Please help me understand the sunset/sunrise mechanism in Domoticz.
For later (serious) use, I wanted to play first with a 'day / night time switch'. I created the switch with the name DayNighttime (picture 1) and created two notifications with it via pushover (picture 2). This morning with sunrise, I got two messages, instead of the expected one message (picture 3). Please help me understand why Domoticz thinks sun is set and sun is risen. Thank you.
[SOLVED] The use of daytime switch (sunset / sunrise)
packetloss
- Domoticz version: 4.11590
- logging
- 3.png (3.09 KiB) Viewed 12276 times
- DayNighttime with notifications
- 2.png (109.25 KiB) Viewed 12276 times
- switch
- 1.png (11.34 KiB) Viewed 12276 times
Last edited by packetloss on Monday 30 November 2015 15:34, edited 1 time in total.
- bbqkees
- Domoticz version: 4.1x
Re: The use of daytime switch (sunset / sunrise)
You have omitted how you set the timers.
packetloss
You're right! Here's a screenshot.bbqkees wrote:You have omitted how you set the timers.
- timers
- 4.png (171.5 KiB) Viewed 12243 times
- bbqkees
So zero minutes before sunRISE you set it to on, and zero minutes after sunRISE you turn it to off.
This is the same moment, you want to turn it off at sunSET.
packetloss
Ah... thanx a lot! Now I understand. cheers!bbqkees wrote:So zero minutes before sunRISE you set it to on, and zero minutes after sunRISE you turn it to off.
smokinjoev
Re: [SOLVED] The use of daytime switch (sunset / sunrise)
Nice work. The virtual switch is a great idea. I was having issues trying to use the blocks to create an event. This makes it quite easy.
Can you offset your sunrise/sunset timer by adding or subtracting minutes?
Would be nice to have my lights cut on/off a little earlier.
- bbqkees
That is a standard function. You can set a time offset in the On/Off timers.smokinjoev wrote:Nice work. The virtual switch is a great idea. I was having issues trying to use the blocks to create an event. This makes it quite easy.
ronnyandre
Just found this thread.
If I want the the lights to turn on 30 minutes before sunset, I can set the time to 00:30?
Newbie just started with Domoticz and home automation.
