Compatibility Zigate and Synology nas Topic is solved
Re: Compatibility Zigate and Synology nas
Could you try to do a git pull in order to update the plugin, and do a Domoticz restart.
twoenter
- Domoticz version: 4.10
My repeater (router) is quite the same as your link. I'm using a CC2531 usb sniffer with a special router firmware witch now is supported by zigate.Johnny5 wrote: Thursday 18 July 2019 23:17Hello,
Do you use this repeater? Have you assembled it by yourself?
https://www.zigbee2mqtt.io/how_tos/how_ ... outer.html
What is the longest distance where Xiaomi sensor connected to it?
I'm strungling with Xiaomi temp sensor to reach Zigate from about 8-10 meters. It's straight ahead on the porch. There are two big windows between them. Initialisation on Xiaomi sensor works then it loses the connection after several minutes. Swicthing wifi to 5Ghz didn't help on this problem.
I'm thinking about to move away Zigate using a USB extender cable from the place where my NAS and Wifi router are as well.
Thanks.
My syno is at one side of the house, next to the front door. All the sensors are in less than 9 meters distance, 3x aqara motion sensor, 3x aqara temp+hum, 2x vibration sensor and 1x aqara door sensor. Between the zigate and the sensor are max 2 floors (window and vibration sensor), the others are on the first and ground floor.
When I look into the meshnetwork in de webadmin page of zigate I see everyting is connected directly to the zigate, none of the devices does use the router?. Maybe in interpretet the diagram wrong? I do not experience structural connection errors, sometimes the window sensor fails to connect. I want to find out how to (force) connect it to the router.
Yes I have.pipiche wrote: Friday 19 July 2019 9:15Do you have domoticz backup enabled ?twoenter wrote:This is the only error I still have :
There is one for motion, baro and tempCode: Select all
2019-07-19 05:48:20.499 Error: (Zigate) retreiveTimeOut_Motion - Database error: database disk image is malformed
will do that tonight. Thankspipiche wrote: Friday 19 July 2019 11:27 Could you try to do a git pull in order to update the plugin, and do a Domoticz restart.
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
Best would be to be on 'beta' branch and have beta-4.4.13
twoenter
Okay, I'm having domoticz crashes since I have updated the plugin. There is no newer version of domoticz available for synology. I think I switch back to stable plugin and wait for a domoticz update.
Could you attached the log ?
In order to check if the problem is not related to the changes made
twoenter
I dont see any errors...pipiche wrote: Saturday 20 July 2019 9:54 Could you attached the log ?
I'm sure it has something to do with the backup. domoticz always crashes on the xx:00 hour.
2019-07-19 22:00:00.828 Status: Starting automatic database backup procedure...
Around 22:05 I noticed domoticz was offline, so i restarted from DSM (Syno admin page)
2019-07-19 22:05:26.946 Status: Domoticz V4.10998 (c)2012-2019 GizMoCuz
2019-07-19 22:05:26.946 Status: Build Hash: d38fbc3-modified, Date: 2019-07-13 16:44:30
2019-07-19 22:05:26.947 Status: Startup Path: /usr/local/domoticz/
2019-07-19 22:05:26.994 Sunrise: 05:43:00 SunSet: 21:51:00
2019-07-19 22:05:26.994 Day length: 16:08:00 Sun at south: 13:47:00
2019-07-19 22:05:26.994 Civil twilight start: 04:59:00 Civil twilight end: 22:36:00
2019-07-19 22:05:26.994 Nautical twilight start: 03:54:00 Nautical twilight end: 23:41:00
2019-07-19 22:05:26.994 There is no astronomical twilight in the space of 24 hours
2019-07-19 22:05:28.206 Status: PluginSystem: Started, Python version '3.5.1'.
2019-07-19 22:05:28.217 Active notification Subsystems: gcm (1/13)
2019-07-19 22:05:28.255 Status: WebServer(HTTP) started on address: :: with port 8084
2019-07-19 22:05:28.305 Status: WebServer(SSL) started on address: :: with port 8443
2019-07-19 22:05:28.308 Starting shared server on: :::6144
2019-07-19 22:05:28.309 Status: TCPServer: shared server started...
2019-07-19 22:05:28.309 Status: RxQueue: queue worker started...
2019-07-19 22:05:30.310 Status: Hardware Monitor: Started
2019-07-19 22:05:30.331 Status: P1 Smart Meter: Using serial port: /dev/ttyUSB-216-P1-METER
2019-07-19 22:05:30.332 Status: P1 Smart Meter: Worker started...
2019-07-19 22:05:30.333 Status: RFXCOM: Worker started...
2019-07-19 22:05:30.333 Status: InComfort: Worker started...
2019-07-19 22:05:30.334 Status: WOL: Started
2019-07-19 22:05:30.334 Status: Pinger: Worker started...
2019-07-19 22:05:30.335 Status: Darksky: Started...
2019-07-19 22:05:30.335 Status: (Zigate) Started.
2019-07-19 22:05:30.335 Status: EventSystem: reset all events...
2019-07-19 22:05:30.368 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/16_trap.lua
2019-07-19 22:05:30.368 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/00_verlichting.lua
2019-07-19 22:05:30.369 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/global_data.lua
2019-07-19 22:05:30.369 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_Droger.lua
2019-07-19 22:05:30.369 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_wasmachine.lua
2019-07-19 22:05:30.370 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/17_MV.lua
2019-07-19 22:05:30.370 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/9_dekentje.lua
2019-07-19 22:05:30.370 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/14_relais.lua
2019-07-19 22:05:30.371 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/02_vijverpomp.lua
2019-07-19 22:05:30.371 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/10_regen_dzv.lua
2019-07-19 22:05:30.371 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_Droger3.lua
2019-07-19 22:05:30.372 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_Wasmachine.lua
2019-07-19 22:05:30.372 Status: EventSystem: reset all device statuses...
