domoticz in synology as package! Available now.
- Domoticz version: 2022.2
upgraded from 2020.1 to 2020.2 beta on DS414j (comcerto).
Upgrade was no problem.
Domoticz works like before (minor problems with a Devolo device).
Thanks for providing the update!
Best regards
Al
Best regards
Al
- jumbotroll
I'm only visitingmcwieger wrote: ↑Thursday 18 June 2020 10:14 @jumbotroll good to see your back (if you're back, in that case we have different definitions of 'long time')
If you're indeed doing frequent updates again, I'll upgrade to a 2020 version on short term...
Another question: you also create packages for MyDomoAtHome, correct? Could you compile the 0.2.41 version for the DS414 (ArmadaXP) please?
Don't expect very frequent updates as before.
MyDomoAtHome 0.2.42 is uploaded. (NOT TESTED!)
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Domoticz version: 2020.1
Thanks! Works as expected. Did not fix a bug I hoped it would, but that's with the creator of MDAH.
I moved to HomeAssistant. It was fun while it lasted!
upgraded from 2020.1.11839 to 2020.2.12178
upgraded without problems or errors
everything seems to work but i will have a close look at all the devices just in case i need to role back.
made a backup and saved the ozwcache file just to be save.
only thing i need to check after a couple of days is if i delete the ozwcache file it recreates everything without problems.
last issues i had is thatdevices were not recognised correctly or were missing in the groups.
this is why saving a ozwcache file can help you get back to the old working situation
- Domoticz version: 20202
Noobs question: Is there some kind of manual / explanation how to install jumbotroll's package and USB driver for synology (DS213j in my case)?
@jumbotrolljumbotroll wrote: ↑Tuesday 16 June 2020 21:46 NEW! Domoticz Beta version 2020.2 for synology uploaded for testing.
I upgraded from 2020.1.11835-8 to 2020.2.12213-8 (cedarview version, DS412+) and domoticz hangs / stops after the start. I had to go back to 2020.1
- jumbotroll
I have also seen that this happens occasionally in recent versions. I have not located the problem, but if you press RUN a couple of times in the package center on domoticz, it tends to start. It also usually starts immediately after a reboot of the NAS.eSbek wrote: ↑Tuesday 14 July 2020 15:45@jumbotrolljumbotroll wrote: ↑Tuesday 16 June 2020 21:46 NEW! Domoticz Beta version 2020.2 for synology uploaded for testing.
If you use Python plugin, it can be a plugin problem?
Remember to also install official Python3 package from synology first if you install domoticz with python or domoticz will not run.
Jumbotroll
Jumbotroll
Unfortunally it doesn't work at my synology NAS with python enabled (standard package). Get errors in pluginmgr but when I remove all plugins from the folder, it still isn't working... This is my error log when it crashes:
Good to say that I have reversed back to version 2020.1 and replaced the database from an backup and then it's back working with the same plugins. Updating to 2020.2 again gives the same problem...
2020-07-16 16:20:44.156 Status: (Toon) Initialized version 1.0.14, author 'John van de Vrugt'
2020-07-16 16:20:44.257 Error: Domoticz(pid:32185, tid:32200('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-07-16 16:20:44.257 Error: siginfo address=0x7db9, address=0x7f069d350089
2020-07-16 16:20:44.280 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-07-16 16:20:44.285 Error: #0 /usr/local/domoticz/bin/domoticz() [0x6ce890]
2020-07-16 16:20:44.285 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x27d [0x6cf32d]
2020-07-16 16:20:44.285 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7f069d3501c0]
2020-07-16 16:20:44.285 Error: #3 /lib/libpthread.so.0 : raise + 0x29 [0x7f069d350089]
2020-07-16 16:20:44.285 Error: #4 /lib/libpthread.so.0 : + 0x101c0 [0x7f069d3501c0]
2020-07-16 16:20:44.285 Error: #5 /lib/libpython3.5m.so : PyType_Ready + 0xe8a [0x7f069b6a989a]
2020-07-16 16:20:44.285 Error: #6 /lib/libpython3.5m.so : + 0xc84be [0x7f069b6ab4be]
2020-07-16 16:20:44.285 Error: #7 /lib/libpython3.5m.so : + 0xc0df3 [0x7f069b6a3df3]
2020-07-16 16:20:44.285 Error: #8 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.285 Error: #9 /lib/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f069b6feb87]
