Aurora theme
rhendriks
Domoticz version: Newest
Re: Aurora theme
Post by rhendriks »
* When I change the size of the tab then I have 3 colums , if I change the tab to full screen then I have 2 colums.
what is wrong here.
*The camera pop-up is a to small.
blauwebuis
Domoticz version: current
Re: Aurora theme
Post by blauwebuis »
@jochem: For now I won't do version numbers. If people have issues, the first thing they should do is upgrade to the latest version. Since a theme is just CSS and Javascript there is no risk to your system in upgrading.
blauwebuis
Re: Aurora theme
A new version has been uploaded that should fix the bugs.
FIXES
- sometimes an empty right column when using vertical columns.
- dataviz doesn't re-scale when the page does
- webcam popup too small
IMPROVEMENTS
- bigger setpoint buttons everywhere
- mobile design on dashboard is more in line with the rest of the theme.
QUESTIONS
- how are remote control popups now? The grey issue is hopefully fixed.
bdormael
Re: Aurora theme
Post by bdormael »
blauwebuis wrote: Tuesday 16 January 2018 12:41 A new version has been uploaded that should fix the bugs.
FIXES
IMPROVEMENTS
QUESTIONS
Almost perfect for me now, thx :-)
One small issue I still see, when the title is too long for a sensor, it overlaps with the value on the temperature tab, can't the values be put on another line like on the dashboard ?
zak45
Domoticz version: V2024.4
Re: Aurora theme
Post by zak45 »
blauwebuis wrote: Tuesday 16 January 2018 12:41 QUESTIONS
So .. not so good:
bdormael
Aurora theme
Post by bdormael »
Another small issue on my iPad, thermostat buttons are overlapping the title when having a long title, maybe adding more space between the title and the buttons ?
Same for other titles which are too long.
rhendriks
Re: Aurora theme
Post by rhendriks »
If I view in Google Chrome ,the site looks perfect.
In Edge I cannot change something , If I change it's looks good but if I save it looks as before.
If I change in Edge and I look in chrome then It's changed.
If I delete the cache from Edge it has no effect.
jake
Re: Aurora theme
Post by jake »
bdormael wrote:Another small issue on my iPad, thermostat buttons are overlapping the title when having a long title, maybe adding more space between the title and the buttons ?
A very reasonable question.
Another way of thinking to solve your issue is: do you need the word thermostat in the title? The combination of icon and up down already implies a thermostat function.
I use dashticz and deleted quite some of these 'over logic' words, like 'living room lights' -> 'living room' since there was already a lightbulb icon besides it.
BarryT
Domoticz version: 2024.3
Re: Aurora theme
Post by BarryT »
Like! :D
blauwebuis
Re: Aurora theme
I've uploaded a new version. It should hopefully fix the remote control display (I can't test these myself unfortunately). And it fixes a bug where it doesn't store the theme settings if there are no user variables already.
@rhendriks: can you
- upgrade to the latest version
- clear browser and application cache
- then look in the console and Edge and check if you have any error messages? (right mouse button on the page -> inspect element -> console)
@bdormael: make your names less long :-) The HTML output of Domoticz only allows me to do so much.
piokuc
Re: Aurora theme
Post by piokuc »
I see that PR #2056 (https://github.com/domoticz/domoticz/pull/2056) are mered but icon form mobile devices is still the same.
zak45
Re: Aurora theme
Post by zak45 »
Remote control still the same :-(
rhendriks
Re: Aurora theme
Post by rhendriks »
It's look like the page is no longer load the theme , other theme works
blauwebuis wrote: Thursday 18 January 2018 11:18 I've uploaded a new version. It should hopefully fix the remote control display (I can't test these myself unfortunately). And it fixes a bug where it doesn't store the theme settings if there are no user variables already.
@rhendriks: can you
This is the answer:
Fouten
 HTTP404: NIET GEVONDEN - De server heeft niets gevonden dat overeenkomt met de aangevraagde URI (Uniform Resource Identifier).
GET - http://192.168.1.15:8080/acttheme/custom.css
GET - http://192.168.1.15:8080/acttheme/custom.js
 SCRIPT1002: SCRIPT1002: Syntax error
waarschuwingen
 SEC7113: CSS is genegeerd vanwege een niet-overeenkomend MIME-type
 HTML1500: De tag kan geen zichzelf sluitende tag zijn. Gebruik een expliciete afsluitende tag.