2019-07-19 22:05:30.570 Status: PluginSystem: Entering work loop.
2019-07-19 22:05:30.662 Status: Python EventSystem: Initalizing event module.
2019-07-19 22:05:30.663 Status: EventSystem: Queue thread started...
2019-07-19 22:05:30.663 Status: EventSystem: Started
2019-07-19 22:05:31.334 Status: RFXCOM: Using serial port: /dev/ttyUSB-216-RFX433E
2019-07-19 22:05:31.334 Status: MQTT: Connecting to localhost:1883
2019-07-19 22:05:31.436 Status: MQTT: connected to: localhost:1883
2019-07-19 22:05:31.536 Status: MQTT: Subscribed
2019-07-19 22:05:31.663 Status: (Zigate) Entering work loop.
2019-07-19 22:05:31.664 Status: (Zigate) Initialized version beta-4.4, author 'zaraki673 pipiche38'
2019-07-19 22:05:31.673 Status: (Zigate) Zigate plugin beta-4.4.12 started
2019-07-19 22:05:31.673 (Zigate) Debug: 0
2019-07-19 22:05:31.673 Status: (Zigate) Python Version - 3.5.1 (default, Jan 29 2018, 14:16:30)
[GCC 4.9.3 20150311 (prerelease)]
2019-07-19 22:05:31.673 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-19 22:05:31.673 Status: (Zigate) DomoticzVersion: 4.10998
2019-07-19 22:05:31.674 Status: (Zigate) DomoticzHash: d38fbc3-modified
2019-07-19 22:05:31.674 Status: (Zigate) DomoticzBuildTime: 2019-07-13 16:44:30
2019-07-19 22:05:31.674 Status: (Zigate) load PluginConf
2019-07-19 22:05:31.706 Status: P1 Smart Meter: Meter reports as DSMR 4.2
2019-07-19 22:05:31.715 Status: (Zigate) vibrationAqarasensitivity set to high
2019-07-19 22:05:31.715 Status: (Zigate) pluginOTAFirmware set to /usr/local/domoticz/var/plugins/Zigate/OTAFirmware/
2019-07-19 22:05:31.715 Status: (Zigate) pluginHome set to /usr/local/domoticz/var/plugins/Zigate/
2019-07-19 22:05:31.716 Status: (Zigate) pluginReports set to /usr/local/domoticz/var/plugins/Zigate/Reports/
2019-07-19 22:05:31.716 Status: (Zigate) pluginConfig set to /usr/local/domoticz/var/plugins/Zigate/Conf/
2019-07-19 22:05:31.725 Status: (Zigate) pluginData set to /usr/local/domoticz/var/plugins/Zigate/Data/
2019-07-19 22:05:31.725 Status: (Zigate) homedirectory set to /usr/local/domoticz/var/plugins/Zigate/
2019-07-19 22:05:31.725 Status: (Zigate) pluginWWW set to /usr/local/domoticz/var/plugins/Zigate/www/
2019-07-19 22:05:31.725 Status: (Zigate) filename set to /usr/local/domoticz/var/plugins/Zigate/Conf/PluginConf-27.json
2019-07-19 22:05:31.726 Status: (Zigate) Opening DomoticzDB in raw
2019-07-19 22:05:31.910
2019-07-19 22:05:32.057 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1019
Firmware type = Ext2
Hardware version = 1.3
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic enabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
Legrand disabled
MSG4Reserved5 disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 enabled
Conrad RSL disabled
ByronSX enabled
IMAGINTRONIX disabled
KEELOQ disabled
Home Confort disabled
2019-07-19 22:05:32.117 Status: P1 Smart Meter: Found gas meter on M-Bus channel 1
2019-07-19 22:05:32.127 Status: (Zigate) Plugin Database: DeviceList-27.txt
2019-07-19 22:05:32.175 Status: (Zigate) DeviceConf loaded
2019-07-19 22:05:32.175 Status: (Zigate) load ListOfDevice
2019-07-19 22:05:32.263 Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Zigate/Data/DeviceList-27.txt : 9
2019-07-19 22:05:32.279 Status: (Zigate) Transport mode: USB
2019-07-19 22:05:32.280 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB2
2019-07-19 22:05:32.282 Status: (Zigate) Configure Permit To Join
2019-07-19 22:05:32.282 Status: (Zigate) Request Accepting new Hardware for 254 seconds
2019-07-19 22:05:32.282 Status: (Zigate) Trigger a Topology Scan
2019-07-19 22:05:32.283 Status: (Zigate) Trigger a Energy Level Scan
2019-07-19 22:05:32.301 (Slimme meter) P1 Smart Meter (Slimme meter Elektra)
2019-07-19 22:05:32.309 (Slimme meter) Usage (Usage L1)
2019-07-19 22:05:32.311 (Slimme meter) Usage (Delivery L1)
2019-07-19 22:05:32.319 (Slimme meter) P1 Smart Meter (Gasmeter)
2019-07-19 22:05:32.385 Status: (Zigate) Major Version Num: 0003
2019-07-19 22:05:32.386 Status: (Zigate) Installer Version Number: 030f
2019-07-19 22:05:32.589 (Zigate) Permit Join status: 01
2019-07-19 22:05:32.589 (Zigate) ---> self.permitTojoin['Starttime']: 1563566732
2019-07-19 22:05:32.589 (Zigate) ---> Current time : 1563566732
2019-07-19 22:05:32.589 (Zigate) ---> self.Ping['Permit'] (prev) : None
2019-07-19 22:05:32.589 Status: (Zigate) Accepting new Hardware: On
2019-07-19 22:05:32.589 (Zigate) ---> self.Ping['Permit'] (new ) : On
2019-07-19 22:05:32.706 Status: (Zigate) Zigate addresses ieee: 00158d0001ecaee0 , short addr: 0000
2019-07-19 22:05:32.706 Status: (Zigate) Network state UP, PANID: 3b73 extPANID: 0xd56cfb146c18053c Channel: 11
2019-07-19 22:05:32.836 Status: (Zigate) Number of devices recently active in Zigate = 7
2019-07-19 22:05:40.849 (Weer) Temp + Humidity + Baro (Buitentemp+Hum+Baro)
2019-07-19 22:05:40.869 (Weer) Wind (Wind)
2019-07-19 22:05:40.875 (Weer) UV (UV Index)
2019-07-19 22:05:40.882 (Weer) Rain (Rain)
2019-07-19 22:05:40.897 (Weer) General/Visibility (Zicht)
2019-07-19 22:05:40.908 (Weer) General/Custom Sensor (Ozone Sensor)
2019-07-19 22:05:40.909 (Weer) General/Percentage (Cloud Cover)
2019-07-19 22:05:41.016 Status: dzVents: Info: Handling events for: "Buitentemp+Hum+Baro", value: "19.2;78;3;1012;2"
2019-07-19 22:05:41.037 Status: dzVents: Info: ------ Start internal script: 02_vijverpomp: Device: "Buitentemp+Hum+Baro (Weer)", Index: 412
2019-07-19 22:05:41.039 Status: dzVents: Info: De vijver mag uit.
