jvdz
Posts: 2443 Joined: Tuesday 30 December 2014 19:25
Domoticz version: 4.107
Post
by jvdz » Tuesday 03 March 2020 22:35
It should be a table so the format needs to be as shown in the model:
NotificationEmailAdress = {'',''} -- Specify multiple Email Addresses for the notifications. Leave empty to skip email notification
So in your case:
NotificationEmailAdress = {'********@gmail.com','******@hotmail.com'} -- Specify multiple Email Addresses for the notifications. Leave empty to skip email notification
Jos
Basssment
Posts: 38 Joined: Thursday 18 October 2018 14:04
Domoticz version: 4.9700
Post
by Basssment » Wednesday 04 March 2020 14:13
jvdz wrote: Tuesday 03 March 2020 22:35
So in your case:
Jos
Oh shoot. Totally missed that.
Thank you!
Basssment
Post
by Basssment » Wednesday 11 March 2020 22:37
Hi Joost,
I do'nt get any message when i (think) i should.
Ik tried editing the time and days before notification but no luck.
i edit is every time when setting the "testloaddata"to true
the notification in domoticz works and gets updates but no message is recieved.
Not on telegram and not by email.
What could i be doing wrong?
jvdz
Post
by jvdz » Wednesday 11 March 2020 22:46
The email should be send at the time you have defined in the Config table, assuming you have the script as TIME script.
I would need to get the Log files generated at a time defined in the table and the Config file so I can have a look and test, so could you zip them up and email them to me to my github mail account?
Jos
Rowdy
Posts: 7 Joined: Sunday 13 November 2016 13:39
Post
by Rowdy » Thursday 12 March 2020 9:15
Hello Jos,
Is there a option to change the date notation wen I get the e-mail.
Now I get 2020-03-12, but I want to see it like 12-03-2020
Rowdy
Raspberry pi
RFXtrx433E
Sompfy sunscreen
Promax switches ( action)
Klik aan klik uit switches
must be added:
Ipcamera
motion sensors
Light switches Livolo
Thermometer
Smoke sensors
jvdz
Post
by jvdz » Thursday 12 March 2020 9:38
Hi Rowdy,
That will require a change in the script, so will have a look to make that configurable in the config as it now indeed defaults to YYYY-MMM-DD for sorting purposes.
Jos
jvdz
Post
by jvdz » Thursday 12 March 2020 14:29
I've just committed an update to GitHub for the main script and config to allow for defining the dateformat like you can for the textDevice.
Add the lastline to you config and modify it to the format you wish:
notificationtitle = 'GarbageCalendar: @DAY@ de @GARBAGETEXT@ aan de weg zetten!'
notificationtext = '@GARBAGETEXT@ wordt @DAY@ opgehaald! op @GARBAGEDATE@ '
notificationtoday = 'vandaag'
notificationtomorrow = 'morgen'
notificationlonger = 'over @DAYS@ dagen'
notificationdate = 'dd mmm yyyy' -- @GARBAGEDATE@ format -> Options are the same as available for textformat date options
The new main script will also save a copy of the logfile
garbagecalendar_run_update_module.log when the actual Update process is ran to
garbagecalendar_run_update_module.log , so it is easier to debug in case the error only occurs during that process.
Jos
Rowdy
Post
by Rowdy » Thursday 12 March 2020 22:27
jvdz wrote: Thursday 12 March 2020 14:29
Jos
Your the best,
Thx
Raspberry pi
RFXtrx433E
Sompfy sunscreen
must be added:
Ipcamera
motion sensors
Thermometer
Smoke sensors
Bram81
Posts: 22 Joined: Saturday 02 May 2015 11:00
Post
by Bram81 » Sunday 15 March 2020 12:07
First of all, thanks for all this hard work!
