maramazza
Post by maramazza »
Hi to all,
is there a tag / card reader integrable in domoticz?
Thanks!!
DAVIZINHO
Post by DAVIZINHO »
hello.
the aqara water sensor is not availabe yet??
i have the v3.8153 stable of domoticz
Mace
Domoticz version: 3.8153
Post by Mace »
I've got some troubles with the Gateway: Somehow, once every while, the 'Lux' stops functioning. As I have a script running that triggers lights based upon the Lux amount, this results in a diminishing WAF factor....;)
Anybody recognizes this?
Also searching for extra Lux sensors, but can't seem to find them (just the 'Klik-aan-Klik-uit' version)
tho071088
Domoticz version: Stable
Post by tho071088 »
DAVIZINHO wrote: Friday 29 September 2017 11:27 hello.
Same question for me, using the dev version of Domoticz
They have a special price on Gearbest today :D : https://www.gearbest.com/home-smart-imp ... 68897.html
Not found on this list : https://www.domoticz.com/wiki/Xiaomi_Ga ... le_Devices
Last edited by tho071088 on Tuesday 03 October 2017 16:01, edited 1 time in total.
Domoticz Beta on Rasbperry Pi 3
RFLink / YeeLight / Xiaomi Devices / 433MHz / SonOff via MQTT
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
tho071088 wrote: Tuesday 03 October 2017 11:13
They have a special price on Gearbest today :D : https://www.gearbest.com/home-smart-imp ... ?lkid=XXXX
Please remove your lkid from the link on this forum !
tho071088
Post by tho071088 »
chatainsim wrote: Tuesday 03 October 2017 15:53
Sorry, I did not pay attention, link edited :oops:
fabiotodesco
Post by fabiotodesco »
Imagehi, sorry if i have a old question, but i not can add gateway in domoticz...i have all port open but the reponse of domoticz is
XiaomiGateway: will listen on 9898 for hardware id 4
XiaomiGateway: Delaying worker startup...
XiaomiGateway: Worker started...
domoticz is install in windows 2012R2 server on my pc at office. The pc is connected in LAN (cabled). In to the pc if i ping the gtw it respond. I have test udp port with packet sender and the risult is attached.
Can you help me? i have reinstall the app to the my Android phone but nothing, nothing seems to work
chatainsim
tho071088 wrote: Tuesday 03 October 2017 16:03
timh1004
Post by timh1004 »
Mace wrote: Tuesday 03 October 2017 8:50 I've got some troubles with the Gateway: Somehow, once every while, the 'Lux' stops functioning. As I have a script running that triggers lights based upon the Lux amount, this results in a diminishing WAF factor....;)
I have exactly the same issue with the Lux sensor of the gateway! In theory, it works very well, but in my case, it stops working every night and is then offline for 12h or so.
The second generation of the motion sensor (now also under the Aqara branding) has an build in Lux sensor, but this sensor is very inaccurate and therefore not usable.
So I‘m also searching for an accurate and reliable Lux sensor.
tho071088
Post by tho071088 »
timh1004 wrote: Tuesday 03 October 2017 22:08
Maybe with Mi Flora ? It does have a Lux sensor.
For outside I'm using weatherunderground API.
timh1004
Post by timh1004 »
tho071088 wrote: Tuesday 03 October 2017 22:15
Great recommendations! Thank you!
corbin
Post by corbin »
fabiotodesco wrote: Tuesday 03 October 2017 16:12 Imagehi, sorry if i have a old question, but i not can add gateway in domoticz...i have all port open but the reponse of domoticz is
To test this, you should be sending to the multicast address 224.0.0.50, not 192.168.134.250. I'm guessing you tried that first but changed to the actual device IP because the multicast address wasn't working, and if that is the case it is probably your Windows firewall blocking it, or your router/network configuration not working with multicast.
Mace
Post by Mace »
timh1004 wrote: Tuesday 03 October 2017 22:08 The second generation of the motion sensor (now also under the Aqara branding) has an build in Lux sensor, but this sensor is very inaccurate and therefore not usable.
Do you have some more info/reviews on this? Seems to be the only viable option so far...
corbin
Post by corbin »
Yes it needs to be the dev/beta version. Are you getting an 'Unknown' message in the logs, if the device is not detecting, and isn't coming up as unknown it may not be supported in the firmware yet. I don't have one to test and just copied "sensor_wleak.aq1" as the device model from another project.
fabiotodesco
corbin wrote: Wednesday 04 October 2017 11:11
HI, thanks for te answer but the firewalll of windows is disable, but i have a mikrotik firewall thath control the network. i don't understand this multicast story can you explain me?
Thanks a lot
Luigi87
Post by Luigi87 »
corbin wrote: Wednesday 04 October 2017 11:18
Is there a way to add only file with support for the water sensor?
(i have done this before with .xml file for open z-wave, to get support on other devices)
I dont like to update my system to the Beta... ( i am now running the latest Stable)
chatainsim
If I understand correctly, you send order to the gateway through multicast ?
That's why when I have my second gateway turned on I have errors messages telling my that the key isn't correct ?
The second gateway isn't configured in Domoticz.
Is there a way to not have anwser from the second gateway ?
sdujolo
Post by sdujolo »
I also have problem with lux sensor of the gateway. Before i was controlling lights with that sensor now it´s not working. The sensor in gateway is very good the one in 6in1 sensor from Aeotec is terrible. I don´t know if is becasue for new domoticz version or firmware in gateway. All other sensor is working.
corbin
Post by corbin »
chatainsim wrote: Thursday 05 October 2017 10:21 If I understand correctly, you send order to the gateway through multicast ?
Commands are not sent multicast, they are sent direct to the IP of the gateway. Multiple gateways should make no difference to this, regardless of if the additional gateway is configured in Domoticz. The correct key should be returned by matching the IP address of the gateway you have configured in Domoticz, so don't know why you are having this problem.
corbin
Post by corbin »
fabiotodesco wrote: Wednesday 04 October 2017 13:22 HI, thanks for te answer but the firewalll of windows is disable, but i have a mikrotik firewall thath control the network. i don't understand this multicast story can you explain me?
Thanks a lot
Can't help you specifically with your hardware, but you can test on your windows pc by running wireshark and see if the UDP packets are visible on your network. Example of a UDP packet when clicking a Xiaomi button:
