Ikea Ansluta remote (2.4GHz)
Hesmink
Post by Hesmink »
I'm considering to use Ikea kitchen lighting.
This can be remote controlled by the Ansluta remote, working on 2.4GHz. http://www.ikea.com/us/en/catalog/products/80288328/
Does anyone have any experience with controlling this from Domoticz?
ThinkPad
Re: Ikea Ansluta remote (2.4GHz)
Post by ThinkPad »
Maybe with the RFLink project. It has a nRF24L01+ transceiver on board for 2,4Ghz communications.
But it is not used yet in the code of the RFLink.
Hesmink
Post by Hesmink »
ThinkPad wrote:Maybe with the RFLink project. It has a nRF24L01+ transceiver on board for 2,4Ghz communications.
That would be nice, and if implemented, for me a reason to buy one.
Hesmink
Post by Hesmink »
Is this already available?
I ordered an RFLink, but are still waiting for the rest I need from China.
Stuntteam
Post by Stuntteam »
Indeed this is now working in the RFLink lab.. both receive and transmit.
Hesmink
Post by Hesmink »
Very good news!
Derik
Post by Derik »
mmm
Perhaps you can tell me what hardware is working in the lab....
When i am @ Ikea can i order some hardware....
Great job
Stuntteam
Post by Stuntteam »
See the wiring page on www.nemcon.nl/blog2
Near the bottom it shows 3 working CC2500 modules...
Derik
Post by Derik »
mm looking Fu#%^&$%cking great....
I do have a "RFlink Gateway Gesoldeerd " v.1.1
Do i need to make modifications?
Or can i use all the new stuff?
Stuntteam
Post by Stuntteam »
You need to add the CC2500 and since that one does not like the 5 volt signals you also need to add a level shifter inbteween the signals.
Like these: https://nl.aliexpress.com/item/5PCS-IIC ... 21005.html
Hesmink
Post by Hesmink »
Stuntteam wrote:You need to add the CC2500 and since that one does not like the 5 volt signals you also need to add a level shifter inbteween the signals.
I have a 433Mhz RFLink per-soldered and a NRF24L01 on top of it.
I was under the impression the NRF24L01 was also a 2.4GHz tranceiver?
Stuntteam
Post by Stuntteam »
Yes, the NRF24 is also 2.4 Ghz but can not handle the modulation required for the additional devices..
We will soon also be adding support for the CC1101 - 868 mhz transceiver
Hesmink
Post by Hesmink »
Stuntteam wrote:Yes, the NRF24 is also 2.4 Ghz but can not handle the modulation required for the additional devices..
Ok.
Is there a solderless solution I can plug in the existing board?
Hesmink
Post by Hesmink »
Well, I have a working RFLink (without CC2500 though) and some Ansluta stuff, so I'm ready to try it out as soon as it's available.
(And hopefully doable without much soldering).
Derik
Post by Derik »
@ Stuntteam,
Please can you ad some more details.
i do not understand what i need to solder and the diff rents between NRF24 for Ikea and the NRF24 for the Milight..?
Example what is my NRF24 now for?
Stuntteam
Post by Stuntteam »
RFlink is modular.. this means you can hook various transceivers to the mega and use their different abilities.
Milight communication is done using a NRF24L01.
Ikea Ansluta communication is done with a CC2500 transceiver. The reason that it does not work with the NRF as well is because a different form of modulation is used, modulations is the way 2 sides talk to eachother..
Btje
Re: RE: Re: Ikea Ansluta remote (2.4GHz)
Post by Btje »
I see that the cc1101 is also capable of 433 mhz. Will this mean that we don't need the default tranceiver anymore.
I ordered a cc in advance for my ws4000 weather station.
Verstuurd vanaf mijn SM-G920F met Tapatalk
Stuntteam
Post by Stuntteam »
No, although the chip itself can handle multiple frequencies, the modules that contain the cc1101 have additional hardware that limits the frequency.
For now we are working on the 868 mhz version to add support for various devices that are so far unsupported..
Btje
Post by Btje »
I ordered this module:
https://nl.aliexpress.com/item/CC1101-W ... bff814a668
It states more freq. Bit confusing. I understand that the RF part in some cases would need to change.
Btje
Post by Btje »
Users browsing this forum: suhanidash557 and 1 guest
