Multi value custom sensor
- Target OS: -
Re: Multi value custom sensor
This is exactly what I was looking for and too bad there isn't such a multi value custom sensor available yet
Testing here with SDS011 and ESPeasy on a Wemos D1.
I was hoping to get some graphs during newyear, but now I only can graph the PM2.5.
- Domoticz version: 2.2563
Untill it arrvies I'm using the rules in ESP Easy for ESP8266 to send both PM 2,5 and PM10 to Domoticz:
Where 201 and 202 are Custom sensors.
SendToHTTP 192.168.1.45,8888,/json.htm?type=command¶m=udevice&idx=201&nvalue=0&svalue=[SDS011#PM25]
SendToHTTP 192.168.1.45,8888,/json.htm?type=command¶m=udevice&idx=202&nvalue=0&svalue=[SDS011#PM10]
How does this work?
- McMelloW
- Domoticz version: V2024.1
+1
Love to have Custom Sensor accepting multi values. ie number / text etc
Any body working on this already ?
Greetings McMelloW
Another +1,
Very useful for bandwith coverage, Mi flora flower sensors etc...
- Domoticz version: 2024.7
+1
Should be nice feature!
Synology with Domoticz build (V2024.7) in Docker
Can you please share the entire Rule? I am not sure how to make the execution of the request every xx seconds.thorian wrote: ↑Sunday 14 January 2018 21:07 Untill it arrvies I'm using the rules in ESP Easy for ESP8266 to send both PM 2,5 and PM10 to Domoticz:
Where 201 and 202 are Custom sensors.Code: Select all
SendToHTTP 192.168.1.45,8888,/json.htm?type=command¶m=udevice&idx=201&nvalue=0&svalue=[SDS011#PM25] SendToHTTP 192.168.1.45,8888,/json.htm?type=command¶m=udevice&idx=202&nvalue=0&svalue=[SDS011#PM10]
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Eastron SDM230
- Domoticz version: 4.10364
I use exactly the same method to send values from PMS5003
After system boot wait 10 seconds for wifi connections etc.
Switch on power for dust sensor and wait 60 seconds for proper data reading
Send values to domoticz and switch off power
Set Timer one for 1800 sec
On System#Boot do
timerSet,1,10
endon
On Rules#Timer=1 do
GPIO,12,0
timerSet,2,60
endon
On Rules#Timer=2 do
SendToHTTP xxx.xxx.xxx.xxx,80,/json.htm?type=command¶m=udevice&idx=130&nvalue=0&svalue=[dust#PM10]
SendToHTTP xxx.xxx.xxx.xxx,80,/json.htm?type=command¶m=udevice&idx=133&nvalue=0&svalue=[dust#PM1]
SendToHTTP xxx.xxx.xxx.xxx,80,/json.htm?type=command¶m=udevice&idx=132&nvalue=0&svalue=[dust#PM25]
GPIO,12,1
timerSet,1,1800
endon
On System#Boot do
timerSet,1,10
endon
On Rules#Timer=1 do
GPIO,12,0
timerSet,2,60
endon
On Rules#Timer=2 do
GPIO,12,1
timerSet,1,1800
endon
- Domoticz version: Beta 3.8
+1
I need this for custom virtual temperature measurements
- Domoticz version: 3.9056
+1
(new to this, and surprised it isn't there already)
DS-218+ with Jadahl Domoticz
+1 because I'm in metric and my wife in imperial, will be great to display temperature Celsius/Fahrenheit in the custom sensor
Is there something new here?
My problem:
I have a new UV Sensor VEML6070.
I use EasyESP to send the data to domoticz.
My problem:
This sensor has three values, UV-Raw / UV-Risk / UV-Power
I have created a virtual custom sensor, but the only shown me the first value UV-Raw.
Do you have an idea how i can display the 2 and 3 value?
Thanks a lot
My problem:
My problem:
Thanks a lot
Users browsing this forum: Bing [Bot] and 0 guests