HTML1300: Er heeft navigatie plaatsgevonden.
192.168.1.15:8080 (1,1)
 AppCache maken met manifest: http://192.168.1.15:8080/html5.appcache.
 CSS3121: De mediaquery -ms-viewport is afgeschaft.
SCRIPT7016: SCRIPT7016: Gebruik van XMLHttpRequest waarvoor de synchrone vlag is ingesteld op waar, is afgewezen vanwege de impact ervan op de door de gebruiker ervaren site-prestaties.
blauwebuis
Re: Aurora theme
@rhendriks: thanks for the detailed response!
- This was interesting:
https://stackoverflow.com/questions/164 ... l-files-no
Some questions:
- Did you install the theme by copying it to a Pi from Windows? Perhaps then it's a permissions problem.
- Does this only happen on Internet Explorer, or also other browsers?
bdormael
Re: Aurora theme
Post by bdormael »
Shortened my names (was a lot of work because they are all used in dzvents scripts), so all is ok now.
I also combined my thermostat with my temperature sensors into one so eg. "Living - Temperature" & "Living - Thermostat", some of my Temperature sensors have temperature & humidity in it, then the combination of Temp & Therm does not work, they keep seperated.
So to summarise:
1 sensor : "Living - Temperature" which is temp & humidity
1 sensor : "Living - Thermostat"
Will not show up as 1 combined block because the temperature has 2 values and it looks like it doesn't know which one to take to show.
When adding a switch in that same combination (eg. "Living - My Switch") which comes alphabetically before the temp sensor, then it works fine.
Request :
- I'm using vertical columns enabled, but by combining temp with therm sensors, the third columns is empty now, cant' we hide this column if there are no sensors to show so the other sensors are stretched out ?
rhendriks
Re: Aurora theme
Post by rhendriks »
blauwebuis wrote: Friday 19 January 2018 11:47 @rhendriks: thanks for the detailed response!
Some questions:
-I copied the files with Winscp .
-It's now happen with all the Edge and Chrome.
I think it's weird because the first time I instal the aurora theme it works fine .
If I use other themes they work .
blauwebuis
Re: Aurora theme
@rhendriks: I suspect it's a permissions problem. The pi won't serve the files from the theme. Those two files are the (custom.css and custom.js) are the core starting file for any theme.
To fix it, delete the folder, and download the theme from on the pi itself.
Or change the permissions of the files (chmod).
@bdormael: As you can read on the settings page, the merging option only merges 'simple' items. Items with more than one output, or items with buttons and sliders, they are not merged.
The option to merge temperature and weather is designed to remove a vertical column, so that the vertical columns feature can work on smaller screens. It does not leave behind an 'empty' column. So I wonder what is going on.
htilburgs
Aurora theme - Events page
Post by htilburgs »
Nice to see that the theme is published and making a lot of progress.
I've an issue with the events page. I don't like the main menu or the settings menu as a sidebar, so I switched this option off.
When I go to my Events page, to create or edit events, the top part of the screen is 'hidden' under the main menu.
Can this be corrected?
Aurora - Events.png (56.88 KiB) Viewed 5115 times
Hardware:
bdormael
Re: Aurora theme
Post by bdormael »
blauwebuis wrote: The option to merge temperature and weather is designed to remove a vertical column, so that the vertical columns feature can work on smaller screens. It does not leave behind an 'empty' column. So I wonder what is going on.
I have no weather sensors and the tab weather is also not enabled. What I mean is to hide the utility column as my thermostats are merged with temperature, now it still shows the utility column without anything in there
Verzonden vanaf mijn iPad met Tapatalk
rhendriks
Re: Aurora theme
Post by rhendriks »
blauwebuis wrote: Saturday 20 January 2018 10:34 @rhendriks: I suspect it's a permissions problem. The pi won't serve the files from the theme. Those two files are the (custom.css and custom.js) are the core starting file for any theme.
I delete the folder in "styles" , download the theme again and it's working.
Maybe the new download is the solution.
I have now only the problem with the two colums instead of tree.