2019-07-19 22:05:41.039 Status: dzVents: Info: ------ Finished 02_vijverpomp
2019-07-19 22:05:41.062 Status: LUA: WU Script Parsed Temp=19.2 Humidity=78 Pressure=1012
2019-07-19 22:05:41.813 Status: (Zigate) Zigate set to Certification : CE
2019-07-19 22:05:41.814 Status: (Zigate) Start Web Server connection
2019-07-19 22:05:41.824 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-07-19 22:05:41.824 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-19 22:05:42.222 (Zigate) checkPluginVersion - Available Plugin Versions are, stable: 4.3.5 , beta: 4.4.12
2019-07-19 22:05:42.222 (Zigate) checkPluginVersion - Available Firmware Version is, Major: 0003 , Minor: 031a
2019-07-19 22:05:42.222 (Zigate) checkPluginUpdate - 4.4.12 4.4.12
2019-07-19 22:05:42.222 (Zigate) checkFirmwareUpdate - Firmware update available
2019-07-19 22:05:42.222 Status: (Zigate) There is a newer Zigate Firmware version available
2019-07-19 22:05:42.325 (Slimme meter) P1 Smart Meter (Slimme meter Elektra)
2019-07-19 22:05:42.327 (Slimme meter) Usage (Usage L1)
2019-07-19 22:05:42.328 (Slimme meter) Usage (Delivery L1)
2019-07-19 22:05:43.174 MQTT: Topic: domoticz/in, Message: {"idx":329,"RSSI":6,"nvalue":0,"svalue":"3.00;32391.00"}
2019-07-19 22:05:48.205 MQTT: Topic: domoticz/in, Message: {"idx":332,"RSSI":6,"nvalue":0,"svalue":"8.00;1698.00;8122.00"}
2019-07-19 22:05:52.349 (Slimme meter) P1 Smart Meter (Slimme meter Elektra)
2019-07-19 22:05:52.359 (Slimme meter) Usage (Usage L1)
2019-07-19 22:05:52.363 (Slimme meter) Usage (Delivery L1)
My last back up of 22:00 is at 18-07-2019 so domoticz does not complete the back up.
With the zigate plugin on the stable branch, not have crashes today
Ok. This give me some hint. Will let you know when to test an updated version of beta
I pushed one more change on beta. Would be glad if you could test it for a while .
twoenter
Domoticz runs without any problem for 12 hours now.
Thanks pipiche!
Thanks pipiche!
twoenter
Re: Compatibility Zigate, CC2531 and Synology nas
For those who also want to have a working zigbee router based on the cc2531 chip, check my blog where i have written an article about flashing and configuring the cc2531 chip to work with zigate and the zigate domoticz plugin.
https://www.twoenter.nl/blog/en/overig/ ... ee-router/
For Dutch users
https://www.twoenter.nl/blog/domotica/v ... ee-router/
For Dutch users
keros
Hello twoenter, hello pipiche, hello all !!
I'm facing the same issue, that's why I reply to this topic.
In my case, the Zigate using USB is working fine. But with Wifi, it's more complicated : I can loose my Aqara sensor informations after a few hours.
I brought the Zigate last month.I reflashed the wifi module this afternoon.
This is an exemple of my log this evening :
Note : the access to the zigate admin web page is very long, even unreachable some times (have to plug and un plug).
Note also : if I do not select I select /dev/serial0 as serial port, the raspberry pi will start to reboot and reboot without ending. I had to unplug the power to be able to restart normaly and have time to go to the seetings and found that /dev/serial0 was the good one for the Wifi model.
I'm trying right now without the automatic updates of the database. I'll keep you updated.
2019-07-27 00:00:01.868 Status: Starting automatic database backup procedure...
2019-07-27 00:00:05.971 Status: Ending automatic database backup procedure...
2019-07-27 00:02:33.490 Status: (Zigate) onDisconnect called
2019-07-27 00:23:28.173 Error: (Zigate) retreiveTimeOut_Motion - Database error: database disk image is malformed
2019-07-27 00:23:28.174 Error: (Zigate) 'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() > int()'.
2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 737 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 600 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 1327 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function ResetDeviceNote also : if I do not select I select /dev/serial0 as serial port, the raspberry pi will start to reboot and reboot without ending. I had to unplug the power to be able to restart normaly and have time to go to the seetings and found that /dev/serial0 was the good one for the Wifi model.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
keros
I didn't think that I would come back so shortly...
