Ok. Uploadedwaaren wrote: Friday 19 April 2019 16:36Can you please also build this version with Python for Braswell- DSM 6.2. I want to test dzVents' domoticz.triggerIFTTT on my Synology 916+jumbotroll wrote: Friday 19 April 2019 16:07 I have build the latest domoticz 4.10603 Alpine you can test or if that not work, maybe try to reinstall the plugin.
Many thanks !
domoticz in synology as package! Available now.
- jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- waaren
Thx. downloaded, installed and tested. Working like a charm !
schumi2004
- Domoticz version: 4.10603
My apologies for my late reply but just installed version 4.10603 and the error message regarding SSH client is gone, script is working fine now.jumbotroll wrote: Friday 19 April 2019 16:07Nothing changed in the package only updated domoticz from latest source.schumi2004 wrote: Friday 19 April 2019 13:34 @jumbotroll
Since i upgraded to version 4.10602 i see a issue with python plugin iDetect
(https://www.domoticz.com/forum/viewtopic.php?t=20467)
2019-04-19 13:26:56.629 Error: (iDetect Wifi presence detection) Aborting plugin initialization because SSH client could not be found
2019-04-19 13:27:06.779 Error: (iDetect Wifi presence detection) Plugin initialization did not complete successfully. Check the (debug) log for startup errors.
For some reason it can't find SSH client but it always worked and nothing has changed to the Synology system, no DSM upgrade or anything like that.
SSH still workes like before so no noticeable changes there either.
I can't downgrade easily because Synology doesn't let you.
Any ideas?
Maybe something went wrong when you updated?
It looks like something was wrong in version 10602 regarding SSH client then.
schumi2004
@jumbotroll
Got 1 thing resolved but stumbled on something else, it must have been there for a long time now because the dzVents script never worked.
I'm using a simple dzVents script named LEDSlaveDemo found here: https://www.domoticz.com/forum/viewtopic.php?t=23568
But it never worked.
Then i did enable debugging for dzVents and noticed below error:
Error: EventSystem: in /usr/local/domoticz/dzVents/runtime/dzVents.lua: /usr/local/domoticz/dzVents/runtime/persistence.lua:24: /usr/local/domoticz/var/scripts/dzVents/domoticzData.lua: No such file or directory
And the error message is wrong because those files are available:
admin@DS715:/usr/local/domoticz/dzVents/runtime$ ls -la
total 248
drwxr-xr-x 6 domoticz root 4096 Apr 19 16:05 .
drwxr-xr-x 4 domoticz root 4096 Apr 19 16:05 ..
-rw-r--r-- 1 domoticz root 1213 Apr 19 16:05 Camera.lua
drwxr-xr-x 2 domoticz root 4096 Apr 19 16:05 device-adapters
-rw-r--r-- 1 domoticz root 1618 Apr 19 16:05 Device.lua
-rw-r--r-- 1 domoticz root 18512 Apr 19 16:05 Domoticz.lua
-rw-r--r-- 1 domoticz root 2514 Apr 19 16:05 dzVents.lua
-rw-r--r-- 1 domoticz root 28621 Apr 19 16:05 EventHelpers.lua
-rw-r--r-- 1 domoticz root 12426 Apr 19 16:05 HistoricalStorage.lua
-rw-r--r-- 1 domoticz root 1077 Apr 19 16:05 HTTPResponse.lua
drwxr-xr-x 2 domoticz root 4096 Apr 19 16:05 integration-tests
-rw-r--r-- 1 domoticz root 65212 Apr 19 16:05 lodash.lua
drwxr-xr-x 2 domoticz root 4096 Apr 19 16:05 misc
-rwxr-xr-x 1 domoticz root 5741 Apr 19 16:05 persistence.lua
-rw-r--r-- 1 domoticz root 380 Apr 19 16:05 Security.lua
drwxr-xr-x 6 domoticz root 4096 Apr 19 16:05 tests
-rw-r--r-- 1 domoticz root 5050 Apr 19 16:05 TimedCommand.lua
-rw-r--r-- 1 domoticz root 807 Apr 19 16:05 TimedCommandOptions.lua
-rw-r--r-- 1 domoticz root 32915 Apr 19 16:05 Time.lua
-rw-r--r-- 1 domoticz root 336 Apr 19 16:05 Timer.lua
-rw-r--r-- 1 domoticz root 542 Apr 19 16:05 todo.md
-rw-r--r-- 1 domoticz root 4215 Apr 19 16:05 Utils.lua
-rw-r--r-- 1 domoticz root 1673 Apr 19 16:05 Variable.lua
I did some searching in this topic and found that this error is seen beofre but couldn;t find a solution for it.