I'm using the AFW plugin. I'm looking for a way to get a notification being showed on a Nodemcu with onboard 0,96 inch oled display, which is next to my frontdoor. It already would be verry helpful for me to be able to set a uservariable to 1 or 0 when a notification is scheduled or not, so i could trigger another script.
I'm no Lua hero, so I can't realy figure out where and how I should add this to the script. Is there anyone who can point me in the right direction?
Thanks in advance!
jvdz
Post
by jvdz » Sunday 15 March 2020 12:15
Hi Bram,
I think it should be pretty simple to send some text to an OLED display by using the "Notificationscript" option in the config.
This way you can run any command/script you line with some parameters for the text to display at the time of the notification set in the config.
Would that work for you?
Pm/Email me when you need help with the script.
Jos
woempiej
Posts: 9 Joined: Saturday 19 October 2019 18:47
Domoticz version: 2021.1
Post
by woempiej » Monday 30 March 2020 19:26
I try to figure out how to read the data from source
http://www.montferland.afvalwijzer.net/ with the eventsystem script_time.lua
Is there a way to copy the data in the script from afval westland?
I'm no professional in scripting sorry
jvdz
Post
by jvdz » Monday 30 March 2020 19:51
woempiej wrote: Monday 30 March 2020 19:26
Do you mean that your "gemeente" requires a new module written?
If so, I can have a look tomorrow but would need some more required info for this provider like ZIPCODE / HouseNbr.
Please Email me the info on my GitHub emailaddress.
Jos
Thuis
Posts: 281 Joined: Tuesday 11 September 2018 11:36
Post
by Thuis » Tuesday 31 March 2020 18:51
Hello Jos it worked for a while but now it seems it is stuck. It does not refresh anymore. i get this on the text switch:
And i put the debug to true to see what was happening, and i see this in the log:
Spoiler: show 2020-03-31 18:47:00.394 Status: LUA: @GarbageCal(m_goeree-overflakkee): #### Tue Mar 31 18:47:00 2020 ### Start garbagecalendar script v20200317-1900
2020-03-31 18:47:00.394 Status: LUA: @GarbageCal(m_goeree-overflakkee): #### Debuging with extra messages because "mydebug=true" in garbagecalendarconfig.lua
2020-03-31 18:47:00.395 Status: LUA: @GarbageCal(m_goeree-overflakkee): #### please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
2020-03-31 18:47:00.395 Status: LUA: @GarbageCal(m_goeree-overflakkee): domoticzjsonpath: /home/onshuis/Domotica/domoticz/scripts/lua/
2020-03-31 18:47:00.395 Status: LUA: @GarbageCal(m_goeree-overflakkee): datafilepath: /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/temp/
2020-03-31 18:47:00.396 Status: LUA: @GarbageCal(m_goeree-overflakkee): scriptpath: /home/onshuis/Domotica/domoticz/scripts/lua/
2020-03-31 18:47:00.396 Status: LUA: @GarbageCal(m_goeree-overflakkee): Loaded /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/garbagecalendarconfig.lua.
2020-03-31 18:47:00.397 Status: LUA: @GarbageCal(m_goeree-overflakkee): Loaded /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/tablefuncs.lua.
