Compatibility Zigate and Synology nas Topic is solved
pipiche
Re: Compatibility Zigate and Synology nas
Post by pipiche »
Could you try to do a git pull in order to update the plugin, and do a Domoticz restart.
twoenter
Domoticz version: 4.10
Post by twoenter »
Johnny5 wrote: Thursday 18 July 2019 23:17
twoenter wrote: Thursday 18 July 2019 6:02 Yes I have 3 Aqara motion sensors
Do you use this repeater? Have you assembled it by yourself?
https://www.zigbee2mqtt.io/how_tos/how_ ... outer.html
What is the longest distance where Xiaomi sensor connected to it?
I'm strungling with Xiaomi temp sensor to reach Zigate from about 8-10 meters. It's straight ahead on the porch. There are two big windows between them. Initialisation on Xiaomi sensor works then it loses the connection after several minutes. Swicthing wifi to 5Ghz didn't help on this problem.
I'm thinking about to move away Zigate using a USB extender cable from the place where my NAS and Wifi router are as well.
Thanks.
My repeater (router) is quite the same as your link. I'm using a CC2531 usb sniffer with a special router firmware witch now is supported by zigate.
My syno is at one side of the house, next to the front door. All the sensors are in less than 9 meters distance, 3x aqara motion sensor, 3x aqara temp+hum, 2x vibration sensor and 1x aqara door sensor. Between the zigate and the sensor are max 2 floors (window and vibration sensor), the others are on the first and ground floor.
When I look into the meshnetwork in de webadmin page of zigate I see everyting is connected directly to the zigate, none of the devices does use the router?. Maybe in interpretet the diagram wrong? I do not experience structural connection errors, sometimes the window sensor fails to connect. I want to find out how to (force) connect it to the router.
pipiche wrote: Friday 19 July 2019 9:15
twoenter wrote:This is the only error I still have :
2019-07-19 05:48:20.499 Error: (Zigate) retreiveTimeOut_Motion - Database error: database disk image is malformed
There is one for motion, baro and temp
Do you have domoticz backup enabled ?
Yes I have.
pipiche wrote: Friday 19 July 2019 11:27 Could you try to do a git pull in order to update the plugin, and do a Domoticz restart.
will do that tonight. Thanks
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
pipiche
Post by pipiche »
Best would be to be on 'beta' branch and have beta-4.4.13
twoenter
Post by twoenter »
pipiche wrote: Friday 19 July 2019 23:25 Best would be to be on 'beta' branch and have beta-4.4.13
Okay, I'm having domoticz crashes since I have updated the plugin. There is no newer version of domoticz available for synology. I think I switch back to stable plugin and wait for a domoticz update.
pipiche
Post by pipiche »
Could you attached the log ?
In order to check if the problem is not related to the changes made
twoenter
Post by twoenter »
pipiche wrote: Saturday 20 July 2019 9:54 Could you attached the log ?
I dont see any errors...
I'm sure it has something to do with the backup. domoticz always crashes on the xx:00 hour.
2019-07-19 22:00:00.828  Status: Starting automatic database backup procedure...
After this message domoticz runs for like 1 second and prints only normal dzvents messages...
Around 22:05 I noticed domoticz was offline, so i restarted from DSM (Syno admin page)
2019-07-19 22:05:26.946  Status: Domoticz V4.10998 (c)2012-2019 GizMoCuz
2019-07-19 22:05:26.946  Status: Build Hash: d38fbc3-modified, Date: 2019-07-13 16:44:30
2019-07-19 22:05:26.947  Status: Startup Path: /usr/local/domoticz/
2019-07-19 22:05:26.994  Sunrise: 05:43:00 SunSet: 21:51:00
2019-07-19 22:05:26.994  Day length: 16:08:00 Sun at south: 13:47:00
2019-07-19 22:05:26.994  Civil twilight start: 04:59:00 Civil twilight end: 22:36:00
2019-07-19 22:05:26.994  Nautical twilight start: 03:54:00 Nautical twilight end: 23:41:00
2019-07-19 22:05:26.994  There is no astronomical twilight in the space of 24 hours
2019-07-19 22:05:28.206  Status: PluginSystem: Started, Python version '3.5.1'.
2019-07-19 22:05:28.217  Active notification Subsystems: gcm (1/13)
2019-07-19 22:05:28.255  Status: WebServer(HTTP) started on address: :: with port 8084
2019-07-19 22:05:28.305  Status: WebServer(SSL) started on address: :: with port 8443
2019-07-19 22:05:28.308  Starting shared server on: :::6144
2019-07-19 22:05:28.309  Status: TCPServer: shared server started...
2019-07-19 22:05:28.309  Status: RxQueue: queue worker started...
2019-07-19 22:05:30.310  Status: Hardware Monitor: Started
2019-07-19 22:05:30.331  Status: P1 Smart Meter: Using serial port: /dev/ttyUSB-216-P1-METER
2019-07-19 22:05:30.332  Status: P1 Smart Meter: Worker started...
2019-07-19 22:05:30.333  Status: RFXCOM: Worker started...
2019-07-19 22:05:30.333  Status: InComfort: Worker started...
2019-07-19 22:05:30.334  Status: WOL: Started
2019-07-19 22:05:30.334  Status: Pinger: Worker started...
2019-07-19 22:05:30.335  Status: Darksky: Started...
2019-07-19 22:05:30.335  Status: (Zigate) Started.
2019-07-19 22:05:30.335  Status: EventSystem: reset all events...
2019-07-19 22:05:30.368  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/16_trap.lua
2019-07-19 22:05:30.368  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/00_verlichting.lua
2019-07-19 22:05:30.369  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/global_data.lua
2019-07-19 22:05:30.369  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_Droger.lua
2019-07-19 22:05:30.369  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_wasmachine.lua
2019-07-19 22:05:30.370  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/17_MV.lua
2019-07-19 22:05:30.370  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/9_dekentje.lua
2019-07-19 22:05:30.370  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/14_relais.lua
2019-07-19 22:05:30.371  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/02_vijverpomp.lua
2019-07-19 22:05:30.371  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/10_regen_dzv.lua
2019-07-19 22:05:30.371  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_Droger3.lua
2019-07-19 22:05:30.372  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/13_Wasmachine.lua
2019-07-19 22:05:30.372  Status: EventSystem: reset all device statuses...
