Shelly support by Domoticz
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
Domoticz version: 2026.3
Re: Shelly support by Domoticz
gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?
BartSr
Domoticz version: V2024.7
Post by BartSr »
Apart from all fine and helpfull instructions:
Domoticz is running in docker on a HP T630 thin client with plenty of storage.
I bought cheapest Shellies at Hornbach. ChatGpt advised and learned how to get these to work using python and mqtt. Once that was done integration in dz using auto mqtt detect was piece of cake.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
BartSr wrote: Thursday 19 November 2026 19:31 Apart from all fine and helpfull instructions:
So you first had to make an own python script / plugin / whatsoever ?
Stop, look and listen.
gerardvs
Domoticz version: latest-1
Post by gerardvs »
You could also make a little bash script. As an example this is the script I use to add my Shellies 1 Gen3. It is not that difficult.
#!/bin/env bash
# Basic settings
BROKERIP="192.168.123.123"
BROKERPORT="1883"
MQTTROOT="homeassistant"
# Change for each device
SHELLYDEVICE="shelly1g3-112233445566"
SHELLYNAME="Shelly 1 BlueG3"
# Add Relay
mosquitto_pub -h $BROKERIP -p $BROKERPORT -r \
  -t "$MQTTROOT/switch/$SHELLYDEVICE/config" \
  -m '{
    "name": "$SHELLYNAME",
    "unique_id": "$SHELLYDEVICE-relay",
    "command_topic": "$SHELLYDEVICE/command/switch:0",
    "state_topic": "$SHELLYDEVICE/status/switch:0",
    "value_template": "{{ value_json.output }}",
    "payload_on": "on",
    "payload_off": "off",
    "state_on": "true",
    "state_off": "false"
# Add Temperature
  -t "$MQTTROOT/sensor/$SHELLYDEVICE-temperature/config" \
  -m '{
    "name": "$SHELLYNAME Temperature",
    "unique_id": "$SHELLYDEVICE-temperature",
    "value_template": "{{ value_json.temperature.tC }}",
    "unit_of_measurement": "C",
    "device_class": "temperature"
# Add Input (be aware of button type in Shelly device)
  -t "$MQTTROOT/binary_sensor/$SHELLYDEVICE-input/config" \
  -m '{
    "name": "$SHELLYNAME Input",
    "unique_id": "$SHELLYDEVICE-input",
    "state_topic": "$SHELLYDEVICE/status/input:0",
    "value_template": "{{ value_json.state }}",
    "payload_on": "true",
    "payload_off": "false",
    "device_class": "power"