2020-03-31 18:47:00.398 Status: LUA: @GarbageCal(m_goeree-overflakkee): Start checking garbagetype_cfg table:
2020-03-31 18:47:00.398 Status: LUA: @GarbageCal(m_goeree-overflakkee): Groente-, fruit- en tuinafval change to groente-, fruit- en tuinafval
2020-03-31 18:47:00.398 Status: LUA: @GarbageCal(m_goeree-overflakkee): Papier en karton change to papier en karton
2020-03-31 18:47:00.399 Status: LUA: @GarbageCal(m_goeree-overflakkee): Restafval change to restafval
2020-03-31 18:47:00.399 Status: LUA: @GarbageCal(m_goeree-overflakkee): -> NotificationTime:19:0 Garbagetype:papier en karton
2020-03-31 18:47:00.399 Status: LUA: @GarbageCal(m_goeree-overflakkee): -> NotificationTime:19:0 Garbagetype:groente-, fruit- en tuinafval
2020-03-31 18:47:00.400 Status: LUA: @GarbageCal(m_goeree-overflakkee): -> NotificationTime:16:25 Garbagetype:dummy2
2020-03-31 18:47:00.400 Status: LUA: @GarbageCal(m_goeree-overflakkee): -> NotificationTime:19:0 Garbagetype:restafval
2020-03-31 18:47:00.400 Status: LUA: @GarbageCal(m_goeree-overflakkee): -> NotificationTime:2:2 Garbagetype:dummy1
2020-03-31 18:47:00.400 Status: LUA: @GarbageCal(m_goeree-overflakkee): Start update for text device:
2020-03-31 18:47:00.402 Status: LUA: @GarbageCal(m_goeree-overflakkee): - Start looping through data from the website: /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/temp/garbagecalendar_m_goeree-overflakkee.data
2020-03-31 18:47:00.402 Status: LUA: ==> GarbageDate:2020-2-24 GarbageType:restafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-36
2020-03-31 18:47:00.403 Status: LUA: ==> GarbageDate:2020-3-2 GarbageType:groente-, fruit- en tuinafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-29
2020-03-31 18:47:00.404 Status: LUA: ==> GarbageDate:2020-3-9 GarbageType:restafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-22
2020-03-31 18:47:00.404 Status: LUA: ==> GarbageDate:2020-3-14 GarbageType:papier en karton Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-17
2020-03-31 18:47:00.405 Status: LUA: ==> GarbageDate:2020-3-16 GarbageType:groente-, fruit- en tuinafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-15
2020-03-31 18:47:00.405 Status: LUA: @GarbageCal(m_goeree-overflakkee): - End -----------------
2020-03-31 18:47:00.406 Status: LUA: @GarbageCal(m_goeree-overflakkee): ==> found schedule:ma 24 feb: Groene bak, Restafval ; ma 2 mrt: Bruine bak, GFT afval ; ma 9 mrt: Groene bak, Restafval ; za 14 mrt: Blauwe bak, Papier en Karton ; ma 16 mrt: Bruine bak, GFT afval ;
2020-03-31 18:47:00.406 Status: LUA: @GarbageCal(m_goeree-overflakkee): No updated text for TxtDevice.
2020-03-31 18:47:00.407 Status: LUA: @GarbageCal(m_goeree-overflakkee): #### 18:47:00 End garbagecalendar script v20200317-1900
2020-03-31 18:47:00.423 Status: EventSystem: Script event triggered: /home/onshuis/Domotica/domoticz/scripts/lua/script_time_garbagecalendar.lua
Does it perhaps mean the website where the data is from is not updated correctly ??? I just looked at the website
https://webadapter.watsoftware.nl/afvalkalender.html and it is normally showing dates...
I noticed because last weekend i did not received any notification, so i thought to look into it.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
jvdz
Post
by jvdz » Tuesday 31 March 2020 18:59
Thuis wrote: Tuesday 31 March 2020 18:51
Does it perhaps mean the website where the data is from is not updated correctly ???/quote]
Did you check the garbagecalendar_web_m_goeree-overflakkee.log as that is the result of the WebUpdate that runs one time per day?