I restart my Raspberry Pi before going to sleep (in order to reset every thing) and it kept on rebooting.
At that moment, the admin page of the zigate was down.
Here is on of the log I received.
I had ton unplug/plug the Wifi Zigate in order to make the things working again.
Durring that moment, my sensors were recorded but with exacly the same tempreture enven if it was decreasing. I have a plot every 5 minutes between 00:00 and 00:30 (all on the same horrizontal line). After I don't have any data until 01h25 (line going down).
2019-07-27 01:19:25.512 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 01:19:25.513 Status: (Zigate) onDisconnect called Durring that moment, my sensors were recorded but with exacly the same tempreture enven if it was decreasing. I have a plot every 5 minutes between 00:00 and 00:30 (all on the same horrizontal line). After I don't have any data until 01h25 (line going down).
keros
I comme back after the night. I had somme errors after my Raspberry restart at 06h30 (the restart is schedulded at 6:30).
Here is the log :
This lines were repeated 7000 times in only 5 seconds :
Those thousands of error in a few seconds can explain why the raspberry keeps on rebooting some times.
Here is the log :
2019-07-27 06:30:43.355 Status: Domoticz V4.11031 (c)2012-2019 GizMoCuz
2019-07-27 06:30:43.356 Status: Build Hash: ad1a5b2ac, Date: 2019-07-26 06:20:37
2019-07-27 06:30:43.357 Status: Startup Path: /home/pi/domoticz/
2019-07-27 06:30:43.549 Sunrise: 06:32:00 SunSet: 21:26:00
2019-07-27 06:30:43.549 Day length: 14:54:00 Sun at south: 13:59:00
2019-07-27 06:30:43.549 Civil twilight start: 05:58:00 Civil twilight end: 22:00:00
2019-07-27 06:30:43.549 Nautical twilight start: 05:14:00 Nautical twilight end: 22:44:00
2019-07-27 06:30:43.549 Astronomical twilight start: 04:23:00 Astronomical twilight end: 23:36:00
2019-07-27 06:30:44.413 Status: PluginSystem: Started, Python version '3.5.3'.
2019-07-27 06:30:44.422 Active notification Subsystems: (0/13)
2019-07-27 06:30:44.460 Status: WebServer(HTTP) started on address: :: with port 8080
2019-07-27 06:30:44.483 Status: WebServer(SSL) started on address: :: with port 443
2019-07-27 06:30:44.529 Starting shared server on: :::6144
2019-07-27 06:30:44.529 Status: TCPServer: shared server started...
2019-07-27 06:30:44.530 Status: RxQueue: queue worker started...
2019-07-27 06:30:46.530 Status: GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!
2019-07-27 06:30:46.546 Status: (Zigate) Started.
2019-07-27 06:30:46.546 Status: (Teleinfo) Teleinfo device uses serial port: /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_TINFO-1063-if00-port0 at 1200 bauds
2019-07-27 06:30:46.551 Status: (Teleinfo) CRC checks will be performed on incoming data
2019-07-27 06:30:46.552 Status: EventSystem: reset all events...
2019-07-27 06:30:46.566 Status: EventSystem: reset all device statuses...
2019-07-27 06:30:46.689 Status: Python EventSystem: Initalizing event module.
2019-07-27 06:30:46.690 Status: EventSystem: Started
2019-07-27 06:30:46.690 Status: EventSystem: Queue thread started...
2019-07-27 06:30:46.703 Status: PluginSystem: Entering work loop.
2019-07-27 06:30:46.770 Status: (Teleinfo) Teleinfo CRC check mode set to 1
2019-07-27 06:30:47.183 Status: (Zigate) Entering work loop.
2019-07-27 06:30:47.190 Status: (Zigate) Initialized version 4.3.2, author 'zaraki673 pipiche38'
2019-07-27 06:30:47.209 Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 06:30:47.209 (Zigate) Debug: 4
2019-07-27 06:30:47.209 (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 06:30:47.211 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516]
2019-07-27 06:30:47.211 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 06:30:47.211 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 06:30:47.211 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 06:30:47.211 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 06:30:47.235 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 06:30:47.268 Status: (Zigate) load PluginConf
2019-07-27 06:30:47.270 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 06:30:47.273 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-07-27 06:30:47.273 Status: (Zigate) -enablegroupmanagement: 0
2019-07-27 06:30:47.273 Status: (Zigate) -resetMotiondelay: 30
2019-07-27 06:30:47.274 Status: (Zigate) -logFORMAT: 0
2019-07-27 06:30:47.274 Status: (Zigate) -logLQI: 0
2019-07-27 06:30:47.274 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 06:30:47.296 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 06:30:47.372 Status: (Zigate) DeviceConf loaded
2019-07-27 06:30:47.372 Status: (Zigate) load ListOfDevice
2019-07-27 06:30:47.564 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 06:30:47.574 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 06:30:47.574 (Zigate) Heartbeat interval set to: 5.
2019-07-27 06:30:47.593 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:47.593 (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:47.594 Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:47.594 (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.594 (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.594 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:47.596 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:47.596 (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:47.596 Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:47.596 (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.596 (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.596 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
35000 Error code lines deleted
2019-07-27 06:30:52.556 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.556 (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.557 Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:52.557 (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.557 (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.557 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:52.557 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.557 (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.558 (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.558 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:52.558 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.558 (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.558 Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:52.558 (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.559 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.559 (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.559 Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:52.559 (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.559 (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.559 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:52.614 Status: (Zigate) Reconnected after failure
2019-07-27 06:30:52.615 (Zigate) Configure Permit To Join
2019-07-27 06:30:52.615 (Zigate) Request discovery mode for 180 seconds
2019-07-27 06:30:52.666 Status: (Zigate) Major Version Num: 0003
2019-07-27 06:30:52.667 Status: (Zigate) Installer Version Number: 030f
2019-07-27 06:30:52.769 Status: (Zigate) Zigate in Permit Join: On
2019-07-27 06:30:52.824 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 06:30:52.824 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 06:30:52.879 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 06:30:57.289 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 06:45:50.955 Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 06:45:51.956 Error: Restarting: Zigate
2019-07-27 06:45:51.956 Status: (Zigate) Stop directive received.