2019-07-19 22:05:30.570  Status: PluginSystem: Entering work loop.
2019-07-19 22:05:30.662  Status: Python EventSystem: Initalizing event module.
2019-07-19 22:05:30.663  Status: EventSystem: Queue thread started...
2019-07-19 22:05:30.663  Status: EventSystem: Started
2019-07-19 22:05:31.334  Status: RFXCOM: Using serial port: /dev/ttyUSB-216-RFX433E
2019-07-19 22:05:31.334  Status: MQTT: Connecting to localhost:1883
2019-07-19 22:05:31.436  Status: MQTT: connected to: localhost:1883
2019-07-19 22:05:31.536  Status: MQTT: Subscribed
2019-07-19 22:05:31.663  Status: (Zigate) Entering work loop.
2019-07-19 22:05:31.664  Status: (Zigate) Initialized version beta-4.4, author 'zaraki673  pipiche38'
2019-07-19 22:05:31.673  Status: (Zigate) Zigate plugin beta-4.4.12 started
2019-07-19 22:05:31.673  (Zigate) Debug: 0
2019-07-19 22:05:31.673  Status: (Zigate) Python Version - 3.5.1 (default, Jan 29 2018, 14:16:30)
[GCC 4.9.3 20150311 (prerelease)]
2019-07-19 22:05:31.673  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-19 22:05:31.673  Status: (Zigate) DomoticzVersion: 4.10998
2019-07-19 22:05:31.674  Status: (Zigate) DomoticzHash: d38fbc3-modified
2019-07-19 22:05:31.674  Status: (Zigate) DomoticzBuildTime: 2019-07-13 16:44:30
2019-07-19 22:05:31.674  Status: (Zigate) load PluginConf
2019-07-19 22:05:31.706  Status: P1 Smart Meter: Meter reports as DSMR 4.2
2019-07-19 22:05:31.715  Status: (Zigate) vibrationAqarasensitivity set to high
2019-07-19 22:05:31.715  Status: (Zigate) pluginOTAFirmware set to /usr/local/domoticz/var/plugins/Zigate/OTAFirmware/
2019-07-19 22:05:31.715  Status: (Zigate) pluginHome set to /usr/local/domoticz/var/plugins/Zigate/
2019-07-19 22:05:31.716  Status: (Zigate) pluginReports set to /usr/local/domoticz/var/plugins/Zigate/Reports/
2019-07-19 22:05:31.716  Status: (Zigate) pluginConfig set to /usr/local/domoticz/var/plugins/Zigate/Conf/
2019-07-19 22:05:31.725  Status: (Zigate) pluginData set to /usr/local/domoticz/var/plugins/Zigate/Data/
2019-07-19 22:05:31.725  Status: (Zigate) homedirectory set to /usr/local/domoticz/var/plugins/Zigate/
2019-07-19 22:05:31.725  Status: (Zigate) pluginWWW set to /usr/local/domoticz/var/plugins/Zigate/www/
2019-07-19 22:05:31.725  Status: (Zigate) filename set to /usr/local/domoticz/var/plugins/Zigate/Conf/PluginConf-27.json
2019-07-19 22:05:31.726  Status: (Zigate) Opening DomoticzDB in raw
2019-07-19 22:05:31.910
2019-07-19 22:05:32.057  subtype           = Interface Response
Sequence nbr      = 2
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 1019
Firmware type     = Ext2
Hardware version  = 1.3
Undec             off
X10               enabled
ARC               enabled
AC                enabled
HomeEasy EU       enabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic enabled
Visonic           disabled
Mertik            disabled
AD                disabled
Hideki            enabled
La Crosse         enabled
Legrand           disabled
MSG4Reserved5     disabled
BlindsT0          disabled
BlindsT1          disabled
AE                disabled
RUBiCSON          disabled
FineOffset        disabled
Lighting4         enabled
Conrad RSL        disabled
ByronSX           enabled
IMAGINTRONIX      disabled
KEELOQ            disabled
Home Confort      disabled
2019-07-19 22:05:32.117  Status: P1 Smart Meter: Found gas meter on M-Bus channel 1
2019-07-19 22:05:32.127  Status: (Zigate) Plugin Database: DeviceList-27.txt
2019-07-19 22:05:32.175  Status: (Zigate) DeviceConf loaded
2019-07-19 22:05:32.175  Status: (Zigate) load ListOfDevice
2019-07-19 22:05:32.263  Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Zigate/Data/DeviceList-27.txt : 9
2019-07-19 22:05:32.279  Status: (Zigate) Transport mode: USB
2019-07-19 22:05:32.280  Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB2
2019-07-19 22:05:32.282  Status: (Zigate) Configure Permit To Join
2019-07-19 22:05:32.282  Status: (Zigate) Request Accepting new Hardware for 254 seconds
2019-07-19 22:05:32.282  Status: (Zigate) Trigger a Topology Scan
2019-07-19 22:05:32.283  Status: (Zigate) Trigger a Energy Level Scan
2019-07-19 22:05:32.301  (Slimme meter) P1 Smart Meter (Slimme meter Elektra)
2019-07-19 22:05:32.309  (Slimme meter) Usage (Usage L1)
2019-07-19 22:05:32.311  (Slimme meter) Usage (Delivery L1)
2019-07-19 22:05:32.319  (Slimme meter) P1 Smart Meter (Gasmeter)
2019-07-19 22:05:32.385  Status: (Zigate) Major Version Num: 0003
2019-07-19 22:05:32.386  Status: (Zigate) Installer Version Number: 030f
2019-07-19 22:05:32.589  (Zigate) Permit Join status: 01
2019-07-19 22:05:32.589  (Zigate) ---> self.permitTojoin['Starttime']: 1563566732
2019-07-19 22:05:32.589  (Zigate) ---> Current time                  : 1563566732
2019-07-19 22:05:32.589  (Zigate) ---> self.Ping['Permit']  (prev)   : None
2019-07-19 22:05:32.589  Status: (Zigate) Accepting new Hardware: On
2019-07-19 22:05:32.589  (Zigate) ---> self.Ping['Permit']  (new )   : On
2019-07-19 22:05:32.706  Status: (Zigate) Zigate addresses ieee: 00158d0001ecaee0 , short addr: 0000
2019-07-19 22:05:32.706  Status: (Zigate) Network state UP, PANID: 3b73 extPANID: 0xd56cfb146c18053c Channel: 11
2019-07-19 22:05:32.836  Status: (Zigate) Number of devices recently active in Zigate = 7
2019-07-19 22:05:40.849  (Weer) Temp + Humidity + Baro (Buitentemp+Hum+Baro)
2019-07-19 22:05:40.869  (Weer) Wind (Wind)
2019-07-19 22:05:40.875  (Weer) UV (UV Index)
2019-07-19 22:05:40.882  (Weer) Rain (Rain)
2019-07-19 22:05:40.897  (Weer) General/Visibility (Zicht)
2019-07-19 22:05:40.908  (Weer) General/Custom Sensor (Ozone Sensor)
2019-07-19 22:05:40.909  (Weer) General/Percentage (Cloud Cover)
2019-07-19 22:05:41.016  Status: dzVents: Info:  Handling events for: "Buitentemp+Hum+Baro", value: "19.2;78;3;1012;2"
2019-07-19 22:05:41.037  Status: dzVents: Info:  ------ Start internal script: 02_vijverpomp: Device: "Buitentemp+Hum+Baro (Weer)", Index: 412
2019-07-19 22:05:41.039  Status: dzVents: Info:  De vijver mag uit.