When I test with your info it works fine for me:
==> found schedule:restafval: maa 6 apr ; groente-, fruit- en tuinafval: zat 11 apr ; papier en karton: zat 18 apr ;
Jos
Thuis
Post
by Thuis » Tuesday 31 March 2020 19:38
I looked in the garbagecalendar_web_m_goeree-overflakkee.log
Spoiler: show 1 @GarbageCal(m_goeree-overflakkee): #### Tue Mar 31 19:37:00 2020 ### Start garbagecalendar script v20200317-1900
2 @GarbageCal(m_goeree-overflakkee): #### Debuging with extra messages because "mydebug=true" in garbagecalendarconfig.lua
3 @GarbageCal(m_goeree-overflakkee): #### please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
4 @GarbageCal(m_goeree-overflakkee): domoticzjsonpath: /home/onshuis/Domotica/domoticz/scripts/lua/
5 @GarbageCal(m_goeree-overflakkee): datafilepath: /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/temp/
6 @GarbageCal(m_goeree-overflakkee): scriptpath: /home/onshuis/Domotica/domoticz/scripts/lua/
7 @GarbageCal(m_goeree-overflakkee): Loaded /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/garbagecalendarconfig.lua.
8 @GarbageCal(m_goeree-overflakkee): Loaded /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/tablefuncs.lua.
9 @GarbageCal(m_goeree-overflakkee): Start checking garbagetype_cfg table:
10 @GarbageCal(m_goeree-overflakkee): Restafval change to restafval
11 @GarbageCal(m_goeree-overflakkee): Groente-, fruit- en tuinafval change to groente-, fruit- en tuinafval
12 @GarbageCal(m_goeree-overflakkee): Papier en karton change to papier en karton
13 @GarbageCal(m_goeree-overflakkee): -> NotificationTime:19:0 Garbagetype:papier en karton
14 @GarbageCal(m_goeree-overflakkee): -> NotificationTime:19:0 Garbagetype:groente-, fruit- en tuinafval
15 @GarbageCal(m_goeree-overflakkee): -> NotificationTime:19:0 Garbagetype:restafval
16 @GarbageCal(m_goeree-overflakkee): -> NotificationTime:16:25 Garbagetype:dummy2
17 @GarbageCal(m_goeree-overflakkee): -> NotificationTime:2:2 Garbagetype:dummy1
18 @GarbageCal(m_goeree-overflakkee): Start update for text device:
19 @GarbageCal(m_goeree-overflakkee): - Start looping through data from the website: /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/temp/garbage$
20 ==> GarbageDate:2020-2-24 GarbageType:restafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-36
21 ==> GarbageDate:2020-3-2 GarbageType:groente-, fruit- en tuinafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-29
22 ==> GarbageDate:2020-3-9 GarbageType:restafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-22
23 ==> GarbageDate:2020-3-14 GarbageType:papier en karton Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-17
24 ==> GarbageDate:2020-3-16 GarbageType:groente-, fruit- en tuinafval Notify Time=19:0 Notify_DaysBefore=1 reminder=2 Calculated_Days_Differerence=-15
25 @GarbageCal(m_goeree-overflakkee): - End -----------------
26 @GarbageCal(m_goeree-overflakkee): ==> found schedule:ma 24 feb: Groene bak, Restafval ; ma 2 mrt: Bruine bak, GFT afval ; ma 9 mrt: Groene bak, Restafval$
27 @GarbageCal(m_goeree-overflakkee): No updated text for TxtDevice.
Thuis
Post
by Thuis » Tuesday 31 March 2020 19:41
Oh that was run_m here is web_m
Spoiler: show 1 @m_goeree_overflakkee:Start garbagekalerder module m_goeree_overflakkee (v20200209-1800)
2 @m_goeree_overflakkee:Loaded JSON.lua.
