Ikea Ansluta remote (2.4GHz)
Hesmink
I'm considering to use Ikea kitchen lighting.
This can be remote controlled by the Ansluta remote, working on 2.4GHz. http://www.ikea.com/us/en/catalog/products/80288328/
Does anyone have any experience with controlling this from Domoticz?
ThinkPad
Re: Ikea Ansluta remote (2.4GHz)
Maybe with the RFLink project. It has a nRF24L01+ transceiver on board for 2,4Ghz communications.
But it is not used yet in the code of the RFLink.
Hesmink
That would be nice, and if implemented, for me a reason to buy one.ThinkPad wrote:Maybe with the RFLink project. It has a nRF24L01+ transceiver on board for 2,4Ghz communications.
Hesmink
Is this already available?ThinkPad wrote:Maybe with the RFLink project. It has a nRF24L01+ transceiver on board for 2,4Ghz communications.
I ordered an RFLink, but are still waiting for the rest I need from China.
- Stuntteam
Indeed this is now working in the RFLink lab.. both receive and transmit.
Hesmink
Very good news!
Derik
- Domoticz version: BETA
mmm
Perhaps you can tell me what hardware is working in the lab....
When i am @ Ikea can i order some hardware....
Great job
Great job
- Stuntteam
See the wiring page on www.nemcon.nl/blog2
Near the bottom it shows 3 working CC2500 modules...
Derik
mm looking Fu#%^&$%cking great....
I do have a "RFlink Gateway Gesoldeerd " v.1.1 Do i need to make modifications?
Or can i use all the new stuff?
- Stuntteam
You need to add the CC2500 and since that one does not like the 5 volt signals you also need to add a level shifter inbteween the signals.
Like these: https://nl.aliexpress.com/item/5PCS-IIC ... 21005.html
Hesmink
I have a 433Mhz RFLink per-soldered and a NRF24L01 on top of it.Stuntteam wrote:You need to add the CC2500 and since that one does not like the 5 volt signals you also need to add a level shifter inbteween the signals.
I was under the impression the NRF24L01 was also a 2.4GHz tranceiver?
- Stuntteam
Yes, the NRF24 is also 2.4 Ghz but can not handle the modulation required for the additional devices..
We will soon also be adding support for the CC1101 - 868 mhz transceiver
Hesmink
Ok.Stuntteam wrote:Yes, the NRF24 is also 2.4 Ghz but can not handle the modulation required for the additional devices..
Is there a solderless solution I can plug in the existing board?
Hesmink
Well, I have a working RFLink (without CC2500 though) and some Ansluta stuff, so I'm ready to try it out as soon as it's available.
(And hopefully doable without much soldering).
Derik
@ Stuntteam,
Please can you ad some more details.
i do not understand what i need to solder and the diff rents between NRF24 for Ikea and the NRF24 for the Milight..?
Example what is my NRF24 now for?
- Stuntteam
RFlink is modular.. this means you can hook various transceivers to the mega and use their different abilities.
Milight communication is done using a NRF24L01.
Ikea Ansluta communication is done with a CC2500 transceiver. The reason that it does not work with the NRF as well is because a different form of modulation is used, modulations is the way 2 sides talk to eachother..
Btje
Re: RE: Re: Ikea Ansluta remote (2.4GHz)
I see that the cc1101 is also capable of 433 mhz. Will this mean that we don't need the default tranceiver anymore.Stuntteam wrote:Yes, the NRF24 is also 2.4 Ghz but can not handle the modulation required for the additional devices..
I ordered a cc in advance for my ws4000 weather station.
Verstuurd vanaf mijn SM-G920F met Tapatalk
- Stuntteam
No, although the chip itself can handle multiple frequencies, the modules that contain the cc1101 have additional hardware that limits the frequency.
For now we are working on the 868 mhz version to add support for various devices that are so far unsupported..
Btje
I ordered this module:
https://nl.aliexpress.com/item/CC1101-W ... bff814a668
It states more freq. Bit confusing. I understand that the RF part in some cases would need to change.
