MyDomoticz - Testers wanted!
dakipro
Domoticz version: 3.5877
Re: Testers wanted!
Post by dakipro »
mine is still red unfortunately :(
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
spikehome
Re: Testers wanted!
Post by spikehome »
Was the mine to.
Enabled shared apps then u get green perhaps
Minglarn
Domoticz version: v3.8153
Re: Testers wanted!
Post by Minglarn »
Mine is dead too. It works well for about 30min and then it disconnects.
It could be Domoticz who have issues but I'm not sure.
spikehome
Re: Testers wanted!
Post by spikehome »
Here it still works
woody4165
Re: Testers wanted!
Post by woody4165 »
Mine it's working too, but I cannot display device values in frontpage.html if I go to https://my.domoticz.com/my/xxxxxxxx/frontpage.html.
In the dashboard all is ok.
spikehome
Re: Testers wanted!
Post by spikehome »
When i go to frontpage.html i het offline.
At the settings of domoticz at my.domoticz is apps enabeld?
woody4165
Re: Testers wanted!
Post by woody4165 »
spikehome wrote:When i go to frontpage.html i het offline.
Apps were not enabled.
Now I have enabled, rebooted (just in case), but still no values...
spikehome
Re: Testers wanted!
Post by spikehome »
When u login at my.domoticz the man is nog green?
It also takes a few minutes so far i found out.
And with apps disabeld it was nog working with me.
woody4165
Re: Testers wanted!
Post by woody4165 »
The man in the my.domoticz, after logging in, is green.
Then I get request for user login, I have defined users, and I login with the admin user that have access to everything and every devices.
In dashboard all ok, in frontpage no.
Apps are allowed now.
woody4165
Re: Testers wanted!
Post by woody4165 »
Now it's not working... Just the commodore 64 page.
woody4165
Re: Testers wanted!
Post by woody4165 »
woody4165 wrote:The man in the my.domoticz, after logging in, is green.
I'm still getting no values for devices.
It's the same if I go thru ddns.
Apps are enabled.
Any suggestion?
dakipro
Re: Testers wanted!
Post by dakipro »
spikehome wrote:Was the mine to.
Still doesn't work for me, little guy is red after logging in.
I then tried to "revoke the system" and enter data again, now my system is not appearing on my.domoticz.com. I tried restarting it few times, entering and saving API key and pass, still nothing.
I do not have 2steps verification.
dakipro
Re: Testers wanted!
Post by dakipro »
and after few restarts now the green guy is back and remote control works fine. Life is worth living again...
codesnipper
Re: Testers wanted!
Post by codesnipper »
Problem with frontpage - in my domoticz is FlatZ - is that frontpage is operating on local IP and you call it from outside network.
In www/settings/settings.js i changet this:
$.domoticzurl = "http://XXX.XXX.XXX.XXX:8080"
into this:
$.domoticzurl = "https://my.domoticz.com/my/A48BD36E8ECA577"
Now it works, but if there isn't connection with MyDomoticz, local addres of frontpage won't work.
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
codesnipper wrote:Problem with frontpage - in my domoticz is FlatZ - is that frontpage is operating on local IP and you call it from outside network.
into this:
Not sure what you want to accomplish. But you shouldn't be having to change anything in the sources files.
codesnipper
Re: Testers wanted!
It is not source file - it's file with settings for FlatZ frontpage. You have to edit it when you install this frontpage.
Gravityz
Domoticz version: 2022.2
Re: Testers wanted!
Post by Gravityz »
i just voluntered for my Domoticz and i must say it works right out of the box.
on an iphone safari is not keeping track of username and password(forgot auto fill in)
i however use ewallet where i can put everything which passes it along to the mydomoticz page.
2 clicks and i am in.
responsetimes are really faster then when i use the philips hue app the same way.
with HUe it takes 5-6 seconds before lights react.
wit mydomoticz it takes 1 second.
nice work.
my setup
Synology 112+
DSM 6
domoticz 5019
chimit
Re: Testers wanted!
Post by chimit »
Update: Just edited the Wiki at https://www.domoticz.com/wiki/MyDomoticz. The alpha phase is over for a while already. Now we reached Beta status.
We are almost reaching 300 Domoticz's online simultaneously at the moment.
codesnipper
Re: Testers wanted!
After sucesfull start I have errors (11 minutes from start):
2016-04-02 15:44:17.530 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-04-02 15:44:59.024 Error: PROXY: Handshake failed, reconnecting: short read
Gravityz
Re: Testers wanted!
Post by Gravityz »
i have the same.
i think sometimes mydomoitcz looses connection.
connection is up most of the time(green) so no problems here
2016-04-02 23:53:21.526 Error: PROXY: timeout occurred, reconnecting
2016-04-02 23:53:21.526 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-04-02 23:54:43.546 Error: PROXY: Connect failed, reconnecting: Connection timed out
2016-04-03 07:35:57.264 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