2019-07-27 06:45:51.957 Status: (Zigate) Exiting work loop.
2019-07-27 06:45:52.033 Status: (Zigate) onDisconnect called
2019-07-27 06:45:52.033 Status: (Zigate) onStop called
2019-07-27 06:45:52.223 Status: (Zigate) Statistics on message
2019-07-27 06:45:52.224 Status: (Zigate) Sent:
2019-07-27 06:45:52.224 Status: (Zigate) TX commands : 7
2019-07-27 06:45:52.224 Status: (Zigate) Max Load (Queue) : 4
2019-07-27 06:45:52.224 Status: (Zigate) TX failed : 0 (0.0%)
2019-07-27 06:45:52.224 Status: (Zigate) TX timeout : 0 (0.0%)
2019-07-27 06:45:52.224 Status: (Zigate) TX data timeout : 0 (0.0%)
2019-07-27 06:45:52.224 Status: (Zigate) TX reTransmit : 0 (0.0%)
2019-07-27 06:45:52.224 Status: (Zigate) Received:
2019-07-27 06:45:52.224 Status: (Zigate) RX frame : 44
2019-07-27 06:45:52.225 Status: (Zigate) RX crc errors : 0 (0.0%)
2019-07-27 06:45:52.225 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2019-07-27 06:45:52.225 Status: (Zigate) RX clusters : 31
2019-07-27 06:45:52.225 Status: (Zigate) RX clusters KO : 0
2019-07-27 06:45:52.225 Status: (Zigate) Operating time : 0 Hours 15 Mins 5 Secs
2019-07-27 06:45:52.357 Status: (Zigate) Stopping threads.
2019-07-27 06:45:52.357 Status: (Zigate) Stopped.
2019-07-27 06:45:52.357 Status: (Zigate) Started.
2019-07-27 06:45:52.562 Status: (Zigate) Entering work loop.
2019-07-27 06:45:52.563 Status: (Zigate) Initialized version 4.3.2, author 'zaraki673 pipiche38'
2019-07-27 06:45:52.574 Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 06:45:52.574 (Zigate) Debug: 4
2019-07-27 06:45:52.574 (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 06:45:52.576 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 06:45:52.576 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 06:45:52.576 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 06:45:52.576 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 06:45:52.576 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 06:45:52.582 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 06:45:52.583 Status: (Zigate) load PluginConf
2019-07-27 06:45:52.583 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 06:45:52.584 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-07-27 06:45:52.584 Status: (Zigate) -enablegroupmanagement: 0
2019-07-27 06:45:52.584 Status: (Zigate) -resetMotiondelay: 30
2019-07-27 06:45:52.584 Status: (Zigate) -logFORMAT: 0
2019-07-27 06:45:52.584 Status: (Zigate) -logLQI: 0
2019-07-27 06:45:52.584 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 06:45:52.586 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 06:45:52.603 Status: (Zigate) DeviceConf loaded
2019-07-27 06:45:52.603 Status: (Zigate) load ListOfDevice
2019-07-27 06:45:52.636 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 06:45:52.640 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 06:45:52.640 (Zigate) Heartbeat interval set to: 5.
2019-07-27 06:45:52.691 (Zigate) Configure Permit To Join
2019-07-27 06:45:52.691 (Zigate) Request discovery mode for 180 seconds
2019-07-27 06:45:52.743 Status: (Zigate) Major Version Num: 0003
2019-07-27 06:45:52.743 Status: (Zigate) Installer Version Number: 030f
2019-07-27 06:45:52.845 Status: (Zigate) Zigate in Permit Join: On
2019-07-27 06:45:52.900 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 06:45:52.900 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 06:45:52.954 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 06:46:02.574 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:01:03.397 Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 07:01:04.398 Error: Restarting: Zigate
2019-07-27 07:01:04.398 Status: (Zigate) Stop directive received.
2019-07-27 07:01:04.398 Status: (Zigate) Exiting work loop.
2019-07-27 07:01:04.485 Status: (Zigate) onDisconnect called
2019-07-27 07:01:04.486 Status: (Zigate) onStop called
2019-07-27 07:01:04.538 Status: (Zigate) Statistics on message
2019-07-27 07:01:04.538 Status: (Zigate) Sent:
2019-07-27 07:01:04.538 Status: (Zigate) TX commands : 5
2019-07-27 07:01:04.538 Status: (Zigate) Max Load (Queue) : 4
2019-07-27 07:01:04.539 Status: (Zigate) TX failed : 0 (0.0%)
2019-07-27 07:01:04.539 Status: (Zigate) TX timeout : 0 (0.0%)
2019-07-27 07:01:04.539 Status: (Zigate) TX data timeout : 0 (0.0%)
2019-07-27 07:01:04.539 Status: (Zigate) TX reTransmit : 0 (0.0%)
2019-07-27 07:01:04.539 Status: (Zigate) Received:
2019-07-27 07:01:04.539 Status: (Zigate) RX frame : 52
2019-07-27 07:01:04.539 Status: (Zigate) RX crc errors : 0 (0.0%)
2019-07-27 07:01:04.539 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2019-07-27 07:01:04.540 Status: (Zigate) RX clusters : 43
2019-07-27 07:01:04.540 Status: (Zigate) RX clusters KO : 0
2019-07-27 07:01:04.540 Status: (Zigate) Operating time : 0 Hours 15 Mins 12 Secs
2019-07-27 07:01:04.699 Status: (Zigate) Stopping threads.
