Dashticz V3
TankySpanky
Re: Dashticz V3
Post by TankySpanky »
Lol found it myself, i think i have seen that posting and all over 20 times and it seems i overread it every time.
But now i got the icons bigger but the width is "fixed" somewhere because text is NOT moving and the picture is "squeezed" :)
I hope anyone can help there :)
O btw File info for belgium (antwerpen) i cant find a "good" working RSS Feed
ty in advance
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
Lokonli
Re: Dashticz V3
Post by Lokonli »
TankySpanky wrote: Sunday 08 March 2020 20:32 Lol found it myself, i think i have seen that posting and all over 20 times and it seems i overread it every time.
ty in advance
What did you change?
TankySpanky
Re: Dashticz V3
Hello
In the folder /dashticz/css
the file creative.css the " img.icon {max-width:40px;} "
Because its a image i made it 40 width,
But somewhere is also the width for the text i guess and i need to find that to make that part smaller.
Maybe even allign to right for the Text and data part to keep the most space
But when i tried that also the garbage part moved to the right :) hehe
So need a extra css in the custom for the trash then
All a work in progress going (very)slow , learning the language while working on it ( how it works and what it does )
but in the traffic.js i need a good rss feed for belgium
the icons look a bit odd now hehe
Width 30px
dashticz screen 2.png (317.82 KiB) Viewed 2292 times
width 40px now the text is getting in the way i want them like 60 or even 80 width so the switches look like switches and not like a toaster :)
dashticz screen 3.png (328.62 KiB) Viewed 2292 times
Lokonli
Re: Dashticz V3
Post by Lokonli »
If you want to change all image and icon sizes, add the following to custom.css:
div.mh {
    height: 100px !important
.col-icon {
    width: 80px !important;
    max-width: 80px !important;
.col-data {
    width: calc(100% - 90px) !important
.col-icon em {
    font-size: 40px !important;
img.icon {
If you only want to change a single block (example: device id 238), add the following:
.block_238 {
.block_238 .col-icon {
.block_238 .col-data {
.block_238 .icon {
It's better to add this to custom.css, and not to creative.css, because updating Dashticz then will be easier.
TankySpanky
Re: Dashticz V3
Oooo GReat,
Im working now on it, but i need to resize some of the icons to the best size.
Really its working great just what i needed.
now im trying to do the same for the .titleblock's
So i can only put a picture there and (almost) no text :)
/Hug :)
thank you very much
TankySpanky
Re: Dashticz V3
Solved it in 2 parts: custom.css
Never could do it without your help
first part give text a color and move to right side
.titlegroups[data-id='blocktitle_hue'] {color: #663399; !important; text-align:right;}
2nd part for only that title change img size
.titlegroups[data-id='blocktitle_hue'] .icon { max-width: 250px !important}
ive just changed your 2nd code part to titleblock
TankySpanky
Re: Dashticz V3
Today i encounterd something strange,
I was looking at the garbage settings and i noted when i change "config['garbage_use_colors'] = 0;" that the colors of everything are less bright
And when i use the "config['garbage_use_names'] = 0;" then it makes of the blue PMD the name "papier" while it is PMD
garbage 2.png (33.08 KiB) Viewed 2180 times
I use ophaalkalender.be as provider.
Latest beta from Dashticz & Domoticz
Pics are a bit bigger so you can see the "brightness" of the other items
Minglarn
Domoticz version: v3.8153
Re: Dashticz V3
Post by Minglarn »
AS I'm trying out the latest beta i've got a few issues..
One of them is the FLASH option in blocks.
This wont work, it's a pir sensor and when it's activated only the last seen info is changed but no flash of the button.
Am I missing some settings?
blocks[69] 	= {flash: 5000};
Lokonli
Re: Dashticz V3
Post by Lokonli »
It should be fixed in the latest beta of yesterday.
You have to update via git pull (I did not update the github release package yet)
Minglarn
Re: Dashticz V3
Post by Minglarn »
Lokonli wrote: Tuesday 31 March 2020 18:58 It should be fixed in the latest beta of yesterday.
Great! Im running Dashticz on my own webserver.. Thanks!
Minglarn
Re: Dashticz V3
Post by Minglarn »
Another question..
If I would FLASH to be default to all my blocks, where can I append this config?
krizzz
Re: Dashticz V3
Post by krizzz »
Hi! I see that the link to the documentation on readthedocs.io os not working anymore. Can it be fixed? Thanks!
HansieNL
Re: Dashticz V3
Post by HansieNL »
krizzz wrote: Saturday 02 May 2020 9:26 Hi! I see that the link to the documentation on readthedocs.io os not working anymore. Can it be fixed? Thanks!
@krizzz : Because of a name change the links are changed to:
https://dashticz.readthedocs.io/en/master/
https://dashticz.readthedocs.io/en/beta/
@Lokonli : Can you update the links in the 1st post please?
Blah blah blah
Basssment
Domoticz version: 4.9700
Re: Dashticz V3
Post by Basssment »
Hi i just updated dashticz i think
I am running on linux and just downloaded the zip file and extracted it in a new folder.
Replaced the custom files with the old one (3.7)
Removed the old folder an renamed the new folder to dashticz, but still my dashticz (with opens correctly) give a update notification.
what could be wrong?
madpatrick
Domoticz version: 2025.2
Re: Dashticz V3
Post by madpatrick »
Did you clear your browser cache ?
Basssment
Re: Dashticz V3
Post by Basssment »
yes did clear cache.
Also tried different browser (with cleared cache) same result :S
Lokonli
Re: Dashticz V3
Post by Lokonli »
Basssment wrote: Tuesday 27 July 2021 23:08 yes did clear cache.
Was this solved already?
If not, I will try to help:
How did you install Dashticz? Manual install or did you use the auto install script?
In the Dashticz home folder there should be a file version.txt. Can you post the content of that file here?
Derik
Re: Dashticz V3
Post by Derik »
Thanks for the great work guys!!!
Some one has a extrenal webcam working in dashticz?
Live feed and/or a cam of earthcam or something..
Thanks!!
