matteos1
Post by matteos1 »
yes i try but o don't know if the variable is off when the door is close or "close"
sam329
Post by sam329 »
DasK wrote: Wednesday 18 May 2016 14:06 Any news? Is it possible to control Xiaomi devices with Domoticz? It would be great
The same question for me too man!! But I have seen so many people http://www.domoticz.com/forum/viewtopic ... 4&start=20 opting for Neato XV Pro because of easy monitoring with domoticz and the communication speed.
What about the Xiaomi???
Oleg
Post by Oleg »
martijnm wrote: Sunday 03 September 2017 15:57 I believe they are the same except for a different brandname (Aqara vs. Xiaomi)
at me the square device was defined incorrectly - temperature and humidity have identical ID and pressure of another with type "general". Also, the battery level is not displayed
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
matteos1 wrote: Monday 04 September 2017 22:01 i'de like to create a scene where when i close a door with xiaomi door sensor one light is on and when the door is open light is off.
how i can i make it possible??
thank you
Events -> Lua, device:
if (devicechanged['Door'] == 'Closed' and otherdevices['Xiaomi RGB Gateway'] == 'Off') then
    commandArray['Xiaomi RGB Gateway']='On'
elseif (devicechanged['Door'] == 'Open' and otherdevices['Xiaomi RGB Gateway'] == 'On') then
    commandArray['Xiaomi RGB Gateway']='Off'
matteos1
Post by matteos1 »
chatainsim wrote: Tuesday 05 September 2017 15:39
thank you
hy thank you
could see this picture and transform in lua?
chatainsim
matteos1 wrote: Tuesday 05 September 2017 16:38
thank you
hy thank you
It's too small to read text.
deennoo
Post by deennoo »
Have a look to https://github.com/rytilahti/python-mirobo
That tje n'est python lib to drive Xiaomi wifi device, dev are working hard and add new device/function every day. I manage to drive my Xiaomi Philips ball led with this.
Python plugin for robot vaccum use the same lib (an older version) his way to run looks the best one, just need to be adapted for other device.
http://domo-attitude.fr
matteos1
Post by matteos1 »
i think is better
chatainsim wrote: Tuesday 05 September 2017 17:14
hy thank you
chatainsim
matteos1 wrote: Tuesday 05 September 2017 19:18 Cattura.PNG
i think is better
hy thank you
why don't you try to translate to lua then ask for help if you are stuck ?
matteos1
Post by matteos1 »
Ok
LeonvA
Post by LeonvA »
deennoo wrote: Monday 04 September 2017 17:15
LeonvA wrote:Hello,
I have bought a Xiaomi gateway in China last week but it doesn't connect to Domoticz.
I can control the gateway and read the status of my temperature sensor in the Mi Home app.
I've enabled LAN Communication protocol in the Mi Home app and wrote down the password.
Then I added the new hardware in Domoticz with correct IP address, port 9898 and the correct password.
But then I can't see any new devices in the devices tab.
I've also tried it on a new installed raspberry pi with domoticz on a stand alone network but also no result.
anyone who can help me?
Thanks,
Leon
What is you Fw version please ?
I've got it to work.
I used an older version of the mi home app and now it works.
chatainsim
matteos1 wrote: Wednesday 06 September 2017 10:01Ok
It's not because I don't want to help, It's because it's the best way you to learn lua :)
I'
matteos1
Post by matteos1 »
I'
Yes i know but only this time Image
ratjenl
Post by ratjenl »
Well i finally received my Xiaomi gateway and added it to domoticz.
I also ordered two door/windows sensors to use it as an alarm. With the mii home app it works very well and when i put the alarm "on" it immediatly plays sound from the gateway. Is there also a way to use these sensors inside domoticz so they send the alarm to the gateway ? I tried searching google and this forum but can't find what i am looking for. Is there anybody that can help me/point me in the good direction ?
thnx
pvm
Domoticz version: 4.10538
Post by pvm »
ratjenl
Do you have these devices available in Domoticz? Then you should be able to play a sound using blockly, some instructions on https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Did you see those? Does that help you?
Wob76
Post by Wob76 »
I just added a few zigbee power sockets to my setup, they are working fine and reporting power, on my utility graph I only see power usage and energy usage, apart from an odd "spike" on energy usage it seems to report "0", is anyone else experiencing this?
Wob76
Post by Wob76 »
I just did a test with it set to "computed" and I now see results in the "Energy Usage", is it possible to have these devices set to computed when they are created by the plugin?
Stanleyk
Post by Stanleyk »
I add yesterday xiaomi home to domoticz and working well. I have gateway, 5xdoor contact, 1xbutton, 2x motion sensor. and also 2x IR transmitter but this I dont see in domoticz. have anybody this working ? In MiHome aplication is working TV, AC, HomeTeather. But MiHome fo IR is in Chinese language :-(
I am waiting for wall switches, light bulb and thermometers.
How I can control the classic lights ? Have somebody any relays what is definitely working (433 or wifi) ?
DannyElfman
Domoticz version: 3.8136
Post by DannyElfman »
Does anybody know if the Xiaomi Aqara flood sensors are working with one of the latest Domoticz beta build ?
I cannot find anything on github ( https://github.com/domoticz/domoticz/co ... ateway.cpp )
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
Coldman
Post by Coldman »
DannyElfman wrote: Thursday 07 September 2017 10:02 Hi,
corbin wrote: Sunday 03 September 2017 11:30
Martins80 wrote: Saturday 02 September 2017 13:44
marcotini wrote: Saturday 02 September 2017 8:45 I don't know if there is one in Domoticz. It's just a water presence so I think that just 1 or 0 it's ok lol.
I think there is support for smoke alarm and gas alarm, i think this is the same, but water alarm
I could add it the same as the smoke alarm no problem, but hoping someone can suggest a more appropriate device.
