the bottom you can scan your network (enter your IP range like 192.168.0.1/24 to scan all your devices)
They should be detected and you can add them.
The native implementation also uses websockets except for Gen1
BurningTyre
- Domoticz version: 2026.4
If you already have several Shelly devices set up in Domoticz via MQTT autodiscovery, would there still be any advantage to adding them using this method instead?
- gizmocuz
Yes, and i would then not use MQTT-AD has it is more native. But if you have a fully working system, then leave it on MQTT-AD, you can also only add certain devices that do not work correctly with MQTT-AD... but i hope they just work
- imautohuttraeger
Wow, thank you very much! Must wait until next weekend to test it.gizmocuz wrote: Monday 23 November 2026 9:17 Native Shelly support should now be working in Domoticz beta 2026.4.18655 and can be added from the hardware page (Choose Shelly as HW Type)
- imautohuttraeger
Success-story:
Couldn't wait until the weekend
Already implemented
a Plus 2pm device (used for a roller shutter)
and a Plus H&T (Temperature an Humidity)
Fast and easy implementation by simply typing in the IP.
Now I can replace the old Domoticz devices that I had to learn by shelly teacher (percentage sliders did not work).
Looking at the wiki documentation I can only have a glimpse of imagination how much work this was. Thanks again!
You have a very happy user!
Already implemented
- gizmocuz
Using the scanner at the bottom of the setup page would possibly be even easier than typing in all IP addresses by hand
- imautohuttraeger
Sure, but this was just the first quick test.
EDIT: Will use the scan (confirm it is working perfectly) when I will start to to integrate all other Shelly (31) devices I have.
And I want / must proceed step-by step with only one Shelly device per step in order to keep the overview.
- Deactivate MQTT in the Shelly device (so I need the specific IP anyhow)
- Establish this one single Shelly device in Domoticz with SHELLY NATIVE
- Ensure the new Domoticz devices are running
- Identify the corresponding old Domoticz device(s) of MQTT AD
- Identify every skript and scene etc. using the old device(s)
- Replace the old IDX(es) against the new IDX(es) there
- Ensure all is working
- Finally delete the old device, so the system is clean.
I know that an old device idx can replace a new device idx. That would surely be faster and easier. But I am scared of loosing control and overview in the debugging and cleaning phase for 31 further Shelly devices (each creating several Domoticz devices) ...
gerardvs
Thanks for creating this very useful addition!
There is for a Shelly 1 Gen1 a small cosmetic issue. Upon creation there is also a power device created. However the SHSW-1 does not have power measurement. Not a big issue of course since we can leave the device "unused".
Maybe the /status page is confusing for the new hardware addition. (see below)
Again, not an issue for me but just to let you know.
"relays": [
"ison": false,
"has_timer": false,
"timer_started": 0,
"timer_duration": 0,
"timer_remaining": 0,
"source": "http"
"meters": [
"power": 0,
"is_valid": true
"inputs": [
"input": 0,
"event": "",
"event_cnt": 0
"ext_sensors": {
"ext_temperature": {
"ext_humidity": {
- imautohuttraeger
First Integration of several shelly 2pm Gen. 2 (for roller shutters) and other devices done. Works perfect so far. And finally I even even managed to clean the old MQTT-AD Topics (#proud
), so that deleted devices are not always created again new.
One thing I have recognized is, that a battery driven device (Shelly H&T Gen. 3) shows an error when it is not reachable in sleep mode. This is of course a correct information, but a little bit misleading as "Error" indicates, that something is wrong, although the sleep mode is wanted with purpose. That's absolutely OK of course, but I just wanted to inform in case this could be changed from red "Error" to maybe something like a green "Status" or so.
2026-11-25 16:21:46.120 Error: Shelly native: Shelly HT Gen3 mit Display (192.168.1.121) is unreachable
2026-11-25 16:27:54.910 Status: Shelly native: Shelly HT Gen3 mit Display (192.168.1.121) is online
2026-11-25 16:34:11.641 Error: Shelly native: Shelly HT Gen3 mit Display (192.168.1.121) is unreachableStop, look and listen.
BartSr
@ imautohuttraeger
Yes, that's trueBartSr wrote: Thursday 19 November 2026 20:31
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BurningTyre
Did you manually deleted the MQTT-AD topics?imautohuttraeger wrote: Wednesday 25 November 2026 16:56 First Integration of several shelly 2pm Gen. 2 (for roller shutters) and other devices done. Works perfect so far. And finally I even even managed to clean the old MQTT-AD Topics (#proud), so that deleted devices are not always created again new.
2026-11-25 16:21:46.120 Error: Shelly native: Shelly HT Gen3 mit Display (192.168.1.121) is unreachable 2026-11-25 16:27:54.910 Status: Shelly native: Shelly HT Gen3 mit Display (192.168.1.121) is online 2026-11-25 16:34:11.641 Error: Shelly native: Shelly HT Gen3 mit Display (192.168.1.121) is unreachable
- imautohuttraeger
Yes. I deactivated MQTT in web-interface of the Shelly device and copied the topic (settings / MQTT). Then I pasted it into the search filed of MQTT-Explorer. Then I deleted each and every found topic.BurningTyre wrote: Thursday 26 November 2026 9:36Did you manually deleted the MQTT-AD topics?imautohuttraeger wrote: Wednesday 25 November 2026 16:56 First Integration of several shelly 2pm Gen. 2 (for roller shutters) and other devices done. Works perfect so far. And finally I even even managed to clean the old MQTT-AD Topics (#proud), so that deleted devices are not always created again new.