2020-07-16 16:20:44.286 Error: #10 /lib/libpython3.5m.so : + 0x1183b6 [0x7f069b6fb3b6]
2020-07-16 16:20:44.286 Error: #11 /lib/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f069b690a79]
2020-07-16 16:20:44.286 Error: #12 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7435 [0x7f069b7062e5]
2020-07-16 16:20:44.286 Error: #13 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.286 Error: #14 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.286 Error: #15 /lib/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f069b707e0b]
2020-07-16 16:20:44.286 Error: #16 /lib/libpython3.5m.so : + 0x11983d [0x7f069b6fc83d]
2020-07-16 16:20:44.286 Error: #17 /lib/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f069b690a59]
2020-07-16 16:20:44.286 Error: #18 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6dca [0x7f069b705c7a]
2020-07-16 16:20:44.286 Error: #19 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.286 Error: #20 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x5e9c [0x7f069b704d4c]
2020-07-16 16:20:44.286 Error: #21 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.286 Error: #22 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.286 Error: #23 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.286 Error: #24 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.286 Error: #25 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.286 Error: #26 /lib/libpython3.5m.so : + 0x91885 [0x7f069b674885]
2020-07-16 16:20:44.286 Error: #27 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.286 Error: #28 /lib/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0xbf [0x7f069b64b8df]
2020-07-16 16:20:44.286 Error: #29 /lib/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x814 [0x7f069b71bae4]
2020-07-16 16:20:44.286 Error: #30 /lib/libpython3.5m.so : + 0x1181f8 [0x7f069b6fb1f8]
2020-07-16 16:20:44.286 Error: #31 /lib/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f069b690a79]
2020-07-16 16:20:44.286 Error: #32 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.286 Error: #33 /lib/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f069b6feb87]
2020-07-16 16:20:44.286 Error: #34 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x3d24 [0x7f069b702bd4]
2020-07-16 16:20:44.286 Error: #35 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.287 Error: #36 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.287 Error: #37 /lib/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f069b707e0b]
2020-07-16 16:20:44.287 Error: #38 /lib/libpython3.5m.so : + 0x11983d [0x7f069b6fc83d]
2020-07-16 16:20:44.287 Error: #39 /lib/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f069b690a59]
2020-07-16 16:20:44.287 Error: #40 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6dca [0x7f069b705c7a]
2020-07-16 16:20:44.287 Error: #41 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.287 Error: #42 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x5e9c [0x7f069b704d4c]
2020-07-16 16:20:44.287 Error: #43 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.287 Error: #44 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.287 Error: #45 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.287 Error: #46 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.287 Error: #47 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.287 Error: #48 /lib/libpython3.5m.so : + 0x91885 [0x7f069b674885]
2020-07-16 16:20:44.287 Error: #49 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.287 Error: #50 /lib/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0xbf [0x7f069b64b8df]
2020-07-16 16:20:44.287 Error: #51 /lib/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x814 [0x7f069b71bae4]
2020-07-16 16:20:44.287 Error: #52 /lib/libpython3.5m.so : + 0x1181f8 [0x7f069b6fb1f8]
2020-07-16 16:20:44.287 Error: #53 /lib/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f069b690a79]
2020-07-16 16:20:44.287 Error: #54 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.287 Error: #55 /lib/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f069b6feb87]
2020-07-16 16:20:44.287 Error: #56 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x3d24 [0x7f069b702bd4]
2020-07-16 16:20:44.287 Error: #57 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.287 Error: #58 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.287 Error: #59 /lib/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f069b707e0b]