2019-07-19 22:05:41.039  Status: dzVents: Info:  ------ Finished 02_vijverpomp
2019-07-19 22:05:41.062  Status: LUA: WU Script Parsed Temp=19.2 Humidity=78 Pressure=1012
2019-07-19 22:05:41.813  Status: (Zigate) Zigate set to Certification : CE
2019-07-19 22:05:41.814  Status: (Zigate) Start Web Server connection
2019-07-19 22:05:41.824  Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-07-19 22:05:41.824  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-19 22:05:42.222  (Zigate) checkPluginVersion - Available Plugin Versions are, stable: 4.3.5 , beta: 4.4.12
2019-07-19 22:05:42.222  (Zigate) checkPluginVersion - Available Firmware Version is, Major: 0003 , Minor: 031a
2019-07-19 22:05:42.222  (Zigate) checkPluginUpdate - 4.4.12 4.4.12
2019-07-19 22:05:42.222  (Zigate) checkFirmwareUpdate - Firmware update available
2019-07-19 22:05:42.222  Status: (Zigate) There is a newer Zigate Firmware version available
2019-07-19 22:05:42.325  (Slimme meter) P1 Smart Meter (Slimme meter Elektra)
2019-07-19 22:05:42.327  (Slimme meter) Usage (Usage L1)
2019-07-19 22:05:42.328  (Slimme meter) Usage (Delivery L1)
2019-07-19 22:05:43.174  MQTT: Topic: domoticz/in, Message: {"idx":329,"RSSI":6,"nvalue":0,"svalue":"3.00;32391.00"}
2019-07-19 22:05:48.205  MQTT: Topic: domoticz/in, Message: {"idx":332,"RSSI":6,"nvalue":0,"svalue":"8.00;1698.00;8122.00"}
2019-07-19 22:05:52.349  (Slimme meter) P1 Smart Meter (Slimme meter Elektra)
2019-07-19 22:05:52.359  (Slimme meter) Usage (Usage L1)
2019-07-19 22:05:52.363  (Slimme meter) Usage (Delivery L1)
domoticz start and runs like there happened nothing, until the next xx:00 hour...
My last back up of 22:00 is at 18-07-2019 so domoticz does not complete the back up.
With the zigate plugin on the stable branch, not have crashes today
pipiche
Post by pipiche »
Ok. This give me some hint. Will let you know when to test an updated version of beta
pipiche
Post by pipiche »
I pushed one more change on beta. Would be glad if you could test it for a while .
twoenter
Post by twoenter »
Domoticz runs without any problem for 12 hours now.
Thanks pipiche!
twoenter
Re: Compatibility Zigate, CC2531 and Synology nas
Post by twoenter »
For those who also want to have a working zigbee router based on the cc2531 chip, check my blog where i have written an article about flashing and configuring the cc2531 chip to work with zigate and the zigate domoticz plugin.
https://www.twoenter.nl/blog/en/overig/ ... ee-router/
For Dutch users
https://www.twoenter.nl/blog/domotica/v ... ee-router/
keros
Post by keros »
Hello twoenter, hello pipiche, hello all !!
I'm facing the same issue, that's why I reply to this topic.
In my case, the Zigate using USB is working fine. But with Wifi, it's more complicated : I can loose my Aqara sensor informations after a few hours.
I brought the Zigate last month.I reflashed the wifi module this afternoon.
This is an exemple of my log this evening :
2019-07-27 00:00:01.868 Status: Starting automatic database backup procedure...
2019-07-27 00:00:05.971 Status: Ending automatic database backup procedure...
2019-07-27 00:02:33.490 Status: (Zigate) onDisconnect called
2019-07-27 00:23:28.173 Error: (Zigate) retreiveTimeOut_Motion - Database error: database disk image is malformed
2019-07-27 00:23:28.174 Error: (Zigate) 'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() > int()'.
2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 737 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 600 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-07-27 00:23:28.176 Error: (Zigate) ----> Line 1327 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function ResetDevice
Note : the access to the zigate admin web page is very long, even unreachable some times (have to plug and un plug).
Note also : if I do not select I select /dev/serial0 as serial port, the raspberry pi will start to reboot and reboot without ending. I had to unplug the power to be able to restart normaly and have time to go to the seetings and found that /dev/serial0 was the good one for the Wifi model.
I'm trying right now without the automatic updates of the database. I'll keep you updated.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
keros
Post by keros »
I didn't think that I would come back so shortly...
I restart my Raspberry Pi before going to sleep (in order to reset every thing) and it kept on rebooting.
