domoticz in synology as package! Available now.
mschut
Domoticz version: V3.5613
Post by mschut »
I notice Evohome. Is this supported with the domoticz package, or did you perform some setup yourself?
Verstuurd vanaf mijn SM-G920F met Tapatalk
jumbotroll
Post by jumbotroll »
Alle wrote:I just installed domoticz on my 'old' DS710+, but the Aeon labs z-stick s2 is not recognized.
Remove the Z-Stick and reboot Synology and see if that help.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Alle
Post by Alle »
Doesn't help, i see the following errors in dmesg:
[   59.849004] usbserial: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
[   59.908568] ftdi_sio: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
[   59.986218] pl2303: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
[   60.081861] cp210x: version magic '3.2.40 SMP mod_unload ' should be '3.10.35 SMP mod_unload '
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
jumbotroll
What DSM version du you have?
run cat /proc/version
The drivers are for Linux version 3.10.35
Jumbotroll
Alle
Post by Alle »
jumbotroll wrote: What DSM version du you have?
DSM 5.2-5644 Update 3
Linux version 3.10.35 (root@build3) (gcc version 4.7.3 20130102 (prerelease) (crosstool-NG 1.18.0) ) #5644 SMP Fri Jan 22 13:39:31 CST 2016
jumbotroll
Did you install some older UsbSerialDrivers?
What version of my build of domoticz are you using?
Jumbotroll
Alle
Post by Alle »
In the past i used usbserialdrivers, but uninstalled them some time ago.
Using build 2.0.4298-7
jumbotroll
Alle wrote: In the past i used usbserialdrivers, but uninstalled them some time ago.
It looks like you have some old drivers in your system.
I dont know why.
Jumbotroll
Egregius
Domoticz version: v2024.7
Post by Egregius »
Any idea how to remove them?
I might also have some old drivers from more than a year ago.
jumbotroll
Egregius wrote:Any idea how to remove them?
Check if you have some old UsbSerialdrivers in /var/packages/UsbSerialDrivers and /volume1/@appstore/UsbSerialDrivers.
You can delete this folders.
with:
rm -rf /var/packages/UsbSerialDrivers
rm -rf /volume1/@appstore/UsbSerialDrivers
Jumbotroll
Egregius
Post by Egregius »
Nope, not there, not anywhere, did a find / -name UsbSerialDrivers.
Only found a empty directory at /usr/syno/etc/packages/UsbSerialDrivers
To be clear: my RFXCOM works, the Aeotec S2 zwave stick didn't.
Alle
Post by Alle »
I dont know why.
Factory default fixed the problem with the usb-driver on the synology. For the evohome scripts i use debian chroot.
Thanks for your time for creating this package!
Egregius
Post by Egregius »
Factory default? The reset button on the back of the Syno?
Doesn't that have any other things reset also? Or is everything kept in place?
Alle
Post by Alle »
Egregius wrote:Factory default? The reset button on the back of the Syno?
Everything will be wiped, backup first your data.
Verstuurd vanaf mijn E6653 met Tapatalk
Egregius
Post by Egregius »
Not an option. I have 6TB data there... And way to much plugins and other scripts to configure it all over again.
OK, everything is backed up in the cloud, but that's reserved for true disasters.
jumbotroll
Egregius wrote:Not an option. I have 6TB data there... And way to much plugins and other scripts to configure it all over again.
Check if you have a old cp210x.ko file in /usr/lib/modules and delete it, then try to reinstall domoticz and you will have a newer cp210x.ko in folder /usr/local/domoticz/modules.
If that not work, I have No idea :o
Jumbotroll
Egregius
Post by Egregius »
Only the one from your package is found:
guy@DiskStation:/volume1/homes/guy/BackupWWW/_logs$ sudo find / -name 'cp210*'
/volume1/@appstore/domoticz/modules/cp210x.ko
guy@DiskStation:/volume1/homes/guy/BackupWWW/_logs$ cd /volume1/@appstore/domoticz/modules
guy@DiskStation:/volume1/@appstore/domoticz/modules$ ll cp210x.ko
28K -rwxr-xr-x 1 domoticz root 26K Jan 22 13:34 cp210x.ko
Oh well, gonna let it sleep for some time. That is often a good thing to do when it doesn't work instantly ;)
Thanks for thinking!
mschut
Post by mschut »
Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
jumbotroll
mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
No it's not supported in my build.
Jumbotroll
mschut
Post by mschut »
That explains. Saves me from hours trying...