2019-07-27 07:01:04.699 Status: (Zigate) Stopped.
2019-07-27 07:01:04.699 Status: (Zigate) Started.
2019-07-27 07:01:04.929 Status: (Zigate) Entering work loop.
2019-07-27 07:01:04.930 Status: (Zigate) Initialized version 4.3.2, author 'zaraki673 pipiche38'
2019-07-27 07:01:04.941 Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:01:04.941 (Zigate) Debug: 4
2019-07-27 07:01:04.941 (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:01:04.943 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:01:04.943 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:01:04.943 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:01:04.943 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:01:04.943 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:01:04.949 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:01:04.950 Status: (Zigate) load PluginConf
2019-07-27 07:01:04.950 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:01:04.951 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-07-27 07:01:04.951 Status: (Zigate) -enablegroupmanagement: 0
2019-07-27 07:01:04.951 Status: (Zigate) -resetMotiondelay: 30
2019-07-27 07:01:04.951 Status: (Zigate) -logFORMAT: 0
2019-07-27 07:01:04.951 Status: (Zigate) -logLQI: 0
2019-07-27 07:01:04.951 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:01:04.955 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:01:04.971 Status: (Zigate) DeviceConf loaded
2019-07-27 07:01:04.971 Status: (Zigate) load ListOfDevice
2019-07-27 07:01:05.004 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:01:05.008 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:01:05.009 (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:01:05.059 (Zigate) Configure Permit To Join
2019-07-27 07:01:05.060 (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:01:05.111 Status: (Zigate) Major Version Num: 0003
2019-07-27 07:01:05.111 Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:01:05.213 Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:01:05.266 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:01:05.266 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:01:05.321 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:01:14.937 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:15:50.133 (Zigate) processListOfDevices - Device: 854e is in Status = 'Left' for 392256HB
2019-07-27 07:16:15.862 Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 07:16:16.863 Error: Restarting: Zigate
2019-07-27 07:16:16.863 Status: (Zigate) Stop directive received.
2019-07-27 07:16:16.864 Status: (Zigate) Exiting work loop.
2019-07-27 07:16:16.883 Status: (Zigate) onDisconnect called
2019-07-27 07:16:16.883 Status: (Zigate) onStop called
2019-07-27 07:16:16.937 Status: (Zigate) Statistics on message
2019-07-27 07:16:16.937 Status: (Zigate) Sent:
2019-07-27 07:16:16.938 Status: (Zigate) TX commands : 6
2019-07-27 07:16:16.938 Status: (Zigate) Max Load (Queue) : 4
2019-07-27 07:16:16.938 Status: (Zigate) TX failed : 0 (0.0%)
2019-07-27 07:16:16.938 Status: (Zigate) TX timeout : 0 (0.0%)
2019-07-27 07:16:16.938 Status: (Zigate) TX data timeout : 0 (0.0%)
2019-07-27 07:16:16.938 Status: (Zigate) TX reTransmit : 0 (0.0%)
2019-07-27 07:16:16.938 Status: (Zigate) Received:
2019-07-27 07:16:16.938 Status: (Zigate) RX frame : 41
2019-07-27 07:16:16.938 Status: (Zigate) RX crc errors : 0 (0.0%)
2019-07-27 07:16:16.938 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2019-07-27 07:16:16.938 Status: (Zigate) RX clusters : 30
2019-07-27 07:16:16.938 Status: (Zigate) RX clusters KO : 0
2019-07-27 07:16:16.938 Status: (Zigate) Operating time : 0 Hours 15 Mins 11 Secs
2019-07-27 07:16:17.064 Status: (Zigate) Stopping threads.
2019-07-27 07:16:17.064 Status: (Zigate) Stopped.
2019-07-27 07:16:17.064 Status: (Zigate) Started.
2019-07-27 07:16:17.303 Status: (Zigate) Entering work loop.
2019-07-27 07:16:17.304 Status: (Zigate) Initialized version 4.3.2, author 'zaraki673 pipiche38'
2019-07-27 07:16:17.315 Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:16:17.315 (Zigate) Debug: 4
2019-07-27 07:16:17.315 (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:16:17.317 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:16:17.317 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:16:17.317 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:16:17.317 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:16:17.317 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:16:17.324 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:16:17.325 Status: (Zigate) load PluginConf
2019-07-27 07:16:17.325 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:16:17.326 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-07-27 07:16:17.326 Status: (Zigate) -enablegroupmanagement: 0
2019-07-27 07:16:17.326 Status: (Zigate) -resetMotiondelay: 30
2019-07-27 07:16:17.326 Status: (Zigate) -logFORMAT: 0
2019-07-27 07:16:17.326 Status: (Zigate) -logLQI: 0
2019-07-27 07:16:17.326 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:16:17.329 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:16:17.346 Status: (Zigate) DeviceConf loaded
2019-07-27 07:16:17.346 Status: (Zigate) load ListOfDevice
2019-07-27 07:16:17.381 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:16:17.385 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:16:17.385 (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:16:17.436 (Zigate) Configure Permit To Join
2019-07-27 07:16:17.436 (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:16:17.488 Status: (Zigate) Major Version Num: 0003
2019-07-27 07:16:17.488 Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:16:17.590 Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:16:17.644 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:16:17.644 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:16:17.698 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:16:27.316 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:31:29.221 Error: Restarting: Zigate
2019-07-27 07:31:29.222 Status: (Zigate) Stop directive received.
2019-07-27 07:31:29.222 Status: (Zigate) Exiting work loop.