At that moment, the admin page of the zigate was down.
Here is on of the log I received.
2019-07-27 01:19:25.512 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 01:19:25.513 Status: (Zigate) onDisconnect called
I had ton unplug/plug the Wifi Zigate in order to make the things working again.
Durring that moment, my sensors were recorded but with exacly the same tempreture enven if it was decreasing. I have a plot every 5 minutes between 00:00 and 00:30 (all on the same horrizontal line). After I don't have any data until 01h25 (line going down).
Erreur temperature.jpg (36.12 KiB) Viewed 1619 times
keros
Post by keros »
I comme back after the night. I had somme errors after my Raspberry restart at 06h30 (the restart is schedulded at 6:30).
Here is the log :
2019-07-27 06:30:43.355  Status: Domoticz V4.11031 (c)2012-2019 GizMoCuz
2019-07-27 06:30:43.356  Status: Build Hash: ad1a5b2ac, Date: 2019-07-26 06:20:37
2019-07-27 06:30:43.357  Status: Startup Path: /home/pi/domoticz/
2019-07-27 06:30:43.549  Sunrise: 06:32:00 SunSet: 21:26:00
2019-07-27 06:30:43.549  Day length: 14:54:00 Sun at south: 13:59:00
2019-07-27 06:30:43.549  Civil twilight start: 05:58:00 Civil twilight end: 22:00:00
2019-07-27 06:30:43.549  Nautical twilight start: 05:14:00 Nautical twilight end: 22:44:00
2019-07-27 06:30:43.549  Astronomical twilight start: 04:23:00 Astronomical twilight end: 23:36:00
2019-07-27 06:30:44.413  Status: PluginSystem: Started, Python version '3.5.3'.
2019-07-27 06:30:44.422  Active notification Subsystems: (0/13)
2019-07-27 06:30:44.460  Status: WebServer(HTTP) started on address: :: with port 8080
2019-07-27 06:30:44.483  Status: WebServer(SSL) started on address: :: with port 443
2019-07-27 06:30:44.529  Starting shared server on: :::6144
2019-07-27 06:30:44.529  Status: TCPServer: shared server started...
2019-07-27 06:30:44.530  Status: RxQueue: queue worker started...
2019-07-27 06:30:46.530  Status: GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!
2019-07-27 06:30:46.546  Status: (Zigate) Started.
2019-07-27 06:30:46.546  Status: (Teleinfo) Teleinfo device uses serial port: /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_TINFO-1063-if00-port0 at 1200 bauds
2019-07-27 06:30:46.551  Status: (Teleinfo) CRC checks will be performed on incoming data
2019-07-27 06:30:46.552  Status: EventSystem: reset all events...
2019-07-27 06:30:46.566  Status: EventSystem: reset all device statuses...
2019-07-27 06:30:46.689  Status: Python EventSystem: Initalizing event module.
2019-07-27 06:30:46.690  Status: EventSystem: Started
2019-07-27 06:30:46.690  Status: EventSystem: Queue thread started...
2019-07-27 06:30:46.703  Status: PluginSystem: Entering work loop.
2019-07-27 06:30:46.770  Status: (Teleinfo) Teleinfo CRC check mode set to 1
2019-07-27 06:30:47.183  Status: (Zigate) Entering work loop.
2019-07-27 06:30:47.190  Status: (Zigate) Initialized version 4.3.2, author 'zaraki673  pipiche38'
2019-07-27 06:30:47.209  Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 06:30:47.209  (Zigate) Debug: 4
2019-07-27 06:30:47.209  (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 06:30:47.211  Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516]
2019-07-27 06:30:47.211  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 06:30:47.211  Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 06:30:47.211  Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 06:30:47.211  Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 06:30:47.235  Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 06:30:47.268  Status: (Zigate) load PluginConf
2019-07-27 06:30:47.270  Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 06:30:47.273  Status: (Zigate)  -vibrationAqarasensitivity: medium
2019-07-27 06:30:47.273  Status: (Zigate)  -enablegroupmanagement: 0
2019-07-27 06:30:47.273  Status: (Zigate)  -resetMotiondelay: 30
2019-07-27 06:30:47.274  Status: (Zigate)  -logFORMAT: 0
2019-07-27 06:30:47.274  Status: (Zigate)  -logLQI: 0
2019-07-27 06:30:47.274  Status: (Zigate)  -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 06:30:47.296  Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 06:30:47.372  Status: (Zigate) DeviceConf loaded
2019-07-27 06:30:47.372  Status: (Zigate) load ListOfDevice
2019-07-27 06:30:47.564  Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 06:30:47.574  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 06:30:47.574  (Zigate) Heartbeat interval set to: 5.
2019-07-27 06:30:47.593  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:47.593  (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:47.594  Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:47.594  (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.594  (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.594  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:47.596  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:47.596  (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:47.596  Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:47.596  (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.596  (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:47.596  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
35000 Error code lines deleted
2019-07-27 06:30:52.556  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.556  (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.557  Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:52.557  (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.557  (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.557  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:52.557  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.557  (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.558  (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.558  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:52.558  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.558  (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.558  Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:52.558  (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.559  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to '192.168.1.201:9999'
2019-07-27 06:30:52.559  (Zigate) Connect directive received, action initiation failed.
2019-07-27 06:30:52.559  Error: (Zigate) Failed to connect (-1)
2019-07-27 06:30:52.559  (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.559  (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.201', Port: '9999', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'
2019-07-27 06:30:52.559  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-07-27 06:30:52.614  Status: (Zigate) Reconnected after failure
2019-07-27 06:30:52.615  (Zigate) Configure Permit To Join
2019-07-27 06:30:52.615  (Zigate) Request discovery mode for 180 seconds
2019-07-27 06:30:52.666  Status: (Zigate) Major Version Num: 0003
2019-07-27 06:30:52.667  Status: (Zigate) Installer Version Number: 030f
2019-07-27 06:30:52.769  Status: (Zigate) Zigate in Permit Join: On
2019-07-27 06:30:52.824  Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 06:30:52.824  Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 06:30:52.879  Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 06:30:57.289  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 06:45:50.955  Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 06:45:51.956  Error: Restarting: Zigate
2019-07-27 06:45:51.956  Status: (Zigate) Stop directive received.
