As you can see the ttsUSB0 is not the RFXCOM but the smartmeter P1 and the RFXCOM is on ttyUSB1
So you code is checking the smartmeter P1 device and not the RFXCOM.
If I can find some time I will make a Synology package which will do the insmod of the tyyUSB on boot of the Nas instead of at start of the domoticz package.
I only have the RFXCOM and a USB disk attached via USB and when the RFXCOM is attached it is shown as an FT232 device.
So on my NAS the FT232 is the RFXCOM. My guess is that it may be connected to that I have a gen1 RFXCOM, have they changed the USB-serial chipset between generations?
Sorry for off topic.
My Synology NAS has got only two USBs which are occupied by 1wire and RFXCOM. I also use Zigbee and zwave protocols at home which are connected to Rasberry pi as Synology has no free USB ports anymore.
I tried to use a USB hub without any success.
Would you please advice whether there is a solution to expand USB ports on the NAS or I should give up?
Does your hub has his own power supply, because this configuration draws too much power for a non powered hub.
If so please connect the devices via the usbhub and then post the output of the following two command here.
Pacman42 wrote: Friday 24 May 2019 9:01
Quite new here so hello!
Looking on Jadahl.com for Domoticz 4.9700 stable for DSM6.2 as I'm running a DS413J with MARVELL Kirkwood 88F6282...
I can only find the MyDomoAtHome download, but not the Domoticz v4.0.9700-7 spk download for the 413j...
jumbotroll wrote: Thursday 06 September 2018 15:57
icek wrote: Thursday 06 September 2018 15:49
Hello Jumbotroll,
Is it possible to have a DS413j build?
many tnx
Sorry DS413j use Marvell Kirkwood 88F6282 and have to old toolchain from synology to build the latest domoticz.
Latest build is domoticz_88f6282-6.2_3.0.9483-7.spk
Download here: for DSM 6.2 : http://www.jadahl.com/domoticz_beta_6.2 ... 9483-7.spk
This link to an older version is not working anymore…
DS413J wrote: Saturday 25 May 2019 9:29
Hello Jumbotroll,
many tnx
Since update to DSM 6.2.2 (running on my DS412+) i cannot get my Z-Wave network to work. All devices show up as unknown and I get time-outs on several devices. All of them do not work.
Running Domoticz 4.10538. What can I do to resolve this?
I've already rebooted, restarted, removed stick a couple of times and added the delay between drivers and domoticz start as mentioned 2 pages back.
what can I do?
Playing with my DS218J but have a issue with my bluetooth.
Got a unknow BT dongle and it's recognized.
But unfortunately when i conduct "l2ping <mac>" or hcitool scan then they can't find any devices while my Rpi does find all my devices.
I feel i miss something, searching google the entire day didn't help.
Didn't install anything besides the SynoDomotics with python.
I know ipkg has bluez but it hasn't a compatible bootstrap for my DS218J.
So thats a no go, if i can't get BT working for my SomeOneHome trigger then i'll stick to my Rpi...
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Siewert308SW wrote: Wednesday 29 May 2019 19:40
I think you need bluez..
I tried to compile bluez for synology without success..
Thx for the answer.
Yep Bluez it is, i know ipkg has a package but can't install it.
As far as i know there is no bootstrap for my DS218J.
Setup:
- DS923+ Docker
Hi, i'm trying to update my domoticz to the latest version on my DS213+. However when downloading and trying to manually install via the package center i get the following error:
"This pacakage is not supported on the platform of DiskSation or incompatible with the current DSM version."
(i'm running on DSM 6.2.2)
Anybody else faceing this? e.g. anybody know how to resolve this?
Sjaakios wrote: Sunday 02 June 2019 10:16
Anyone a solution for this error in the log on DS215J
2019-06-02 15:48:00.457 no field package.preload['socket.core']
2019-06-02 15:48:00.457 no file '/usr/local/share/lua/5.2/socket/core.lua'
2019-06-02 15:48:00.457 no file '/usr/local/share/lua/5.2/socket/core/init.lua'
2019-06-02 15:48:00.457 no file '/usr/local/lib/lua/5.2/socket/core.lua'
2019-06-02 15:48:00.457 no file '/usr/local/lib/lua/5.2/socket/core/init.lua'
2019-06-02 15:48:00.457 no file './socket/core.lua'
2019-06-02 15:48:00.457 no file '/usr/local/lib/lua/5.2/socket/core.so'
2019-06-02 15:48:00.457 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-06-02 15:48:00.457 no file './socket/core.so'
2019-06-02 15:48:00.457 no file '/usr/local/lib/lua/5.2/socket.so'
2019-06-02 15:48:00.457 no file './socket.so'
2019-04-19 13:26:56.629 Error: (iDetect Wifi presence detection) Aborting plugin initialization because SSH client could not be found
2019-04-19 13:27:06.779 Error: (iDetect Wifi presence detection) Plugin initialization did not complete successfully. Check the (debug) log for startup errors.
For some reason it can't find SSH client but it always worked and nothing has changed to the Synology system, no DSM upgrade or anything like that.
SSH still workes like before so no noticeable changes there either.
I can't downgrade easily because Synology doesn't let you.
Any ideas?
Nothing changed in the package only updated domoticz from latest source.
Maybe something went wrong when you updated?
I have build the latest domoticz 4.10603 Alpine you can test or if that not work, maybe try to reinstall the plugin.
My apologies for my late reply but just installed version 4.10603 and the error message regarding SSH client is gone, script is working fine now.
It looks like something was wrong in version 10602 regarding SSH client then.
Hi schumi, did you ever experience this issue again? I have the exact same error message, i'm running on version 4.10717, build hash b38b49e-modified. Any idea's how to get this resolved?
