domoticz in synology as package! Available now.
remb0
Post by remb0 »
synocommunity.com is up again and the repository in synology has an up to date package list.
2 things I saw:
I had 11 update :P
and:
synology package
synology package
2014-05-31 22_57_13-NAS.png (18.87 KiB) Viewed 36589 times
http://www.synocommunity.com/ is still up/down (I think they are working hard on it.)
but the repo which you can add in the synology package center is alive.
add:
http://packages.synocommunity.com/
Whatsek
Domoticz version: Latest B
Re: domoticz in synology as package! Available now.
Post by Whatsek »
Verry nice! Tried to install it, but couldn't start it. It gave an error. But I will follow progress closely! On a Synology DS214Play
dolf1966
Post by dolf1966 »
with the ds212+ not working
niki_lauda
Post by niki_lauda »
DS209 not working sorry
mschut
Domoticz version: V3.5613
Post by mschut »
DS213+ cannot start the package. Waiting with great expectations!
Tigrou
Post by Tigrou »
DS3612XS DSM 5.0-4458 update 2 cannot start the package
error :
Échec lors du lancement de la réparation du paquet
les2v
Domoticz version: 14040
Post by les2v »
+1 for a DS214play but the install is still failing.
I'll follow this closely.
remb0
Post by remb0 »
this weekend I will check the logs and post them on github.. And I hope we get it working.
xKingx
Domoticz version: 2022.1
Post by xKingx »
I put below on Github ticket #1041. Perhaps useful.
I don't have a solution but I build a Domoticz package for my cedarview DS1812+. It installed but like reported here did not start. This is what is said in /var/log/messages. Unfortunately I can't find any more meaningful logs.
Jun 4 20:43:05 MiesStorage entry.cgi_SYNO.Core.Package.Installation[1].install[23710]: pkgtool.cpp:1450 Failed to exrtact package INFO to /volume1/@tmp/538F68B97653CC7A/
Jun 4 20:43:05 MiesStorage entry.cgi_SYNO.Core.Package.Installation[1].install[23710]: pkgtool.cpp:1451 /bin/tar xf /volume1/@tmp/upload_tmp.229410 -C /volume1/@tmp/538F68B97653CC7A/ INFO
Jun 4 21:00:24 MiesStorage entry.cgi_SYNO.Core.Package.Control[1].start[2392]: pkgstartstop.cpp:121 Failed to start package domoticz
Jun 4 21:08:44 XXX PkgMan.cgi: pkgtool.cpp:2052 Failed to query package status, domoticz
However I can manually start the binary, although connecting with a browser gives a 404 message, so it is not working properly in any case.
./domoticz -www 8085 -verbose 1
Domoticz V1.0.10 (c)2012-2013 GizMoCuz
Startup Path: /volume1/@appstore/domoticz/bin/
Webserver started on port: 8085
Camera settings (re)loaded
Incoming connection from: 192.168.x.x
^CClosing application!...
stopping worker...
Scheduler stopped...
Camera fetch stopped...
WebServer stopped...
Mainworker Stopped...
Raspberry Pi running Domoticz image
les2v
Post by les2v »
Do we have some news regarding this issue?
Do we know when the fix will be done and released?
gizmocuz
Post by gizmocuz »
@xKingx
no idea when unpacking does not work (i'm no synology guru)
but, when you start manually start domoticz you have to provide the commandline options for the database path and the www patch
-dbase
-wwwroot
/Rob
fwehrle
Post by fwehrle »
Hi guys,
I've add synocommunity repo, but didn't see domoticz un community tab. I have a ds209. Is it normal?
Arkie
Post by Arkie »
For me the same, doesn't show up!
Synology DS412+
Philips Hue
Fibaro
Logitech Hamony elite
Foscam 9804 ip cam
RFXtrx433E USB 433.92MHz
ZXT 120 eu AC controller
Heatmiser NEO stat thermostats and Hub
bvp76
Post by bvp76 »
Any news on the package?
For me it doesn't show up in the package center either.
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
Same here (213j)
remb0
Post by remb0 »
I hope the topics will lead to a public SPK soon.
https://github.com/SynoCommunity/spksrc/issues/1041
https://github.com/SynoCommunity/spksrc/pull/1098
for now: it's not (yet) available in the package center.
sincze
Domoticz version: 2024.4
Post by sincze »
remb0 wrote:I hope the topics will lead to a public SPK soon.
Would be great to have it available for 412+ and 212. :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Number8
Post by Number8 »
Nothing yet. Running ds1813+ and ds412+
Debian buster on NUC and three RPi with buster.
ivom74
Post by ivom74 »
Just wanted to thanks the people already which are making this package possible.
I look forward to it. Can't install cmake on ds212 amd dsm 5.0
gizmocuz
Post by gizmocuz »
Updated the 2 patches (from the wiki) to:
- Domoticz #2099
- OpenZWave #919
