Aurora theme
blauwebuis
Domoticz version: current
Re: Aurora theme
Post by blauwebuis »
@miljume, @marcin: thanks, I'll look into it.
AFUDirk
Re: Aurora theme
Post by AFUDirk »
zak45 wrote: Monday 18 December 2017 17:18 Not able to save the settings for the theme, every time I made modification and save, when come back to settings, retreive old (original)values:
Hello, has a solution been found here already?
Is it the file rights that have to be legislated with Chmod? :?
blauwebuis
Re: Aurora theme
@AFUDirk: yes this has been fixed.
JustMitchie
Re: Aurora theme
Post by JustMitchie »
Hello, is it possible to have the dashboard data visualisation graphs to show the monthly by default? Or hourly...? I find those options far more usefull.
blauwebuis
Re: Aurora theme
That is not currently built. The code is open source, so you could add these features to the theme.
Gironimo
Re: Aurora theme
Post by Gironimo »
Hi all, I have installed Aurora to be able to show a liveview of my ip cameras. I added now 3 of them in the dashboard, but only the first one in the row shows the liveview. If I swap the widget around it shows the first one in the row. Is this a limitation or a bug? Thanks for your help!
remb0
Re: Aurora theme
Post by remb0 »
Since one of the last update the RGB(w) color selector is not oke.
2018-04-14 10_09_53-Domoticz.png (313.79 KiB) Viewed 5882 times
pj-r
Domoticz version: V3.8650
Re: Aurora theme
Post by pj-r »
pj-r wrote: Wednesday 03 January 2018 0:40
pj-r wrote: Wednesday 20 December 2017 23:59 Nice, looks very nice!
Would it be hard to show the optionlist of rooms(dropdown) as row of buttons?
Displaying the rooms as buttons could be quite handy on tablet screen since the dropdown is not that touch friendly.
Perhaps the dropdown could stay where it is but the buttons would be additional and not for all rooms. Generating the buttons could use some filtering from rooms. For example generate button if room name contains some char.
This is what I meant. Some of the roomplans could be as buttons in addition to the drop down:
(of course with some nice styling :D )
blauwebuis wrote: Thursday 04 January 2018 18:23 @pj-r: the room buttons could be a feature in the future, but for now I just want to get things stable. I suspect it would be a little complex: where would the buttons go technically (where in the html). Domoticz is very difficult to work with, as it constantly changes html output. There are bannav tables, pre-bannev tables. Always filled with different things. Sometimes there’s a wrapper. It’s a mess. I standardise this when I was working on the new default theme, but those changes weren’t integrated..are fixed.
Looks like some one else would appreciate this feature too ;)
viewtopic.php?f=4&t=22975
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
nissart78
Re: Aurora theme
Post by nissart78 »
Hi everyone.
I was wondering if there is a way to change / custom columns.
Please have a look at the following pictures.
Let me know if it is possible.
Arnaud
devros
Re: Aurora theme
Post by devros »
hi, anyone know how to modify css to display T: and A: (total and actual) value on power metter sensor?
On mobile view its displayed correctly but on web view is only actual displayed....
Tried to dig into css and looks like td#status is hidden on default web view.
Dunno if this is only this theme problem or domoticz bug.
edit:
found way...
add this code to css (or modify elements)
and total is back
div#bstatus.item.General.kWh   td#status {
        float:right!important;
    display: inline-block!important;
    width: 30%!important;
    margin-top: -40px!important;
    margin-right: 5px!important;
assenzuid
Re: Aurora theme
Post by assenzuid »
miljume wrote: Monday 12 March 2018 20:56 Very nice theme, I just downloaded and installed it !
However I have problems in the mobile view (on my smartphone with Android 8.0) where no temp sensors or switches shows the value for each sensor (see picture)
I have tried clearing the cache, restarting Domoticz and tried both Chrome and Firefox without success
Any clues?
EDIT: Turned off "iPhone style" in settings and now they are showing up again !
Same here, also the values for the smart meters are not shown.
blauwebuis
Re: Aurora theme
I've made two fixes.
- Added an icon for swtich-off state (see issue on github)
- Fixed the color selector.
blauwebuis
Re: Aurora theme
I've fixed the mobile display of values
CLEMENT99
Re: Aurora theme
Post by CLEMENT99 »
blauwebuis wrote: Saturday 05 May 2018 8:09 I've fixed the mobile display of values
Thanks ! Great job !
Jochem
Domoticz version: 4.10181
Re: Aurora theme
Post by Jochem »
Blauewebuis,
I missed the sliders at the dimmer at the tab Switches...
I hope you can fix it soon..
Raspberry P3, RF-Link FW version 48, lots of KAKU switches, Sonos connected, LG TV switching, a lot of weather switches.
Xztraz
Re: Aurora theme
Post by Xztraz »
Jochem wrote: Sunday 06 May 2018 20:47 Blauewebuis,
Do you mean this bug?
https://github.com/domoticz/domoticz/issues/2370
Jochem
Re: Aurora theme
Post by Jochem »
Hello Xtraz,
That' s the problem that I have, but I don't understand how to fix it...
hsvt
Re: Aurora theme
Post by hsvt »
When I put more than 6 switches in 1 merge-block, they don't stands in one line below each other.
With 6 it's fine.
Are there more with this problem?
quack3d
Re: Aurora theme
Post by quack3d »
Anyone got a css of a more modern color palette they would like to share that is not as white as the iPhone style colors? The default is too much like the theme author's nickname : blue web ui :D
I much prefer the colors in the dark-th3me for instance.
blauwebuis
Re: Aurora theme
@hsvt: this is normal behaviour. There is a limit.
@quack3D: you can already change the colours to whatever you like in the theme settings.
