Shelly support by Domoticz
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
Domoticz version: 2026.3
Re: Shelly support by Domoticz
gizmocuz wrote: Thursday 19 November 2026 7:25 I have very limited Shelly devices, but did test against a wide range of MQTT-AD shelly configuration files i could find.
Then is the question: How to find or create those MQTT-AD shelly configuration files? Is it by doing a setting in the shelly user interface? Or just search on the net and publish it to MQTT?
BartSr
Domoticz version: V2024.7
Post by BartSr »
Apart from all fine and helpfull instructions:
Domoticz is running in docker on a HP T630 thin client with plenty of storage.
I bought cheapest Shellies at Hornbach. ChatGpt advised and learned how to get these to work using python and mqtt. Once that was done integration in dz using auto mqtt detect was piece of cake.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
BartSr wrote: Thursday 19 November 2026 19:31 Apart from all fine and helpfull instructions:
So you first had to make an own python script / plugin / whatsoever ?
Stop, look and listen.
gerardvs
Domoticz version: latest-1
Post by gerardvs »
You could also make a little bash script. As an example this is the script I use to add my Shellies 1 Gen3. It is not that difficult.
#!/usr/bin/env bash
# Basic settings
BROKERIP="<broker-ip>"
BROKERPORT="1883"
MQTTROOT="homeassistant"
# Change for each device
SHELLYDEVICE="shellyxyz-aabbcc1122"
SHELLYNAME="<name within Domoticz>"
# Add Relay
PAYLOAD=$(cat <<EOF
    "name": "$SHELLYNAME",
    "unique_id": "$SHELLYDEVICE-relay",
    "command_topic": "$SHELLYDEVICE/command/switch:0",
    "state_topic": "$SHELLYDEVICE/status/switch:0",
    "value_template": "{{ value_json.output }}",
    "payload_on": "on",
    "payload_off": "off",
    "state_on": "true",
    "state_off": "false"
EOF
mosquitto_pub -h "$BROKERIP" -p "$BROKERPORT" -r \
  -t "$MQTTROOT/switch/$SHELLYDEVICE/config" \
  -m "$PAYLOAD"
# Add Temperature
PAYLOAD=$(cat <<EOF
    "name": "$SHELLYNAME Temperature",
    "unique_id": "$SHELLYDEVICE-temperature",
    "value_template": "{{ value_json.temperature.tC }}",
    "unit_of_measurement": "C",
    "device_class": "temperature"
EOF
  -t "$MQTTROOT/sensor/$SHELLYDEVICE/config" \
  -m "$PAYLOAD"
# Add Input (be aware of button type in Shelly device)
PAYLOAD=$(cat <<EOF
    "name": "$SHELLYNAME Input",
    "unique_id": "$SHELLYDEVICE-input",
    "state_topic": "$SHELLYDEVICE/status/input:0",
    "value_template": "{{ value_json.state }}",
    "payload_on": "true",
    "payload_off": "false",
    "device_class": "power"
EOF
  -t "$MQTTROOT/binary_sensor/$SHELLYDEVICE/config" \
  -m "$PAYLOAD"
** edit: better use of ' and " **
Last edited by gerardvs on Saturday 21 November 2026 19:56, edited 1 time in total.
gizmocuz
Post by gizmocuz »
waltervl wrote: Thursday 19 November 2026 9:21
You're correct, it is generated by this script:
https://github.com/bieniu/ha-shellies-discovery-gen2
But as these devices are so popular, I am looking about natively integrating them now.
(Also the company has been bought and we have to see what the feature remains)
imautohuttraeger
gizmocuz wrote: Friday 20 November 2026 9:53 But as these devices are so popular, I am looking about natively integrating them now.
Oh, that is great to hear - highly appreciated! This would be much more simple-user friendly than having to create scripts for every device.
lemassykoi
Domoticz version: 2025.1
Post by lemassykoi »
why not using websockets (like I did in my plugin) ?
for pure data collection efficiency on Gen2+ devices, WebSocket RPC wins
WebSocket (native RPC)
- Real-time push of status events directly from the device, no broker hop, no polling, lowest latency
- Fewer moving parts: no broker to run, secure, or monitor. Devices just open an outbound connection to your collector
- This is what Home Assistant's native Shelly integration uses by default for Gen2/3/4, with zero config
- Limits: point-to-point only (one connection per client), max 6 simultaneous non-persistent RPC channels per device, and no buffering. If your collector is down, events are lost, there's no retention like a broker
imautohuttraeger
lemassykoi wrote: Sunday 22 November 2026 20:25 why not using websockets (like I did in my plugin) ?
Partly, am really using this as a workaround. At least I use http commands. I could be wrong, but for a slider device (e.g. roller shutter percentage) it is not feasible.
gizmocuz
Post by gizmocuz »
Native Shelly support should now be working in Domoticz beta 2026.4.18655 and can be added from the hardware page (Choose Shelly as HW Type)
Also consult the wiki documentation
https://wiki.domoticz.com/Shelly
Once you added the hardware you can press the setup button from the hardware list, and at the bottom you can scan your network (enter your IP range like 192.168.0.1/24 to scan all your devices)
They should be detected and you can add them.
The native implementation also uses websockets except for Gen1
BurningTyre
Domoticz version: 2026.4
Post by BurningTyre »
If you already have several Shelly devices set up in Domoticz via MQTT autodiscovery, would there still be any advantage to adding them using this method instead?
gizmocuz
Post by gizmocuz »
Yes, and i would then not use MQTT-AD has it is more native. But if you have a fully working system, then leave it on MQTT-AD, you can also only add certain devices that do not work correctly with MQTT-AD... but i hope they just work
imautohuttraeger
gizmocuz wrote: Monday 23 November 2026 9:17 Native Shelly support should now be working in Domoticz beta 2026.4.18655 and can be added from the hardware page (Choose Shelly as HW Type)
Wow, thank you very much! Must wait until next weekend to test it.
imautohuttraeger
Success-story:
Couldn't wait until the weekend ;-)
Already implemented
a Plus 2pm device (used for a roller shutter)
and a Plus H&T (Temperature an Humidity)
Fast and easy implementation by simply typing in the IP.
Now I can replace the old Domoticz devices that I had to learn by shelly teacher (percentage sliders did not work).
Looking at the wiki documentation I can only have a glimpse of imagination how much work this was. Thanks again!
You have a very happy user!
gizmocuz
Post by gizmocuz »
Using the scanner at the bottom of the setup page would possibly be even easier than typing in all IP addresses by hand 😁
imautohuttraeger
Sure, but this was just the first quick test.
EDIT: Will use the scan (confirm it is working perfectly) when I will start to to integrate all other Shelly (31) devices I have.
And I want / must proceed step-by step with only one Shelly device per step in order to keep the overview.
- Deactivate MQTT in the Shelly device (so I need the specific IP anyhow)
- Establish this one single Shelly device in Domoticz with SHELLY NATIVE
- Ensure the new Domoticz devices are running
- Identify the corresponding old Domoticz device(s) of MQTT AD
- Identify every skript and scene etc. using the old device(s)
- Replace the old IDX(es) against the new IDX(es) there
- Ensure all is working
- Finally delete the old device, so the system is clean.
I know that an old device idx can replace a new device idx. That would surely be faster and easier. But I am scared of loosing control and overview in the debugging and cleaning phase for 31 further Shelly devices (each creating several Domoticz devices) ...
