Dashticz V3
Lokonli
Dashticz V3
Post by Lokonli »
Dashticz V3
Dashticz V3 has been born.
Github location:
https://github.com/dashticz/dashticz
Documentation:
https://dashticz.readthedocs.io
Dashticz V3 is a fork of Dashticz V2.
It contains the same functionality as Dashticz V2 of 15-6-2019. The open PRs have been merged. A beta branch as well as master branch have been created.
I hope Dashticz V3 will give a solid base for future development work on Dashticz.
List of changes:
New functionality:
* Change in forcerefresh parameter of a button to support cheap Chinese webcams.
* Support for TempBaro device
* Sizing the y-axis of the graph to relevant data
* Adding possibility to draw graph data for Qubino ZMNHTDx Smart meter
* Add bar graph type option.
* Streamplayer: Add class when in playing state to enable styling via custom.css
* Radio streaming image (radio-streaming.png)
Fixes:
* Make index2.html consistent with index.html
* Streamplayer error handling
Upgrading
If you upgrade from Dashticz_v2:
Clone the Dashticz repository:
git clone https://github.com/dashtic/dashticz
and copy your previous CONFIG.js and other customizations to the new location:
cp dashticz_v2/custom/CONFIG.js dashticz/custom
cp dashticz_v2/custom/custom.css dashticz/custom
cp dashticz_v2/custom/custom.js dashticz/custom
If you are running Apache according the installation instructions, then you have to add the symlink in the www-root folder to the new Dashticz V3 location:
sudo ln -s $(pwd)/dashticz/ /var/www/html
After that Dashticz_v3 can be found on:
http://[IP-ADDRESS]/dashticz
Automatic installation script
The beta-branch contains an automatic installation script.
I need some beta testers to make the script more robust. I will create a new forum topic for this.
Enjoy.
EdwinK
Re: Dashticz V3
Post by EdwinK »
Just one question. Is Rob okay with this? I know in the past someone created a 'Dashtichz V3', it was later renamed to something else, because he didn't want the name Dashticz to be used.
EdwinK
Re: Dashticz V3
Post by EdwinK »
git clone https://github.com/dashticzv3/dashticz_v3
This asks for a username.
This works:
git clone https://github.com/dashticzv3/dashticz_v3.git new_dash
EdwinK
Re: Dashticz V3
Post by EdwinK »
deleted post
Lokonli
Re: Dashticz V3
Post by Lokonli »
EdwinK wrote: Tuesday 18 June 2019 14:41 Just one question. Is Rob okay with this? I know in the past someone created a 'Dashtichz V3', it was later renamed to something else, because he didn't want the name Dashticz to be used.
Good to know.
I tried to contact Rob, but I didn't get any reaction until now.
@RobGeerts:
If you prefer that we don't use the name Dashticz V3 please let me know, and we'll solve it.
EdwinK
Re: Dashticz V3
Post by EdwinK »
With a git pull:
/volume1/web/dashboard# git pull
From https://github.com/dashticzv3/dashticz_v3
* [new branch] beta -> beta/beta
* [new branch] master -> beta/master
There is no tracking information for the current branch.
Please specify which branch you want to merge with.
See git-pull(1) for details.
git pull <remote> <branch>
If you wish to set tracking information for this branch you can do so with:
git branch --set-upstream-to=origin/<branch> master
Gianni
Re: Dashticz V3
Post by Gianni »
just move over from v2 to v3
love the graph part.
But i notice that setting not save anymore(dont need it really because i do it manual).
But for some test it's easy in the settings :-)
Did the manual setup,made the simlink and chmod
Fixed looks like the write permissions did not complete.
run chmod a+w /home/pi/dashticz/custom/CONFIG.js again and now everything works fine.
t3v3h
Re: Dashticz V3
Post by t3v3h »
Nice work thanks!
For me the graphProperties is not working. do you have any idea?
blocks['graph_19'] = {
    graph: 'bar',
    graphProperties : {
        gridTextColor : '#c3f6fe',
        barColors: ['#f1c40f', '#40e0d0', '#eee'],
	stacked: 'true',
        ymax:'auto'  //set to 'auto' for auto scaling
Lokonli
Re: Dashticz V3
Post by Lokonli »
t3v3h wrote: Wednesday 07 August 2019 15:28 Nice work thanks!
    graph: 'bar',
    graphProperties : {
	stacked: 'true',
What's your exact Dashticz version? It has been implemented from 3.0.4 onwards.
Do you see the graph? Is it a bar graph or line graph?
t3v3h
Re: Dashticz V3
Post by t3v3h »
OK, thanks!
my version is 3.0.0, so it is the problem
Lokonli
Re: Dashticz V3
Post by Lokonli »
t3v3h wrote: Wednesday 07 August 2019 16:19 OK, thanks!
Get the latest version from the new location:
https://github.com/Dashticz/dashticz
After that you can update via git pull.
t3v3h
Re: Dashticz V3
Post by t3v3h »
how to upgrade to beta? :?: :D
Lokonli
Re: Dashticz V3
Post by Lokonli »
Several methods:
You can download a release from the release page:
https://github.com/Dashticz/dashticz/releases
or, if you have a Raspberry or Ubuntu like distribution: run the automatic installation script:
https://dashticz.readthedocs.io/en/late ... stall.html
or: manual install, see:
https://dashticz.readthedocs.io/en/late ... stallation
or, if your 3.0.0 already came from github.com/Dashticz/dashticz, then in the Dashticz folder type:
git checkout beta
git pull
t3v3h
Re: Dashticz V3
Post by t3v3h »
edwin1234
Domoticz version: 2021.1
Re: Dashticz V3
Post by edwin1234 »
I have dashticz v3 and it works,
Very good work.
I have the standerd setup and dont have devices in the left bottom, (the place where the sliders are in the example) and want a graph of my gasdevice id 9.
I cant get that to work. I read a lot of dashticz docs but cant figure out how to do that.
Can someone please help?
EdwinK
Re: Dashticz V3
Post by EdwinK »
edwin1234
Re: Dashticz V3
Post by edwin1234 »
Yes but how do get it in the left part of the screen under my devices?
EdwinK
Re: Dashticz V3
Post by EdwinK »
In config.JS add the following:
var columns = {}
//--- Screen 1 ---
columns[1] = {}
    columns[1]['blocks'] = ['graph_9' ]
    columns[1]['width'] = 6;
var screens = {}
screens[1] = {}
  //  screens[1]['background'] = 'bg14.jpg';
    screens[1]['columns'] = [1]
In this case, the only block shown is the graph, with a width of 6.
More reading: https://dashticz.readthedocs.io/en/mast ... tom-layout
edwin1234
Re: Dashticz V3
Post by edwin1234 »
Thanks for your help,
I’m gonna try it out
TankySpanky
Re: Dashticz V3
Post by TankySpanky »
I still love dashticz, stopped for a while because all was going smooth until i added some Tuya (converted to Tasmota) from the Action where added.
Then i tought i give it a overhaul :)
I only cannot find how to use "bigger" images for the pictures in the blocks & titleblocks
Its a but silly for the most icons now too tiny.
dashticz screen 1.png (176.39 KiB) Viewed 7099 times
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
