[SOLVED] The use of daytime switch (sunset / sunrise)
packetloss
Domoticz version: 4.11590
Post by packetloss »
Please help me understand the sunset/sunrise mechanism in Domoticz.
For later (serious) use, I wanted to play first with a 'day / night time switch'. I created the switch with the name DayNighttime (picture 1) and created two notifications with it via pushover (picture 2). This morning with sunrise, I got two messages, instead of the expected one message (picture 3). Please help me understand why Domoticz thinks sun is set and sun is risen. Thank you.
logging
logging
DayNighttime with notifications
switch
switch
Last edited by packetloss on Monday 30 November 2015 15:34, edited 1 time in total.
bbqkees
Domoticz version: 4.1x
Re: The use of daytime switch (sunset / sunrise)
Post by bbqkees »
You have omitted how you set the timers.
packetloss
bbqkees wrote:You have omitted how you set the timers.
You're right! Here's a screenshot.
timers
timers
bbqkees
Post by bbqkees »
So zero minutes before sunRISE you set it to on, and zero minutes after sunRISE you turn it to off.
This is the same moment, you want to turn it off at sunSET.
packetloss
bbqkees wrote:So zero minutes before sunRISE you set it to on, and zero minutes after sunRISE you turn it to off.
Ah... thanx a lot! Now I understand. cheers!
smokinjoev
Re: [SOLVED] The use of daytime switch (sunset / sunrise)
Post by smokinjoev »
Nice work. The virtual switch is a great idea. I was having issues trying to use the blocks to create an event. This makes it quite easy.
Can you offset your sunrise/sunset timer by adding or subtracting minutes?
Would be nice to have my lights cut on/off a little earlier.
bbqkees
Post by bbqkees »
smokinjoev wrote:Nice work. The virtual switch is a great idea. I was having issues trying to use the blocks to create an event. This makes it quite easy.
That is a standard function. You can set a time offset in the On/Off timers.
ronnyandre
Post by ronnyandre »
Just found this thread.
If I want the the lights to turn on 30 minutes before sunset, I can set the time to 00:30?
Newbie just started with Domoticz and home automation.
Users browsing this forum: 1kke and 1 guest