2019-07-27 06:45:51.957  Status: (Zigate) Exiting work loop.
2019-07-27 06:45:52.033  Status: (Zigate) onDisconnect called
2019-07-27 06:45:52.033  Status: (Zigate) onStop called
2019-07-27 06:45:52.223  Status: (Zigate) Statistics on message
2019-07-27 06:45:52.224  Status: (Zigate) Sent:
2019-07-27 06:45:52.224  Status: (Zigate)    TX commands      : 7
2019-07-27 06:45:52.224  Status: (Zigate)    Max Load (Queue) : 4
2019-07-27 06:45:52.224  Status: (Zigate)    TX failed        : 0 (0.0%)
2019-07-27 06:45:52.224  Status: (Zigate)    TX timeout       : 0 (0.0%)
2019-07-27 06:45:52.224  Status: (Zigate)    TX data timeout  : 0 (0.0%)
2019-07-27 06:45:52.224  Status: (Zigate)    TX reTransmit    : 0 (0.0%)
2019-07-27 06:45:52.224  Status: (Zigate) Received:
2019-07-27 06:45:52.224  Status: (Zigate)    RX frame         : 44
2019-07-27 06:45:52.225  Status: (Zigate)    RX crc errors    : 0 (0.0%)
2019-07-27 06:45:52.225  Status: (Zigate)    RX lentgh errors : 0 (0.0%)
2019-07-27 06:45:52.225  Status: (Zigate)    RX clusters      : 31
2019-07-27 06:45:52.225  Status: (Zigate)    RX clusters KO   : 0
2019-07-27 06:45:52.225  Status: (Zigate) Operating time      : 0 Hours 15 Mins 5 Secs
2019-07-27 06:45:52.357  Status: (Zigate) Stopping threads.
2019-07-27 06:45:52.357  Status: (Zigate) Stopped.
2019-07-27 06:45:52.357  Status: (Zigate) Started.
2019-07-27 06:45:52.562  Status: (Zigate) Entering work loop.
2019-07-27 06:45:52.563  Status: (Zigate) Initialized version 4.3.2, author 'zaraki673  pipiche38'
2019-07-27 06:45:52.574  Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 06:45:52.574  (Zigate) Debug: 4
2019-07-27 06:45:52.574  (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 06:45:52.576  Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 06:45:52.576  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 06:45:52.576  Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 06:45:52.576  Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 06:45:52.576  Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 06:45:52.582  Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 06:45:52.583  Status: (Zigate) load PluginConf
2019-07-27 06:45:52.583  Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 06:45:52.584  Status: (Zigate)  -vibrationAqarasensitivity: medium
2019-07-27 06:45:52.584  Status: (Zigate)  -enablegroupmanagement: 0
2019-07-27 06:45:52.584  Status: (Zigate)  -resetMotiondelay: 30
2019-07-27 06:45:52.584  Status: (Zigate)  -logFORMAT: 0
2019-07-27 06:45:52.584  Status: (Zigate)  -logLQI: 0
2019-07-27 06:45:52.584  Status: (Zigate)  -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 06:45:52.586  Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 06:45:52.603  Status: (Zigate) DeviceConf loaded
2019-07-27 06:45:52.603  Status: (Zigate) load ListOfDevice
2019-07-27 06:45:52.636  Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 06:45:52.640  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 06:45:52.640  (Zigate) Heartbeat interval set to: 5.
2019-07-27 06:45:52.691  (Zigate) Configure Permit To Join
2019-07-27 06:45:52.691  (Zigate) Request discovery mode for 180 seconds
2019-07-27 06:45:52.743  Status: (Zigate) Major Version Num: 0003
2019-07-27 06:45:52.743  Status: (Zigate) Installer Version Number: 030f
2019-07-27 06:45:52.845  Status: (Zigate) Zigate in Permit Join: On
2019-07-27 06:45:52.900  Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 06:45:52.900  Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 06:45:52.954  Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 06:46:02.574  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:01:03.397  Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 07:01:04.398  Error: Restarting: Zigate
2019-07-27 07:01:04.398  Status: (Zigate) Stop directive received.
2019-07-27 07:01:04.398  Status: (Zigate) Exiting work loop.
2019-07-27 07:01:04.485  Status: (Zigate) onDisconnect called
2019-07-27 07:01:04.486  Status: (Zigate) onStop called
2019-07-27 07:01:04.538  Status: (Zigate) Statistics on message
2019-07-27 07:01:04.538  Status: (Zigate) Sent:
2019-07-27 07:01:04.538  Status: (Zigate)    TX commands      : 5
2019-07-27 07:01:04.538  Status: (Zigate)    Max Load (Queue) : 4
2019-07-27 07:01:04.539  Status: (Zigate)    TX failed        : 0 (0.0%)
2019-07-27 07:01:04.539  Status: (Zigate)    TX timeout       : 0 (0.0%)
2019-07-27 07:01:04.539  Status: (Zigate)    TX data timeout  : 0 (0.0%)
2019-07-27 07:01:04.539  Status: (Zigate)    TX reTransmit    : 0 (0.0%)
2019-07-27 07:01:04.539  Status: (Zigate) Received:
2019-07-27 07:01:04.539  Status: (Zigate)    RX frame         : 52
2019-07-27 07:01:04.539  Status: (Zigate)    RX crc errors    : 0 (0.0%)
2019-07-27 07:01:04.539  Status: (Zigate)    RX lentgh errors : 0 (0.0%)
2019-07-27 07:01:04.540  Status: (Zigate)    RX clusters      : 43
2019-07-27 07:01:04.540  Status: (Zigate)    RX clusters KO   : 0
2019-07-27 07:01:04.540  Status: (Zigate) Operating time      : 0 Hours 15 Mins 12 Secs
2019-07-27 07:01:04.699  Status: (Zigate) Stopping threads.
2019-07-27 07:01:04.699  Status: (Zigate) Stopped.
2019-07-27 07:01:04.699  Status: (Zigate) Started.
2019-07-27 07:01:04.929  Status: (Zigate) Entering work loop.