2019-07-27 07:31:29.226 Status: (Zigate) onDisconnect called
2019-07-27 07:31:29.227 Status: (Zigate) onStop called
2019-07-27 07:31:29.279 Status: (Zigate) Statistics on message
2019-07-27 07:31:29.279 Status: (Zigate) Sent:
2019-07-27 07:31:29.279 Status: (Zigate) TX commands : 8
2019-07-27 07:31:29.279 Status: (Zigate) Max Load (Queue) : 4
2019-07-27 07:31:29.279 Status: (Zigate) TX failed : 0 (0.0%)
2019-07-27 07:31:29.279 Status: (Zigate) TX timeout : 0 (0.0%)
2019-07-27 07:31:29.279 Status: (Zigate) TX data timeout : 0 (0.0%)
2019-07-27 07:31:29.280 Status: (Zigate) TX reTransmit : 0 (0.0%)
2019-07-27 07:31:29.280 Status: (Zigate) Received:
2019-07-27 07:31:29.280 Status: (Zigate) RX frame : 20
2019-07-27 07:31:29.280 Status: (Zigate) RX crc errors : 0 (0.0%)
2019-07-27 07:31:29.280 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2019-07-27 07:31:29.280 Status: (Zigate) RX clusters : 5
2019-07-27 07:31:29.280 Status: (Zigate) RX clusters KO : 0
2019-07-27 07:31:29.280 Status: (Zigate) Operating time : 0 Hours 15 Mins 12 Secs
2019-07-27 07:31:29.422 Status: (Zigate) Stopping threads.
2019-07-27 07:31:29.422 Status: (Zigate) Stopped.
2019-07-27 07:31:29.422 Status: (Zigate) Started.
2019-07-27 07:31:29.658 Status: (Zigate) Entering work loop.
2019-07-27 07:31:29.659 Status: (Zigate) Initialized version 4.3.2, author 'zaraki673 pipiche38'
2019-07-27 07:31:29.670 Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:31:29.670 (Zigate) Debug: 4
2019-07-27 07:31:29.670 (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:31:29.671 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:31:29.672 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:31:29.672 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:31:29.672 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:31:29.672 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:31:29.678 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:31:29.679 Status: (Zigate) load PluginConf
2019-07-27 07:31:29.679 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:31:29.680 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-07-27 07:31:29.680 Status: (Zigate) -enablegroupmanagement: 0
2019-07-27 07:31:29.680 Status: (Zigate) -resetMotiondelay: 30
2019-07-27 07:31:29.680 Status: (Zigate) -logFORMAT: 0
2019-07-27 07:31:29.680 Status: (Zigate) -logLQI: 0
2019-07-27 07:31:29.680 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:31:29.682 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:31:29.697 Status: (Zigate) DeviceConf loaded
2019-07-27 07:31:29.698 Status: (Zigate) load ListOfDevice
2019-07-27 07:31:29.731 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:31:29.735 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:31:29.735 (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:31:29.786 (Zigate) Configure Permit To Join
2019-07-27 07:31:29.786 (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:31:29.837 Status: (Zigate) Major Version Num: 0003
2019-07-27 07:31:29.837 Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:31:29.939 Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:31:29.992 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:31:29.992 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:31:30.048 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:31:39.667 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:46:40.643 Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 07:46:41.644 Error: Restarting: Zigate
2019-07-27 07:46:41.644 Status: (Zigate) Stop directive received.
2019-07-27 07:46:41.646 Status: (Zigate) Exiting work loop.
2019-07-27 07:46:41.668 Status: (Zigate) onDisconnect called
2019-07-27 07:46:41.668 Status: (Zigate) onStop called
2019-07-27 07:46:41.720 Status: (Zigate) Statistics on message
2019-07-27 07:46:41.720 Status: (Zigate) Sent:
2019-07-27 07:46:41.721 Status: (Zigate) TX commands : 8
2019-07-27 07:46:41.721 Status: (Zigate) Max Load (Queue) : 4
2019-07-27 07:46:41.721 Status: (Zigate) TX failed : 0 (0.0%)
2019-07-27 07:46:41.721 Status: (Zigate) TX timeout : 0 (0.0%)
2019-07-27 07:46:41.721 Status: (Zigate) TX data timeout : 0 (0.0%)
2019-07-27 07:46:41.721 Status: (Zigate) TX reTransmit : 0 (0.0%)
2019-07-27 07:46:41.721 Status: (Zigate) Received:
2019-07-27 07:46:41.721 Status: (Zigate) RX frame : 18
2019-07-27 07:46:41.721 Status: (Zigate) RX crc errors : 0 (0.0%)
2019-07-27 07:46:41.722 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2019-07-27 07:46:41.722 Status: (Zigate) RX clusters : 3
2019-07-27 07:46:41.722 Status: (Zigate) RX clusters KO : 0
2019-07-27 07:46:41.722 Status: (Zigate) Operating time : 0 Hours 15 Mins 12 Secs
2019-07-27 07:46:41.846 Status: (Zigate) Stopping threads.
2019-07-27 07:46:41.847 Status: (Zigate) Stopped.
2019-07-27 07:46:41.847 Status: (Zigate) Started.
2019-07-27 07:46:42.095 Status: (Zigate) Entering work loop.