2020-07-16 16:20:44.287 Error: #60 /lib/libpython3.5m.so : + 0x11983d [0x7f069b6fc83d]
2020-07-16 16:20:44.287 Error: #61 /lib/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f069b690a59]
2020-07-16 16:20:44.287 Error: #62 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6dca [0x7f069b705c7a]
2020-07-16 16:20:44.287 Error: #63 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.287 Error: #64 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x5e9c [0x7f069b704d4c]
2020-07-16 16:20:44.287 Error: #65 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.287 Error: #66 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.287 Error: #67 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.288 Error: #68 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.288 Error: #69 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.288 Error: #70 /lib/libpython3.5m.so : + 0x91885 [0x7f069b674885]
2020-07-16 16:20:44.288 Error: #71 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.288 Error: #72 /lib/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0xbf [0x7f069b64b8df]
2020-07-16 16:20:44.288 Error: #73 /lib/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x814 [0x7f069b71bae4]
2020-07-16 16:20:44.288 Error: #74 /lib/libpython3.5m.so : + 0x1181f8 [0x7f069b6fb1f8]
2020-07-16 16:20:44.288 Error: #75 /lib/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f069b690a79]
2020-07-16 16:20:44.288 Error: #76 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.288 Error: #77 /lib/libpython3.5m.so : PyEval_CallObjectWithKeywords + 0x47 [0x7f069b6feb87]
2020-07-16 16:20:44.288 Error: #78 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x3d24 [0x7f069b702bd4]
2020-07-16 16:20:44.288 Error: #79 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.288 Error: #80 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.288 Error: #81 /lib/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f069b707e0b]
2020-07-16 16:20:44.288 Error: #82 /lib/libpython3.5m.so : + 0x1437a4 [0x7f069b7267a4]
2020-07-16 16:20:44.288 Error: #83 /lib/libpython3.5m.so : PyRun_StringFlags + 0x74 [0x7f069b728074]
2020-07-16 16:20:44.288 Error: #84 /lib/libpython3.5m.so : + 0x1197a8 [0x7f069b6fc7a8]
2020-07-16 16:20:44.288 Error: #85 /lib/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f069b690a59]
2020-07-16 16:20:44.288 Error: #86 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7435 [0x7f069b7062e5]
2020-07-16 16:20:44.288 Error: #87 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.288 Error: #88 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.288 Error: #89 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x5e9c [0x7f069b704d4c]
2020-07-16 16:20:44.288 Error: #90 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.288 Error: #91 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x5e9c [0x7f069b704d4c]
2020-07-16 16:20:44.288 Error: #92 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.288 Error: #93 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.288 Error: #94 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.288 Error: #95 /lib/libpython3.5m.so : PyEval_EvalCode + 0x1b [0x7f069b707e0b]
2020-07-16 16:20:44.288 Error: #96 /lib/libpython3.5m.so : + 0x11983d [0x7f069b6fc83d]
2020-07-16 16:20:44.288 Error: #97 /lib/libpython3.5m.so : PyCFunction_Call + 0xc9 [0x7f069b690a59]
2020-07-16 16:20:44.288 Error: #98 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x6dca [0x7f069b705c7a]
2020-07-16 16:20:44.288 Error: #99 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.288 Error: #100 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x5e9c [0x7f069b704d4c]
2020-07-16 16:20:44.288 Error: #101 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.289 Error: #102 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.289 Error: #103 /lib/libpython3.5m.so : PyEval_EvalFrameEx + 0x7899 [0x7f069b706749]
2020-07-16 16:20:44.289 Error: #104 /lib/libpython3.5m.so : + 0x124d0b [0x7f069b707d0b]
2020-07-16 16:20:44.289 Error: #105 /lib/libpython3.5m.so : PyEval_EvalCodeEx + 0x23 [0x7f069b707de3]
2020-07-16 16:20:44.289 Error: #106 /lib/libpython3.5m.so : + 0x91885 [0x7f069b674885]