2019-07-27 07:01:04.930  Status: (Zigate) Initialized version 4.3.2, author 'zaraki673  pipiche38'
2019-07-27 07:01:04.941  Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:01:04.941  (Zigate) Debug: 4
2019-07-27 07:01:04.941  (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:01:04.943  Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:01:04.943  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:01:04.943  Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:01:04.943  Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:01:04.943  Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:01:04.949  Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:01:04.950  Status: (Zigate) load PluginConf
2019-07-27 07:01:04.950  Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:01:04.951  Status: (Zigate)  -vibrationAqarasensitivity: medium
2019-07-27 07:01:04.951  Status: (Zigate)  -enablegroupmanagement: 0
2019-07-27 07:01:04.951  Status: (Zigate)  -resetMotiondelay: 30
2019-07-27 07:01:04.951  Status: (Zigate)  -logFORMAT: 0
2019-07-27 07:01:04.951  Status: (Zigate)  -logLQI: 0
2019-07-27 07:01:04.951  Status: (Zigate)  -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:01:04.955  Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:01:04.971  Status: (Zigate) DeviceConf loaded
2019-07-27 07:01:04.971  Status: (Zigate) load ListOfDevice
2019-07-27 07:01:05.004  Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:01:05.008  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:01:05.009  (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:01:05.059  (Zigate) Configure Permit To Join
2019-07-27 07:01:05.060  (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:01:05.111  Status: (Zigate) Major Version Num: 0003
2019-07-27 07:01:05.111  Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:01:05.213  Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:01:05.266  Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:01:05.266  Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:01:05.321  Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:01:14.937  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:15:50.133  (Zigate) processListOfDevices - Device: 854e is in Status = 'Left' for 392256HB
2019-07-27 07:16:15.862  Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 07:16:16.863  Error: Restarting: Zigate
2019-07-27 07:16:16.863  Status: (Zigate) Stop directive received.
2019-07-27 07:16:16.864  Status: (Zigate) Exiting work loop.
2019-07-27 07:16:16.883  Status: (Zigate) onDisconnect called
2019-07-27 07:16:16.883  Status: (Zigate) onStop called
2019-07-27 07:16:16.937  Status: (Zigate) Statistics on message
2019-07-27 07:16:16.937  Status: (Zigate) Sent:
2019-07-27 07:16:16.938  Status: (Zigate)    TX commands      : 6
2019-07-27 07:16:16.938  Status: (Zigate)    Max Load (Queue) : 4
2019-07-27 07:16:16.938  Status: (Zigate)    TX failed        : 0 (0.0%)
2019-07-27 07:16:16.938  Status: (Zigate)    TX timeout       : 0 (0.0%)
2019-07-27 07:16:16.938  Status: (Zigate)    TX data timeout  : 0 (0.0%)
2019-07-27 07:16:16.938  Status: (Zigate)    TX reTransmit    : 0 (0.0%)
2019-07-27 07:16:16.938  Status: (Zigate) Received:
2019-07-27 07:16:16.938  Status: (Zigate)    RX frame         : 41
2019-07-27 07:16:16.938  Status: (Zigate)    RX crc errors    : 0 (0.0%)
2019-07-27 07:16:16.938  Status: (Zigate)    RX lentgh errors : 0 (0.0%)
2019-07-27 07:16:16.938  Status: (Zigate)    RX clusters      : 30
2019-07-27 07:16:16.938  Status: (Zigate)    RX clusters KO   : 0
2019-07-27 07:16:16.938  Status: (Zigate) Operating time      : 0 Hours 15 Mins 11 Secs
2019-07-27 07:16:17.064  Status: (Zigate) Stopping threads.
2019-07-27 07:16:17.064  Status: (Zigate) Stopped.
2019-07-27 07:16:17.064  Status: (Zigate) Started.
2019-07-27 07:16:17.303  Status: (Zigate) Entering work loop.
2019-07-27 07:16:17.304  Status: (Zigate) Initialized version 4.3.2, author 'zaraki673  pipiche38'
2019-07-27 07:16:17.315  Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:16:17.315  (Zigate) Debug: 4
2019-07-27 07:16:17.315  (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:16:17.317  Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:16:17.317  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:16:17.317  Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:16:17.317  Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:16:17.317  Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:16:17.324  Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:16:17.325  Status: (Zigate) load PluginConf
2019-07-27 07:16:17.325  Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:16:17.326  Status: (Zigate)  -vibrationAqarasensitivity: medium
2019-07-27 07:16:17.326  Status: (Zigate)  -enablegroupmanagement: 0
2019-07-27 07:16:17.326  Status: (Zigate)  -resetMotiondelay: 30
2019-07-27 07:16:17.326  Status: (Zigate)  -logFORMAT: 0
2019-07-27 07:16:17.326  Status: (Zigate)  -logLQI: 0
2019-07-27 07:16:17.326  Status: (Zigate)  -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:16:17.329  Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:16:17.346  Status: (Zigate) DeviceConf loaded
2019-07-27 07:16:17.346  Status: (Zigate) load ListOfDevice
2019-07-27 07:16:17.381  Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:16:17.385  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:16:17.385  (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:16:17.436  (Zigate) Configure Permit To Join
2019-07-27 07:16:17.436  (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:16:17.488  Status: (Zigate) Major Version Num: 0003
2019-07-27 07:16:17.488  Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:16:17.590  Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:16:17.644  Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:16:17.644  Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:16:17.698  Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:16:27.316  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:31:29.221  Error: Restarting: Zigate
2019-07-27 07:31:29.222  Status: (Zigate) Stop directive received.
2019-07-27 07:31:29.222  Status: (Zigate) Exiting work loop.