2019-07-27 07:46:42.096 Status: (Zigate) Initialized version 4.3.2, author 'zaraki673 pipiche38'
2019-07-27 07:46:42.107 Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:46:42.107 (Zigate) Debug: 4
2019-07-27 07:46:42.107 (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:46:42.109 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:46:42.109 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:46:42.109 Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:46:42.109 Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:46:42.109 Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:46:42.115 Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:46:42.116 Status: (Zigate) load PluginConf
2019-07-27 07:46:42.116 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:46:42.117 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-07-27 07:46:42.117 Status: (Zigate) -enablegroupmanagement: 0
2019-07-27 07:46:42.117 Status: (Zigate) -resetMotiondelay: 30
2019-07-27 07:46:42.117 Status: (Zigate) -logFORMAT: 0
2019-07-27 07:46:42.117 Status: (Zigate) -logLQI: 0
2019-07-27 07:46:42.117 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:46:42.119 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:46:42.135 Status: (Zigate) DeviceConf loaded
2019-07-27 07:46:42.135 Status: (Zigate) load ListOfDevice
2019-07-27 07:46:42.169 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:46:42.173 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:46:42.173 (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:46:42.224 (Zigate) Configure Permit To Join
2019-07-27 07:46:42.224 (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:46:42.275 Status: (Zigate) Major Version Num: 0003
2019-07-27 07:46:42.275 Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:46:42.377 Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:46:42.430 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:46:42.430 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:46:42.486 Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:46:52.106 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:49:12.166 (Zigate) processListOfDevices - Device: 854e is in Status = 'Left' for 392652HB
2019-07-27 07:52:12.170 (Zigate) processListOfDevices - Device: 854e is in Status = 'Left' for 392688HB
2019-07-27 07:52:39.580 (Zigate) UpdateDevice - (Sonde 5 : Extérieur Sud) 0:22.8;65.4;1;989.3;4
2019-07-27 07:52:39.583 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002d7df32-01) 0:22.8;65.4;1
2019-07-27 07:52:39.589 (Zigate) UpdateDevice - (Sonde 5 : Extérieur Sud) 0:22.8;65.4;1;989.0;4
2019-07-27 07:52:39.595 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002d7df32-01) 0:989.0;4
2019-07-27 07:52:39.601 (Zigate) UpdateDevice - (Sonde 5 : Extérieur Sud) 0:22.8;65.4;1;989.2;4
2019-07-27 07:52:39.606 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002d7df32-01) 0:989.2;4
2019-07-27 07:52:52.138 (Zigate) UpdateDevice - ( Sonde 5) 0:25.1;65.8;1;988.8;4
2019-07-27 07:52:52.141 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f2ec2a-01) 0:25.1;65.8;1
2019-07-27 07:52:52.144 (Zigate) UpdateDevice - (Sonde T6 : Chambre Parents) 25.1:25.1
2019-07-27 07:52:52.148 (Zigate) UpdateDevice - ( Sonde 5) 0:25.1;65.5;1;988.8;4
2019-07-27 07:52:52.151 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f2ec2a-01) 0:25.1;65.5;1
2019-07-27 07:52:52.155 (Zigate) UpdateDevice - ( Sonde 5) 0:25.1;65.5;1;988.7;4
2019-07-27 07:52:52.160 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f2ec2a-01) 0:988.7;4
2019-07-27 07:53:01.389 (Zigate) UpdateDevice - (Sonde T3 : Zigate - lumi.weather_Temp+Hum+Baro-00158d0002d7e00b-01) 0:23.6;77.7;3;989.3;4
2019-07-27 07:53:01.392 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002d7e00b-01) 0:23.6;77.7;3
2019-07-27 07:53:01.398 (Zigate) UpdateDevice - (Sonde T3 : Zigate - lumi.weather_Temp+Hum+Baro-00158d0002d7e00b-01) 0:23.6;77.7;3;989.0;4
2019-07-27 07:53:01.403 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002d7e00b-01) 0:989.0;4Code: Select all
Which version/branch of the plugin are you using ? Indeed there is is a relation with the auto-backup of domoticzkeros wrote:Hello twoenter, hello pipiche, hello all !!
Note : the access to the zigate admin web page is very long, even unreachable some times (have to plug and un plug).Code: Select all
2019-07-27 00:00:01.868 Status: Starting automatic database backup procedure... 2019-07-27 00:00:05.971 Status: Ending automatic database backup procedure... 2019-07-27 00:02:33.490 Status: (Zigate) onDisconnect called 2019-07-27 00:23:28.173 Error: (Zigate) retreiveTimeOut_Motion - Database error: database disk image is malformed 2019-07-27 00:23:28.174 Error: (Zigate) 'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() > int()'. 2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 737 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat 2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 600 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat 2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 1327 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function ResetDevice
If you have the possibility to switch to beta branch this is issue is addressed
keros
Thank you Pipiche for you're help and also all the work you've done !!
I switch to beta and that is the log I got in my log after my Raspberry Restart.
Is it normal ?
I'll tell you if some thing new commes. Thank you once again
2019-07-27 12:04:42.461 Status: (Zigate) Entering work loop.
2019-07-27 12:04:42.474 Status: (Zigate) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-07-27 12:04:42.500 Status: (Zigate) Zigate plugin beta-4.6.001 started
2019-07-27 12:04:42.501 Error: (Zigate) 'onStart' failed 'AttributeError':''NoneType' object has no attribute 'pluginConf''.
2019-07-27 12:04:42.501 Error: (Zigate) ----> Line 804 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-07-27 12:04:42.501 Error: (Zigate) ----> Line 204 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-07-27 12:04:42.501 Error: (Zigate) ----> Line 524 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/tools.py', function loggingPlugin I'll tell you if some thing new commes. Thank you once again
Not normal, will investigate and revert
Got it. You have set Debug mode to something else than None, correct ?
If you do a git pull to get the latest update, this should be fixed.
keros
I didn't recevied after the moment I switched to beta.
When I came back, after lunch, I wasn't able to reach the zigate web admin page. I unpluged/repluged it.
I just did a git pull, a restart, and now the data are slowly comming back (wating for the dashboard update).
I had some troubles with the zigate wifi since the begining for me (15th june) so I set the plugin debug to Domoticz Plugin.