I did noticed that there are different permisions because persistence.lua hass 755 and the rest 644 so i changed other lua script files to 755 also but it did not help.
total 248
- waaren
Looks like a similar problem as been discussed hereschumi2004 wrote: Sunday 21 April 2019 12:41 Got 1 thing resolved but stumbled on something else, it must have been there for a long time now because the dzVents script never worked.
In short:
- make a backup of domoticz.db and all your scripts / plugins.
- remove domoticz package
- install latest domoticz package
- stop domoticz
- restore your database and scripts / plugins
- start domoticz
schumi2004
@waaren
You fixed it, thank you
The steps i took are.
- stop domoticz
- check directory if needed folders and files are there
- start domoticz
- restore backup in GUI
- jumbotroll
Domoticz Stable V4.0.10693 for DSM 6.2 for synology is uploaded.
Jumbotroll
Jumbotroll
Gravityz
- Domoticz version: 2026.3
Thanks,
i was looking under the beta to see if there was a new version out
noticed the stable release message from remb0 on the forum.
I downloaded your package (which seems a higher stable build) and installed it.
sofar looking good.
I am still on DSM 6.2.1 because i did not receive the update to 6.2.2. message yet.
did a couple of handy dzvents scripts to get multiple lines on a text device.
coupled this with telegram so now i get al the notifications even when not connected to domoticz through vpn.
sofar looking good.
jumbotroll wrote: Monday 06 May 2019 16:21 Domoticz Stable V4.0.10693 for DSM 6.2 for synology is uploaded.
- jumbotroll
I am on 6.22 and can confirm that is ok to upgrade.Gravityz wrote: Wednesday 08 May 2019 19:07 Thanks,
sofar looking good.
I manually downloaded 6.22 from here: https://archive.synology.com/download/D ... 2.2/24922/
Jumbotroll
Jumbotroll
- jumbotroll
Domoticz version 4.10717 released (Stable) for Synology
Uploading later tonight
Jumbotroll
Jumbotroll
Gravityz
nice
thanks
howcome this is also called a stable version and not a beta?
thanks
jumbotroll wrote: Thursday 09 May 2019 17:38 Domoticz version 4.10717 released (Stable) for Synology
Uploading later tonight![]()
- jumbotroll
Maybe there was some bug in first in latest "stable" version? Check github..Gravityz wrote: Thursday 09 May 2019 17:48 nice
thanks
Jumbotroll
Jumbotroll
- mongoose
@jumbotroll - Big thank you
appreciate all the work you do!
Gravityz
Hi jumbotroll,
is it possible that you can make a new build for apollolake (DS718+ without python)
there is a bug in the current build which affect the log graph on all switches.
They seem to have fixed this in the latest build
thanks
hopefully this also brings back the new functionality in the logs regarding new graphs (graphs above the text log)
thanks
- jumbotroll
Latest Beta build is uploadedGravityz wrote: Sunday 12 May 2019 9:47 Hi jumbotroll,
thanks
Jumbotroll
Jumbotroll
Gravityz
Thanks,
tested it and bug is fixed in 734
only a minor issue (non dimmable switches(physical or virtual) display on values as 99%, 98% or 100%
Already mentioned this on github
not a big deal(but not correct)
jumbotroll wrote: Sunday 12 May 2019 12:05Latest Beta build is uploadedGravityz wrote: Sunday 12 May 2019 9:47 Hi jumbotroll,
thanks
hopefully this also brings back the new functionality in the logs regarding new graphs (graphs above the text log)![]()
gbuico
- Domoticz version: 3.8153
@jumbotroll
Hi jumbotroll ... sorry if this may be a silly question but... I'm an old user of Domoticz on Raspberry and since a month I'm running your version on my Synology DS218j and,,, it's just great.
Now version 10717 is out and you aligned very quickly... but... what is the right procedure for the upgrade?
In a very simplicistic way I tried to use the normal update process from the Domoticz menu... I hope I did not corrupt anything in my Synology because it goes to the end of the update in a smooth and successful way... but then I still have the old version.
Can you be so kind an give me whatever advice?
Thanks for your work anyway
Giacomo
DSM 6.2
Giacomo
DSM 6.2
Gravityz
wow.
i just noticed they implemented openzwave v1.6 and also a new version of dzvents.
very productive sunday
things are going fast.
- jumbotroll
If your prev version is very old, you have to uninstall domoticz from package center, before you install the new version.gbuico wrote: Sunday 12 May 2019 16:15 @jumbotroll
Giacomo
DSM 6.2
Most of the time, you only have to install over the old version.
Remember to take backup of domoticz database and if you have scripts or plugins.
I have never heard of any corrupt synology after installing these packages, so don't worry
Jumbotroll
Jumbotroll
- jumbotroll
I will build a new version for you later tonight with openzwave v.1.6 new dzventsGravityz wrote: Sunday 12 May 2019 17:02 wow.
Jumbotroll
Jumbotroll