2019-07-27 07:31:29.226  Status: (Zigate) onDisconnect called
2019-07-27 07:31:29.227  Status: (Zigate) onStop called
2019-07-27 07:31:29.279  Status: (Zigate) Statistics on message
2019-07-27 07:31:29.279  Status: (Zigate) Sent:
2019-07-27 07:31:29.279  Status: (Zigate)    TX commands      : 8
2019-07-27 07:31:29.279  Status: (Zigate)    Max Load (Queue) : 4
2019-07-27 07:31:29.279  Status: (Zigate)    TX failed        : 0 (0.0%)
2019-07-27 07:31:29.279  Status: (Zigate)    TX timeout       : 0 (0.0%)
2019-07-27 07:31:29.279  Status: (Zigate)    TX data timeout  : 0 (0.0%)
2019-07-27 07:31:29.280  Status: (Zigate)    TX reTransmit    : 0 (0.0%)
2019-07-27 07:31:29.280  Status: (Zigate) Received:
2019-07-27 07:31:29.280  Status: (Zigate)    RX frame         : 20
2019-07-27 07:31:29.280  Status: (Zigate)    RX crc errors    : 0 (0.0%)
2019-07-27 07:31:29.280  Status: (Zigate)    RX lentgh errors : 0 (0.0%)
2019-07-27 07:31:29.280  Status: (Zigate)    RX clusters      : 5
2019-07-27 07:31:29.280  Status: (Zigate)    RX clusters KO   : 0
2019-07-27 07:31:29.280  Status: (Zigate) Operating time      : 0 Hours 15 Mins 12 Secs
2019-07-27 07:31:29.422  Status: (Zigate) Stopping threads.
2019-07-27 07:31:29.422  Status: (Zigate) Stopped.
2019-07-27 07:31:29.422  Status: (Zigate) Started.
2019-07-27 07:31:29.658  Status: (Zigate) Entering work loop.
2019-07-27 07:31:29.659  Status: (Zigate) Initialized version 4.3.2, author 'zaraki673  pipiche38'
2019-07-27 07:31:29.670  Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:31:29.670  (Zigate) Debug: 4
2019-07-27 07:31:29.670  (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:31:29.671  Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:31:29.672  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:31:29.672  Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:31:29.672  Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:31:29.672  Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:31:29.678  Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:31:29.679  Status: (Zigate) load PluginConf
2019-07-27 07:31:29.679  Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:31:29.680  Status: (Zigate)  -vibrationAqarasensitivity: medium
2019-07-27 07:31:29.680  Status: (Zigate)  -enablegroupmanagement: 0
2019-07-27 07:31:29.680  Status: (Zigate)  -resetMotiondelay: 30
2019-07-27 07:31:29.680  Status: (Zigate)  -logFORMAT: 0
2019-07-27 07:31:29.680  Status: (Zigate)  -logLQI: 0
2019-07-27 07:31:29.680  Status: (Zigate)  -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:31:29.682  Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:31:29.697  Status: (Zigate) DeviceConf loaded
2019-07-27 07:31:29.698  Status: (Zigate) load ListOfDevice
2019-07-27 07:31:29.731  Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:31:29.735  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:31:29.735  (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:31:29.786  (Zigate) Configure Permit To Join
2019-07-27 07:31:29.786  (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:31:29.837  Status: (Zigate) Major Version Num: 0003
2019-07-27 07:31:29.837  Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:31:29.939  Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:31:29.992  Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:31:29.992  Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:31:30.048  Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:31:39.667  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:46:40.643  Error: Zigate hardware (5) nothing received for more than 15 Minutes!....
2019-07-27 07:46:41.644  Error: Restarting: Zigate
2019-07-27 07:46:41.644  Status: (Zigate) Stop directive received.
2019-07-27 07:46:41.646  Status: (Zigate) Exiting work loop.
2019-07-27 07:46:41.668  Status: (Zigate) onDisconnect called
2019-07-27 07:46:41.668  Status: (Zigate) onStop called
2019-07-27 07:46:41.720  Status: (Zigate) Statistics on message
2019-07-27 07:46:41.720  Status: (Zigate) Sent:
2019-07-27 07:46:41.721  Status: (Zigate)    TX commands      : 8
2019-07-27 07:46:41.721  Status: (Zigate)    Max Load (Queue) : 4
2019-07-27 07:46:41.721  Status: (Zigate)    TX failed        : 0 (0.0%)
2019-07-27 07:46:41.721  Status: (Zigate)    TX timeout       : 0 (0.0%)
2019-07-27 07:46:41.721  Status: (Zigate)    TX data timeout  : 0 (0.0%)
2019-07-27 07:46:41.721  Status: (Zigate)    TX reTransmit    : 0 (0.0%)
2019-07-27 07:46:41.721  Status: (Zigate) Received:
2019-07-27 07:46:41.721  Status: (Zigate)    RX frame         : 18
2019-07-27 07:46:41.721  Status: (Zigate)    RX crc errors    : 0 (0.0%)
2019-07-27 07:46:41.722  Status: (Zigate)    RX lentgh errors : 0 (0.0%)
2019-07-27 07:46:41.722  Status: (Zigate)    RX clusters      : 3
2019-07-27 07:46:41.722  Status: (Zigate)    RX clusters KO   : 0
2019-07-27 07:46:41.722  Status: (Zigate) Operating time      : 0 Hours 15 Mins 12 Secs
2019-07-27 07:46:41.846  Status: (Zigate) Stopping threads.
2019-07-27 07:46:41.847  Status: (Zigate) Stopped.
2019-07-27 07:46:41.847  Status: (Zigate) Started.
2019-07-27 07:46:42.095  Status: (Zigate) Entering work loop.
2019-07-27 07:46:42.096  Status: (Zigate) Initialized version 4.3.2, author 'zaraki673  pipiche38'
2019-07-27 07:46:42.107  Status: (Zigate) Zigate plugin 4.3.2 started
2019-07-27 07:46:42.107  (Zigate) Debug: 4
2019-07-27 07:46:42.107  (Zigate) Debug logging mask set to: PLUGIN
2019-07-27 07:46:42.109  Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-07-27 07:46:42.109  Status: (Zigate) Switching Heartbeat to 5 s interval
2019-07-27 07:46:42.109  Status: (Zigate) DomoticzVersion: 4.11031
2019-07-27 07:46:42.109  Status: (Zigate) DomoticzHash: ad1a5b2ac
2019-07-27 07:46:42.109  Status: (Zigate) DomoticzBuildTime: 2019-07-26 06:20:37
2019-07-27 07:46:42.115  Status: (Zigate) Opening DomoticzDB in raw
2019-07-27 07:46:42.116  Status: (Zigate) load PluginConf
2019-07-27 07:46:42.116  Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-07-27 07:46:42.117  Status: (Zigate)  -vibrationAqarasensitivity: medium
2019-07-27 07:46:42.117  Status: (Zigate)  -enablegroupmanagement: 0
2019-07-27 07:46:42.117  Status: (Zigate)  -resetMotiondelay: 30
2019-07-27 07:46:42.117  Status: (Zigate)  -logFORMAT: 0
2019-07-27 07:46:42.117  Status: (Zigate)  -logLQI: 0
2019-07-27 07:46:42.117  Status: (Zigate)  -channel: ['11', '15', '19', '20', '25', '26']
2019-07-27 07:46:42.119  Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-07-27 07:46:42.135  Status: (Zigate) DeviceConf loaded
2019-07-27 07:46:42.135  Status: (Zigate) load ListOfDevice
2019-07-27 07:46:42.169  Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 10
2019-07-27 07:46:42.173  Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: 192.168.1.201:9999
2019-07-27 07:46:42.173  (Zigate) Heartbeat interval set to: 5.