2020-07-16 16:20:44.289 Error: #107 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.289 Error: #108 /lib/libpython3.5m.so : _PyObject_CallMethodIdObjArgs + 0xbf [0x7f069b64b8df]
2020-07-16 16:20:44.289 Error: #109 /lib/libpython3.5m.so : PyImport_ImportModuleLevelObject + 0x814 [0x7f069b71bae4]
2020-07-16 16:20:44.289 Error: #110 /lib/libpython3.5m.so : + 0x1181f8 [0x7f069b6fb1f8]
2020-07-16 16:20:44.289 Error: #111 /lib/libpython3.5m.so : PyCFunction_Call + 0xe9 [0x7f069b690a79]
2020-07-16 16:20:44.289 Error: #112 /lib/libpython3.5m.so : PyObject_Call + 0x6a [0x7f069b64af9a]
2020-07-16 16:20:44.289 Error: #113 /lib/libpython3.5m.so : + 0x68065 [0x7f069b64b065]
2020-07-16 16:20:44.289 Error: #114 /lib/libpython3.5m.so : PyObject_CallFunction + 0x83 [0x7f069b64b203]
2020-07-16 16:20:44.289 Error: #115 /lib/libpython3.5m.so : PyImport_Import + 0x106 [0x7f069b71bf96]
2020-07-16 16:20:44.289 Error: #116 /lib/libpython3.5m.so : PyImport_ImportModule + 0x1a [0x7f069b71c18a]
2020-07-16 16:20:44.289 Error: #117 /lib/libpython3.5m.so : + 0x1411f0 [0x7f069b7241f0]
2020-07-16 16:20:44.289 Error: #118 /lib/libpython3.5m.so : Py_NewInterpreter + 0x1d5 [0x7f069b724be5]
2020-07-16 16:20:44.289 Error: #119 /usr/local/domoticz/bin/domoticz : Plugins::CPlugin::Initialise() + 0x3c [0xa3d66c]
2020-07-16 16:20:44.289 Error: #120 /usr/local/domoticz/bin/domoticz : Plugins::InitializeMessage::Process() + 0x2a [0xa418ea]
2020-07-16 16:20:44.289 Error: #121 /usr/local/domoticz/bin/domoticz : Plugins::CPluginSystem::Do_Work() + 0x319 [0xa42979]
2020-07-16 16:20:44.289 Error: #122 /usr/local/domoticz/bin/domoticz : execute_native_thread_routine + 0x30 [0xc28686]
2020-07-16 16:20:44.289 Error: #123 /lib/libpthread.so.0 : + 0x72c4 [0x7f069d3472c4]
2020-07-16 16:20:44.289 Error: #124 /lib/libc.so.6 : clone + 0x6d [0x7f069c09f10d]
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
@jumbotroll, when you are planning to do a batch of updates, could you also include a build for the new DS220+ (Geminilake)? Would be much appriciated!
has anyone succeeded to get Accuweather working on Synology? I got my developer account, my api key, location, but the only log info in Domoticz is AccuWeather Worker stopped...
I have tried stable 2020.1 and now on 2020.2 on Synology DS418. When I enter the URL in browser with my apikey it returns correct answer...
https://dataservice.accuweather.com/loc ... ikey="here is my api key"="here latitude, longitude in numbers"
thanks a lot
thanks a lot
Accuweather update on synology
now after entering the same info the 20th times it started to return some info. Excellent.
I just got the Synology DS920+ and am wondering if you are planning on compiling a Gemini Lake version?
- jumbotroll
Underfunded wrote: ↑Friday 31 July 2020 19:54 I just got the Synology DS920+ and am wondering if you are planning on compiling a Gemini Lake version?
Test version Domoticz Beta for Geminilake.
Download here:
http://www.jadahl.com/
Jumbotroll
Jumbotroll
- jumbotroll
Jumbotroll
Jumbotroll
great, thanks! Hopefully i get arround and test it in the coming days!
Geminilake works as a charm here! Including custom plugins, zwave!
- jumbotroll
Nice!
Thanks for feedback!
Jumbotroll
Jumbotroll
How stable is the beta so far? Are there lots of changes expected till it's not beta anymore?
All updates so far are running smoothly on my DS414, thanks for the updates.
Just a reminder to you all: maybe a (small) donation for Jumbotroll would be great. If you appreciate.....donate !
For Business travelers complete guide is available to avail Sri Lanka business visa
Hi,jumbotroll wrote: ↑Tuesday 14 July 2020 20:10I have also seen that this happens occasionally in recent versions. I have not located the problem, but if you press RUN a couple of times in the package center on domoticz, it tends to start. It also usually starts immediately after a reboot of the NAS.eSbek wrote: ↑Tuesday 14 July 2020 15:45@jumbotrolljumbotroll wrote: ↑Tuesday 16 June 2020 21:46 NEW! Domoticz Beta version 2020.2 for synology uploaded for testing.
For me Domoticz beta ver. 2020.2.12213-8 (on Synology DS215j) does not work at all. The installation went smoothly, but now even trying to restart Domoticz several times does not work. So all my sensors and actors got stupid. I am waiting for a new beta update hoping that Domoticz will start working again.
Best regards