3 @m_goeree_overflakkee:!!! perform background update to /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/temp/garbagecalendar_m_goeree-overflakk$
4 @m_goeree_overflakkee:---- web update ----------------------------------------------------------------------------
5 @m_goeree_overflakkee:sQuery=curl "https://webadapter.watsoftware.nl/widge ... %3E%3Chuis $
6 @m_goeree_overflakkee:- start looping through received data -----------------------------------------------------------
7 @m_goeree_overflakkee:1 web_garbagetype:Restafval web_garbagedate:Maandag 24 februari
8 @m_goeree_overflakkee:...-> diff:0 garbageyear:2020 garbagemonth:2 garbageday:24
9 @m_goeree_overflakkee:2 web_garbagetype:Groente-, fruit- en tuinafval web_garbagedate:Maandag 2 maart
10 @m_goeree_overflakkee:...-> diff:7 garbageyear:2020 garbagemonth:3 garbageday:2
11 @m_goeree_overflakkee:3 web_garbagetype:Restafval web_garbagedate:Maandag 9 maart
12 @m_goeree_overflakkee:...-> diff:14 garbageyear:2020 garbagemonth:3 garbageday:9
13 @m_goeree_overflakkee:4 web_garbagetype:Papier en karton web_garbagedate:Zaterdag 14 maart
14 @m_goeree_overflakkee:...-> diff:19 garbageyear:2020 garbagemonth:3 garbageday:14
15 @m_goeree_overflakkee:5 web_garbagetype:Groente-, fruit- en tuinafval web_garbagedate:Maandag 16 maart
16 @m_goeree_overflakkee:...-> diff:21 garbageyear:2020 garbagemonth:3 garbageday:16
17 @m_goeree_overflakkee:6 web_garbagetype:Restafval web_garbagedate:Maandag 23 maart
18 @m_goeree_overflakkee:...-> diff:28 garbageyear:2020 garbagemonth:3 garbageday:23
19 @m_goeree_overflakkee:7 web_garbagetype:Groente-, fruit- en tuinafval web_garbagedate:Maandag 30 maart
20 @m_goeree_overflakkee:...-> diff:35 garbageyear:2020 garbagemonth:3 garbageday:30
21 @m_goeree_overflakkee:8 web_garbagetype:Restafval web_garbagedate:Maandag 6 april
22 @m_goeree_overflakkee:...-> diff:42 garbageyear:2020 garbagemonth:4 garbageday:6
23 @m_goeree_overflakkee:9 web_garbagetype:Papier en karton web_garbagedate:Zaterdag 11 april
24 @m_goeree_overflakkee:...-> diff:47 garbageyear:2020 garbagemonth:4 garbageday:11
25 @m_goeree_overflakkee:10 web_garbagetype:Groente-, fruit- en tuinafval web_garbagedate:Zaterdag 11 april
26 @m_goeree_overflakkee:...-> diff:47 garbageyear:2020 garbagemonth:4 garbageday:11
27 @m_goeree_overflakkee:11 web_garbagetype:Restafval web_garbagedate:Maandag 20 april
28 @m_goeree_overflakkee:...-> diff:56 garbageyear:2020 garbagemonth:4 garbageday:20
29 @m_goeree_overflakkee:=> Write data to /home/onshuis/Domotica/domoticz/scripts/lua/garbagecalendar/temp/garbagecalendar_m_goeree-overflakkee.data
Thuis
Post
by Thuis » Tuesday 31 March 2020 19:45
i changed the garbagecalendar_m_goeree-overflakkee.data to garbagecalendar_m_goeree-overflakkee.data.old
then it generated a new garbagecalendar_m_goeree-overflakkee.data with the correct data.
I will keep an eye on it and maybe otherwise delete the .data file after a few days to get the new data ?
the permissions on the .data file is 777
jvdz
Post
by jvdz » Tuesday 31 March 2020 20:01
mmm.... What is the info for the Ownership and Rights for the old file?
Thuis
Post
by Thuis » Tuesday 31 March 2020 20:14
777 same owner ah and the new generated .data file is 644 with the same user and group
i have to go home, so i will not be able to reply anymore, only tomorrow. Thanks for the help so far
jvdz
Post
by jvdz » Wednesday 01 April 2020 11:17
Thuis wrote: Tuesday 31 March 2020 20:14
That doesn't make much sense to me to be honest. So the modification date was also old for the data file?
I have added a extra printline in the table_funcs.lua table.load & table.save functions in case there was an error opening the file, just to make sure that works properly.
Jos