2019-07-27 07:46:42.224  (Zigate) Configure Permit To Join
2019-07-27 07:46:42.224  (Zigate) Request discovery mode for 180 seconds
2019-07-27 07:46:42.275  Status: (Zigate) Major Version Num: 0003
2019-07-27 07:46:42.275  Status: (Zigate) Installer Version Number: 030f
2019-07-27 07:46:42.377  Status: (Zigate) Zigate in Permit Join: On
2019-07-27 07:46:42.430  Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-07-27 07:46:42.430  Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-07-27 07:46:42.486  Status: (Zigate) Number of devices recently active in Zigate = 9
2019-07-27 07:46:52.106  Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
2019-07-27 07:49:12.166  (Zigate) processListOfDevices - Device: 854e is in Status = 'Left' for 392652HB
2019-07-27 07:52:12.170  (Zigate) processListOfDevices - Device: 854e is in Status = 'Left' for 392688HB
2019-07-27 07:52:39.580  (Zigate) UpdateDevice - (Sonde 5 : Extérieur Sud) 0:22.8;65.4;1;989.3;4
2019-07-27 07:52:39.583  (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002d7df32-01) 0:22.8;65.4;1
2019-07-27 07:52:39.589  (Zigate) UpdateDevice - (Sonde 5 : Extérieur Sud) 0:22.8;65.4;1;989.0;4
2019-07-27 07:52:39.595  (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002d7df32-01) 0:989.0;4
2019-07-27 07:52:39.601  (Zigate) UpdateDevice - (Sonde 5 : Extérieur Sud) 0:22.8;65.4;1;989.2;4
2019-07-27 07:52:39.606  (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002d7df32-01) 0:989.2;4
2019-07-27 07:52:52.138  (Zigate) UpdateDevice - (        Sonde 5) 0:25.1;65.8;1;988.8;4
2019-07-27 07:52:52.141  (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f2ec2a-01) 0:25.1;65.8;1
2019-07-27 07:52:52.144  (Zigate) UpdateDevice - (Sonde T6 : Chambre Parents) 25.1:25.1
2019-07-27 07:52:52.148  (Zigate) UpdateDevice - (        Sonde 5) 0:25.1;65.5;1;988.8;4
2019-07-27 07:52:52.151  (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002f2ec2a-01) 0:25.1;65.5;1
2019-07-27 07:52:52.155  (Zigate) UpdateDevice - (        Sonde 5) 0:25.1;65.5;1;988.7;4
2019-07-27 07:52:52.160  (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f2ec2a-01) 0:988.7;4
2019-07-27 07:53:01.389  (Zigate) UpdateDevice - (Sonde T3 : Zigate - lumi.weather_Temp+Hum+Baro-00158d0002d7e00b-01) 0:23.6;77.7;3;989.3;4
2019-07-27 07:53:01.392  (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0002d7e00b-01) 0:23.6;77.7;3
2019-07-27 07:53:01.398  (Zigate) UpdateDevice - (Sonde T3 : Zigate - lumi.weather_Temp+Hum+Baro-00158d0002d7e00b-01) 0:23.6;77.7;3;989.0;4
2019-07-27 07:53:01.403  (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002d7e00b-01) 0:989.0;4
This lines were repeated 7000 times in only 5 seconds :
Those thousands of error in a few seconds can explain why the raspberry keeps on rebooting some times.
pipiche
Post by pipiche »
keros wrote:Hello twoenter, hello pipiche, hello all !!
Which version/branch of the plugin are you using ? Indeed there is is a relation with the auto-backup of domoticz
pipiche
Post by pipiche »
If you have the possibility to switch to beta branch this is issue is addressed
keros
Post by keros »
Thank you Pipiche for you're help and also all the work you've done !!
I switch to beta and that is the log I got in my log after my Raspberry Restart.
 2019-07-27 12:04:42.461 Status: (Zigate) Entering work loop.
2019-07-27 12:04:42.474 Status: (Zigate) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-07-27 12:04:42.500 Status: (Zigate) Zigate plugin beta-4.6.001 started
2019-07-27 12:04:42.501 Error: (Zigate) 'onStart' failed 'AttributeError':''NoneType' object has no attribute 'pluginConf''.
2019-07-27 12:04:42.501 Error: (Zigate) ----> Line 804 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-07-27 12:04:42.501 Error: (Zigate) ----> Line 204 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-07-27 12:04:42.501 Error: (Zigate) ----> Line 524 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/tools.py', function loggingPlugin
Is it normal ?
I'll tell you if some thing new commes. Thank you once again ;)
pipiche
Post by pipiche »
Not normal, will investigate and revert
pipiche
Post by pipiche »
Got it. You have set Debug mode to something else than None, correct ?
pipiche
Post by pipiche »
If you do a git pull to get the latest update, this should be fixed.
keros
Post by keros »
I didn't recevied after the moment I switched to beta.
When I came back, after lunch, I wasn't able to reach the zigate web admin page. I unpluged/repluged it.
I just did a git pull, a restart, and now the data are slowly comming back (wating for the dashboard update).
I had some troubles with the zigate wifi since the begining for me (15th june) so I set the plugin debug to Domoticz Plugin.
