domoticz in synology as package! Available now.
mschut
- Domoticz version: V3.5613
I notice Evohome. Is this supported with the domoticz package, or did you perform some setup yourself?
Verstuurd vanaf mijn SM-G920F met Tapatalk
- jumbotroll
Remove the Z-Stick and reboot Synology and see if that help.Alle wrote:I just installed domoticz on my 'old' DS710+, but the Aeon labs z-stick s2 is not recognized.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Alle
Doesn't help, i see the following errors in dmesg:jumbotroll wrote:Remove the Z-Stick and reboot Synology and see if that help.Alle wrote:I just installed domoticz on my 'old' DS710+, but the Aeon labs z-stick s2 is not recognized.
[ 59.849004] usbserial: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
[ 59.908568] ftdi_sio: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
[ 59.986218] pl2303: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
[ 60.081861] cp210x: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
- jumbotroll
What DSM version du you have?Alle wrote:Doesn't help, i see the following errors in dmesg:jumbotroll wrote:Remove the Z-Stick and reboot Synology and see if that help.Alle wrote:I just installed domoticz on my 'old' DS710+, but the Aeon labs z-stick s2 is not recognized.Code: Select all
[ 59.849004] usbserial: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload ' [ 59.908568] ftdi_sio: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload ' [ 59.986218] pl2303: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload ' [ 60.081861] cp210x: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
run cat /proc/version
The drivers are for Linux version 3.10.35
Jumbotroll
Jumbotroll
- Alle
DSM 5.2-5644 Update 3jumbotroll wrote: What DSM version du you have?
Linux version 3.10.35 (root@build3) (gcc version 4.7.3 20130102 (prerelease) (crosstool-NG 1.18.0) ) #5644 SMP Fri Jan 22 13:39:31 CST 2016
- jumbotroll
Did you install some older UsbSerialDrivers?Alle wrote:Linux version 3.10.35 (root@build3) (gcc version 4.7.3 20130102 (prerelease) (crosstool-NG 1.18.0) ) #5644 SMP Fri Jan 22 13:39:31 CST 2016jumbotroll wrote: What DSM version du you have?
What version of my build of domoticz are you using?
Jumbotroll
Jumbotroll
- Alle
In the past i used usbserialdrivers, but uninstalled them some time ago.jumbotroll wrote:Did you install some older UsbSerialDrivers?Alle wrote:Linux version 3.10.35 (root@build3) (gcc version 4.7.3 20130102 (prerelease) (crosstool-NG 1.18.0) ) #5644 SMP Fri Jan 22 13:39:31 CST 2016jumbotroll wrote: What DSM version du you have?
Using build 2.0.4298-7
- jumbotroll
It looks like you have some old drivers in your system.Alle wrote: In the past i used usbserialdrivers, but uninstalled them some time ago.
I dont know why.
Jumbotroll
Jumbotroll
- Egregius
- Domoticz version: v2024.7
Any idea how to remove them?
I might also have some old drivers from more than a year ago.
- jumbotroll
Check if you have some old UsbSerialdrivers in /var/packages/UsbSerialDrivers and /volume1/@appstore/UsbSerialDrivers.Egregius wrote:Any idea how to remove them?
You can delete this folders.
with:
rm -rf /var/packages/UsbSerialDrivers
rm -rf /volume1/@appstore/UsbSerialDrivers
Jumbotroll
Jumbotroll
- Egregius
Nope, not there, not anywhere, did a find / -name UsbSerialDrivers.
Only found a empty directory at /usr/syno/etc/packages/UsbSerialDrivers
To be clear: my RFXCOM works, the Aeotec S2 zwave stick didn't.
- Alle
Factory default fixed the problem with the usb-driver on the synology. For the evohome scripts i use debian chroot.jumbotroll wrote:It looks like you have some old drivers in your system.Alle wrote: In the past i used usbserialdrivers, but uninstalled them some time ago.
I dont know why.
Thanks for your time for creating this package!
- Egregius
Factory default? The reset button on the back of the Syno?
Doesn't that have any other things reset also? Or is everything kept in place?
- Alle
Everything will be wiped, backup first your data.Egregius wrote:Factory default? The reset button on the back of the Syno?
Verstuurd vanaf mijn E6653 met Tapatalk
- Egregius
Not an option. I have 6TB data there... And way to much plugins and other scripts to configure it all over again.
OK, everything is backed up in the cloud, but that's reserved for true disasters.
- jumbotroll
Check if you have a old cp210x.ko file in /usr/lib/modules and delete it, then try to reinstall domoticz and you will have a newer cp210x.ko in folder /usr/local/domoticz/modules.Egregius wrote:Not an option. I have 6TB data there... And way to much plugins and other scripts to configure it all over again.
If that not work, I have No idea
Jumbotroll
Jumbotroll
- Egregius
Only the one from your package is found:
Oh well, gonna let it sleep for some time. That is often a good thing to do when it doesn't work instantly
Thanks for thinking!
guy@DiskStation:/volume1/homes/guy/BackupWWW/_logs$ sudo find / -name 'cp210*'
/volume1/@appstore/domoticz/modules/cp210x.ko
guy@DiskStation:/volume1/homes/guy/BackupWWW/_logs$ cd /volume1/@appstore/domoticz/modules
guy@DiskStation:/volume1/@appstore/domoticz/modules$ ll cp210x.ko
28K -rwxr-xr-x 1 domoticz root 26K Jan 22 13:34 cp210x.ko
mschut
Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
- jumbotroll
No it's not supported in my build.mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
Jumbotroll
Jumbotroll
mschut
That explains. Saves me from hours trying...
