MyDomoticz - Testers wanted!
dakipro
- Domoticz version: 3.5877
Re: Testers wanted!
mine is still red unfortunately
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
Re: Testers wanted!
Was the mine to.
Enabled shared apps then u get green perhaps
- Minglarn
- Domoticz version: v3.8153
Re: Testers wanted!
Mine is dead too. It works well for about 30min and then it disconnects.
It could be Domoticz who have issues but I'm not sure.
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
Re: Testers wanted!
Here it still works
woody4165
Re: Testers wanted!
Mine it's working too, but I cannot display device values in frontpage.html if I go to https://my.domoticz.com/my/xxxxxxxx/frontpage.html.
In the dashboard all is ok.
Re: Testers wanted!
When i go to frontpage.html i het offline.
At the settings of domoticz at my.domoticz is apps enabeld?
woody4165
Re: Testers wanted!
Apps were not enabled.spikehome wrote:When i go to frontpage.html i het offline.
Now I have enabled, rebooted (just in case), but still no values...
Re: Testers wanted!
When u login at my.domoticz the man is nog green?
It also takes a few minutes so far i found out.
And with apps disabeld it was nog working with me.
woody4165
Re: Testers wanted!
The man in the my.domoticz, after logging in, is green.
Then I get request for user login, I have defined users, and I login with the admin user that have access to everything and every devices.
In dashboard all ok, in frontpage no.
Apps are allowed now.
woody4165
Re: Testers wanted!
Now it's not working... Just the commodore 64 page.
woody4165
Re: Testers wanted!
I'm still getting no values for devices.woody4165 wrote:The man in the my.domoticz, after logging in, is green.
It's the same if I go thru ddns.
Apps are enabled.
Any suggestion?
dakipro
Re: Testers wanted!
Still doesn't work for me, little guy is red after logging in.spikehome wrote:Was the mine to.
I then tried to "revoke the system" and enter data again, now my system is not appearing on my.domoticz.com. I tried restarting it few times, entering and saving API key and pass, still nothing.
I do not have 2steps verification.
dakipro
Re: Testers wanted!
and after few restarts now the green guy is back and remote control works fine. Life is worth living again...
codesnipper
Re: Testers wanted!
Problem with frontpage - in my domoticz is FlatZ - is that frontpage is operating on local IP and you call it from outside network.
In www/settings/settings.js i changet this:
into this:
Now it works, but if there isn't connection with MyDomoticz, local addres of frontpage won't work.
$.domoticzurl = "http://XXX.XXX.XXX.XXX:8080"Code: Select all
$.domoticzurl = "https://my.domoticz.com/my/A48BD36E8ECA577"- chimit
- Domoticz version: master
Re: Testers wanted!
Not sure what you want to accomplish. But you shouldn't be having to change anything in the sources files.codesnipper wrote:Problem with frontpage - in my domoticz is FlatZ - is that frontpage is operating on local IP and you call it from outside network.
into this:Code: Select all
Now it works, but if there isn't connection with MyDomoticz, local addres of frontpage won't work.Code: Select all
codesnipper
Re: Testers wanted!
It is not source file - it's file with settings for FlatZ frontpage. You have to edit it when you install this frontpage.
Gravityz
- Domoticz version: 2025.1
Re: Testers wanted!
i just voluntered for my Domoticz and i must say it works right out of the box.
on an iphone safari is not keeping track of username and password(forgot auto fill in)
i however use ewallet where i can put everything which passes it along to the mydomoticz page.
2 clicks and i am in.
responsetimes are really faster then when i use the philips hue app the same way.
with HUe it takes 5-6 seconds before lights react.
wit mydomoticz it takes 1 second.
nice work.
my setup
Synology 112+
DSM 6
domoticz 5019
nice work.
my setup
Synology 112+
DSM 6
domoticz 5019
- chimit
Re: Testers wanted!
Update: Just edited the Wiki at https://www.domoticz.com/wiki/MyDomoticz. The alpha phase is over for a while already. Now we reached Beta status.
We are almost reaching 300 Domoticz's online simultaneously at the moment.
codesnipper
Re: Testers wanted!
After sucesfull start I have errors (11 minutes from start):
2016-04-02 15:44:17.530 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-04-02 15:44:59.024 Error: PROXY: Handshake failed, reconnecting: short read
Gravityz
Re: Testers wanted!
i have the same.
i think sometimes mydomoitcz looses connection.
connection is up most of the time(green) so no problems here
2016-04-02 23:53:21.526 Error: PROXY: timeout occurred, reconnecting
2016-04-02 23:53:21.526 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-04-02 23:54:43.546 Error: PROXY: Connect failed, reconnecting: Connection timed out
2016-04-03 07:35:57.264 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
