Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
Shelly support by Domoticz
- Domoticz version: 2026.3
Re: Shelly support by Domoticz
BartSr
- Domoticz version: V2024.7
Apart from all fine and helpfull instructions:
Domoticz is running in docker on a HP T630 thin client with plenty of storage.
I bought cheapest Shellies at Hornbach. ChatGpt advised and learned how to get these to work using python and mqtt. Once that was done integration in dz using auto mqtt detect was piece of cake.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- imautohuttraeger
- Domoticz version: lat.beta
So you first had to make an own python script / plugin / whatsoever ?BartSr wrote: Thursday 19 November 2026 19:31 Apart from all fine and helpfull instructions:
Stop, look and listen.
gerardvs
- Domoticz version: latest-1
You could also make a little bash script. As an example this is the script I use to add my Shellies 1 Gen3. It is not that difficult.
#!/bin/env bash
# Basic settings
BROKERIP="192.168.123.123"
BROKERPORT="1883"
MQTTROOT="homeassistant"
# Change for each device
SHELLYDEVICE="shelly1g3-112233445566"
SHELLYNAME="Shelly 1 BlueG3"
# Add Relay
mosquitto_pub -h $BROKERIP -p $BROKERPORT -r \
-t "$MQTTROOT/switch/$SHELLYDEVICE/config" \
-m '{
"name": "$SHELLYNAME",
"unique_id": "$SHELLYDEVICE-relay",
"command_topic": "$SHELLYDEVICE/command/switch:0",
"state_topic": "$SHELLYDEVICE/status/switch:0",
"value_template": "{{ value_json.output }}",
"payload_on": "on",
"payload_off": "off",
"state_on": "true",
"state_off": "false"
# Add Temperature
-t "$MQTTROOT/sensor/$SHELLYDEVICE-temperature/config" \
-m '{
"name": "$SHELLYNAME Temperature",
"unique_id": "$SHELLYDEVICE-temperature",
"value_template": "{{ value_json.temperature.tC }}",
"unit_of_measurement": "C",
"device_class": "temperature"
# Add Input (be aware of button type in Shelly device)
-t "$MQTTROOT/binary_sensor/$SHELLYDEVICE-input/config" \
-m '{
"name": "$SHELLYNAME Input",
"unique_id": "$SHELLYDEVICE-input",
"state_topic": "$SHELLYDEVICE/status/input:0",
"value_template": "{{ value_json.state }}",
"payload_on": "true",
"payload_off": "false",
"device_class": "power"
- gizmocuz
You're correct, it is generated by this script:waltervl wrote: Thursday 19 November 2026 9:21Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
https://github.com/bieniu/ha-shellies-discovery-gen2
But as these devices are so popular, I am looking about natively integrating them now.
(Also the company has been bought and we have to see what the feature remains)
- imautohuttraeger
Oh, that is great to hear - highly appreciated! This would be much more simple-user friendly than having to create scripts for every device.gizmocuz wrote: Friday 20 November 2026 9:53 But as these devices are so popular, I am looking about natively integrating them now.
