I've just committed an update to GitHub for the main script and config to allow for defining the dateformat like you can for the textDevice.
Add the lastline to you config and modify it to the format you wish:
notificationtitle = 'GarbageCalendar: @DAY@ de @GARBAGETEXT@ aan de weg zetten!'
notificationtext = '@GARBAGETEXT@ wordt @DAY@ opgehaald! op @GARBAGEDATE@ '
notificationtoday = 'vandaag'
notificationtomorrow = 'morgen'
notificationlonger = 'over @DAYS@ dagen'
notificationdate = 'dd mmm yyyy' -- @GARBAGEDATE@ format -> Options are the same as available for textformat date options
The new main script will also save a copy of the logfile
garbagecalendar_run_update_module.log when the actual Update process is ran to
garbagecalendar_run_update_module.log, so it is easier to debug in case the error only occurs during that process.
Jos
