Milight - RFlink
poudenes
Domoticz version: 3.8993
Milight - RFlink
Post by poudenes »
Hi All,
Using Milights with the Milight box. Now have the module to control them using RFLink.
Everything is working but i see some difference between de options:
1) Using Milight Box the lamps also have Kelvin options.
2) Using Milight and RFlink the Kelvin option is gone.
3) Sending command to the lamp to dim them in dzVents it won't work (Maybe because of the missing Kelvin)
4) The lamps are all in Switch Type Dimmer. You can change brightness in device thats working but not in dzVents
Have someone same issues?
domoticzag
Re: Milight - RFlink
Post by domoticzag »
poudenes wrote: Saturday 27 January 2018 18:04 Hi All,
I have the exact same isseus, this way, rflink is not workable for RGB+CCT for me. Is there a solution to this?
I bought the NFR module to replace the Milight Ibox v3
Last edited by domoticzag on Thursday 01 February 2018 19:51, edited 1 time in total.
RPi 3
Domoticz Béta
RFLink Gateway dipool antenna
Many kaku devices
P1 smart meter
Custom made ESP8266 devices
Hue lights / Milight ligts and strips
Stuntteam
Post by Stuntteam »
Whats dzVents or what can I do to get an idea of how Kelvin is used?
poudenes
Post by poudenes »
Stuntteam wrote: Thursday 01 February 2018 19:48 Whats dzVents or what can I do to get an idea of how Kelvin is used?
dzVents is easy scripting same as LUA. See Wiki: http://www.domoticz.com/wiki/DzVents:_n ... _scripting
Here a example of my dzVents script:
behind the scenes the dzVents system have many action to activate the action within Domoticz and its devices.
(Danny correct me if i'm wrong)
local Version               = '18.01.24'
local MasterBedroomSwitch	= 90
local MasterBedroom		    = 7
    active = true,
        devices = {MasterBedroomSwitch},
    logging = {marker = 'SLAAPKAMER Switch ' ..Version..'......'},
    if
    domoticz.devices(MasterBedroomSwitch).state == 'On'
    then
        domoticz.devices(MasterBedroom).dimTo(100)
        domoticz.devices(MasterBedroom).setKelvin(5000)
        domoticz.log('--------------------------------------------------------------', domoticz.LOG_FORCE)
        domoticz.log('-------------------==<[ SLAAPKAMER AAN ]>==-------------------', domoticz.LOG_FORCE)
    elseif
    domoticz.devices(MasterBedroomSwitch).state == 'Off'
    then
        domoticz.devices(MasterBedroom).dimTo(5)
        domoticz.devices(MasterBedroom).switchOff().afterSec(1)
        domoticz.log('-------------------==<[ SLAAPKAMER UIT ]>==-------------------', domoticz.LOG_FORCE)
domoticzag
poudenes wrote: Thursday 01 February 2018 20:31
    active = true,
    if
    then
    elseif
    then
Your understanding us wrong i think.
I mean with original Milight Bridge I get this for RGB CCT lamps:
With the RFLINK I only get these options:
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
domoticzag
    active = true,
    if
    then
    elseif
    then
This is the result of the following script, any idea why kelvin isnt working?
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
poudenes
Post by poudenes »
Because i run latest beta with dzVents 2.4.0 version
domoticzag wrote: Friday 02 February 2018 18:15
    active = true,
    if
    then
    elseif
    then
poudenes
Post by poudenes »
Correct. I have same difference with the devices. The Kelvin is missing.
domoticzag wrote: Friday 02 February 2018 18:05
    active = true,
    if
    then
    elseif
    then
poudenes
Post by poudenes »
But can we look to this and do some tests? And see if we can solve this?
rolo84
Domoticz version: 4.10298
Post by rolo84 »
Is there any update on this?
I just bought a FUT014 RGB+CCT lamp.
It successfully paired with Domoticz, but it is recognized as a RGBW lamp, not an RGBWW lamp.
poudenes
Post by poudenes »
rolo84 wrote:Is there any update on this?
I don't know. I'm using now a self build milight hub where I can create unlimited virtual remotes and groups. So everything work great here now for months
Verzonden vanaf mijn iPhone met Tapatalk Pro
rolo84
Post by rolo84 »
What do you need to build a own hub?
Is there some tutorial online?
poudenes
Post by poudenes »
rolo84 wrote:What do you need to build a own hub?
https://blog.christophermullins.com/201 ... n-esp8266/
Here you are!
rolo84
Post by rolo84 »
Thanks, so I build it :)
Everything is working, except the UDP connection to domoticz.
I can see the group, but not the individual lights. How can I add them in domoticz.
CV8R
Post by CV8R »
Same issue here - means I had to go box the ibox2 wifi controller.
CV8R
poudenes
Post by poudenes »
rolo84 wrote:Thanks, so I build it :)
You can't. Light are add in groups. What I did create many remotes so I add every light in its own group. So.yiu add more milight hubs into domoticz. Then you can control every light individual
Baliku
Domoticz version: Stable
Post by Baliku »
Hi everybody,
I'm a bit deseperate to control RGBWW/CCT with rflink
When I folow the C procedure of Rflink faq to pair and create RGBCCT light, domoticz create a RGBW subtype device.
For this RGBCCT products we need to use controls of the RGBWWZ subtype device.
So I've changed in SQL the subtype of this device directly in database, I've tried everything : RGB, RGBW, RGBWZ, RGBWW and RGBWWZ but no one can control correctly the RGBCCT milight bulb.
Color and ON/Off features are OK in all case, but dimming, saturation and temperature have heratics comportments or simply doesn't work.
It be a couple of months that I try to control RGBCCT in domoticz through rflink and even with the new domoticz version nothing works.
If devellopers need a beta tester I am OK for that, MP me.
Else, somebody knows how to control rflink with a dummy device to send commands like 10;MiLightv1;XXXXXX;04;0000;MODE4; ?
Many thanks.
Best regards.
NAS Syno, Last Stable Ver°
RFLink 433.92+NRF24L01 : 6 THN132N, 5 KIT_FP433TEMP / ++MiLights / ++DI-O
HarmonyHub : FreeRev, TV LG, Amp Sony
Cabasse StreamAmp100, 3 Awox StriimLightWifi
KLF200 : 5 Somfy IO
IFTTT : GoogleAgenda
Blockly, DzVents, Bash
Tasker
