Multi value custom sensor
TDer
Re: Multi value custom sensor
Post by TDer »
This is exactly what I was looking for and too bad there isn't such a multi value custom sensor available yet :(
Testing here with SDS011 and ESPeasy on a Wemos D1.
I was hoping to get some graphs during newyear, but now I only can graph the PM2.5.
thorian
Domoticz version: 2.2563
Post by thorian »
Untill it arrvies I'm using the rules in ESP Easy for ESP8266 to send both PM 2,5 and PM10 to Domoticz:
 SendToHTTP 192.168.1.45,8888,/json.htm?type=command&param=udevice&idx=201&nvalue=0&svalue=[SDS011#PM25]
 SendToHTTP 192.168.1.45,8888,/json.htm?type=command&param=udevice&idx=202&nvalue=0&svalue=[SDS011#PM10]
Where 201 and 202 are Custom sensors.
MaikelK
Post by MaikelK »
How does this work?
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
+1
Love to have Custom Sensor accepting multi values. ie number / text etc
Any body working on this already ?
Greetings McMelloW
Spitfire
Post by Spitfire »
Another +1,
Very useful for bandwith coverage, Mi flora flower sensors etc...
PieterS
Domoticz version: 2024.7
Post by PieterS »
+1
Should be nice feature!
Synology with Domoticz build (V2024.7) in Docker
miroslavpetrov
Post by miroslavpetrov »
thorian wrote: Sunday 14 January 2018 21:07 Untill it arrvies I'm using the rules in ESP Easy for ESP8266 to send both PM 2,5 and PM10 to Domoticz:
Can you please share the entire Rule? I am not sure how to make the execution of the request every xx seconds.
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Patrykwaw
Domoticz version: 4.10364
Post by Patrykwaw »
I use exactly the same method to send values from PMS5003
On System#Boot do
   timerSet,1,10
  endon
On Rules#Timer=1 do
  GPIO,12,0
  timerSet,2,60
endon
On Rules#Timer=2 do
    SendToHTTP xxx.xxx.xxx.xxx,80,/json.htm?type=command&param=udevice&idx=130&nvalue=0&svalue=[dust#PM10]
    SendToHTTP xxx.xxx.xxx.xxx,80,/json.htm?type=command&param=udevice&idx=133&nvalue=0&svalue=[dust#PM1]
    SendToHTTP xxx.xxx.xxx.xxx,80,/json.htm?type=command&param=udevice&idx=132&nvalue=0&svalue=[dust#PM25]
 GPIO,12,1
  timerSet,1,1800
endon
After system boot wait 10 seconds for wifi connections etc.
On System#Boot do
   timerSet,1,10
  endon
Switch on power for dust sensor and wait 60 seconds for proper data reading
On Rules#Timer=1 do
  GPIO,12,0
  timerSet,2,60
endon
Send values to domoticz and switch off power
On Rules#Timer=2 do
 GPIO,12,1
Set Timer one for 1800 sec
  timerSet,1,1800
endon
PatrykMilewski
Domoticz version: Beta 3.8
Post by PatrykMilewski »
+1
I need this for custom virtual temperature measurements
angelus1753
Domoticz version: 3.9056
Post by angelus1753 »
+1
(new to this, and surprised it isn't there already)
DS-218+ with Jadahl Domoticz
Qcvictor
Post by Qcvictor »
+1 because I'm in metric and my wife in imperial, will be great to display temperature Celsius/Fahrenheit in the custom sensor :P
ronilee
Post by ronilee »
Is there something new here?
My problem:
I have a new UV Sensor VEML6070.
I use EasyESP to send the data to domoticz.
My problem:
This sensor has three values, UV-Raw / UV-Risk / UV-Power
I have created a virtual custom sensor, but the only shown me the first value UV-Raw.
Do you have an idea how i can display the 2 and 3 value?
Thanks a lot :)
Users browsing this forum: Google [Bot] and 0 guests
