Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
Shelly support by Domoticz
- Domoticz version: 2026.3
Re: Shelly support by Domoticz
BartSr
- Domoticz version: V2024.7
Apart from all fine and helpfull instructions:
Domoticz is running in docker on a HP T630 thin client with plenty of storage.
I bought cheapest Shellies at Hornbach. ChatGpt advised and learned how to get these to work using python and mqtt. Once that was done integration in dz using auto mqtt detect was piece of cake.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- imautohuttraeger
- Domoticz version: lat.beta
So you first had to make an own python script / plugin / whatsoever ?BartSr wrote: Thursday 19 November 2026 19:31 Apart from all fine and helpfull instructions:
Stop, look and listen.
gerardvs
- Domoticz version: latest-1
You could also make a little bash script. As an example this is the script I use to add my Shellies 1 Gen3. It is not that difficult.
** edit: better use of ' and " **
#!/usr/bin/env bash
# Basic settings
BROKERIP="<broker-ip>"
BROKERPORT="1883"
MQTTROOT="homeassistant"
# Change for each device
SHELLYDEVICE="shellyxyz-aabbcc1122"
SHELLYNAME="<name within Domoticz>"
# Add Relay
PAYLOAD=$(cat <<EOF
"name": "$SHELLYNAME",
"unique_id": "$SHELLYDEVICE-relay",
"command_topic": "$SHELLYDEVICE/command/switch:0",
"state_topic": "$SHELLYDEVICE/status/switch:0",
"value_template": "{{ value_json.output }}",
"payload_on": "on",
"payload_off": "off",
"state_on": "true",
"state_off": "false"
EOF
mosquitto_pub -h "$BROKERIP" -p "$BROKERPORT" -r \
-t "$MQTTROOT/switch/$SHELLYDEVICE/config" \
-m "$PAYLOAD"
# Add Temperature
PAYLOAD=$(cat <<EOF
"name": "$SHELLYNAME Temperature",
"unique_id": "$SHELLYDEVICE-temperature",
"value_template": "{{ value_json.temperature.tC }}",
"unit_of_measurement": "C",
"device_class": "temperature"
EOF
-t "$MQTTROOT/sensor/$SHELLYDEVICE/config" \
-m "$PAYLOAD"
# Add Input (be aware of button type in Shelly device)
PAYLOAD=$(cat <<EOF
"name": "$SHELLYNAME Input",
"unique_id": "$SHELLYDEVICE-input",
"state_topic": "$SHELLYDEVICE/status/input:0",
"value_template": "{{ value_json.state }}",
"payload_on": "true",
"payload_off": "false",
"device_class": "power"
EOF
-t "$MQTTROOT/binary_sensor/$SHELLYDEVICE/config" \
-m "$PAYLOAD"
Last edited by gerardvs on Saturday 21 November 2026 19:56, edited 1 time in total.
- gizmocuz
You're correct, it is generated by this script:waltervl wrote: Thursday 19 November 2026 9:21Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
https://github.com/bieniu/ha-shellies-discovery-gen2
But as these devices are so popular, I am looking about natively integrating them now.
(Also the company has been bought and we have to see what the feature remains)
- imautohuttraeger
Oh, that is great to hear - highly appreciated! This would be much more simple-user friendly than having to create scripts for every device.gizmocuz wrote: Friday 20 November 2026 9:53 But as these devices are so popular, I am looking about natively integrating them now.
- lemassykoi
- Domoticz version: 2025.1
why not using websockets (like I did in my plugin) ?
for pure data collection efficiency on Gen2+ devices, WebSocket RPC wins
WebSocket (native RPC)
- Real-time push of status events directly from the device, no broker hop, no polling, lowest latency
- Fewer moving parts: no broker to run, secure, or monitor. Devices just open an outbound connection to your collector
- This is what Home Assistant's native Shelly integration uses by default for Gen2/3/4, with zero config
- Limits: point-to-point only (one connection per client), max 6 simultaneous non-persistent RPC channels per device, and no buffering. If your collector is down, events are lost, there's no retention like a broker
- imautohuttraeger
Partly, am really using this as a workaround. At least I use http commands. I could be wrong, but for a slider device (e.g. roller shutter percentage) it is not feasible.lemassykoi wrote: Sunday 22 November 2026 20:25 why not using websockets (like I did in my plugin) ?
- gizmocuz
Native Shelly support should now be working in Domoticz beta 2026.4.18655 and can be added from the hardware page (Choose Shelly as HW Type)
Also consult the wiki documentation
https://wiki.domoticz.com/Shelly
Once you added the hardware you can press the setup button from the hardware list, and at the bottom you can scan your network (enter your IP range like 192.168.0.1/24 to scan all your devices)
They should be detected and you can add them.
The native implementation also uses websockets except for Gen1
BurningTyre
- Domoticz version: 2026.4
If you already have several Shelly devices set up in Domoticz via MQTT autodiscovery, would there still be any advantage to adding them using this method instead?
- gizmocuz
Yes, and i would then not use MQTT-AD has it is more native. But if you have a fully working system, then leave it on MQTT-AD, you can also only add certain devices that do not work correctly with MQTT-AD... but i hope they just work
