Dashticz - Module - Calendar
aeonfast
Re: Dashticz - Module - Calendar
@Lokonli, hopefully you can help me as well with my calender problem.
Information: Dashticz Beta V2.5.10, PHP Version 7.0.33-0+deb9u1
The code in my config.js:
var calendars = {}
calendars.test = { maxitems: 5, url: 'https://calendar.google.com/calendar/em ... FAmsterdam', icalurl: 'https://cors-anywhere.herokuapp.com/htt ... /basic.ics' }
And yes, it has some test appointments in it. Any clue?
var calendars = {}
- Calender.JPG (158.79 KiB) Viewed 3724 times
Lokonli
First try without adding cors-anywhere.herokuapp.com to the icalurl parameter.aeonfast wrote: Friday 29 March 2019 21:43 @Lokonli, hopefully you can help me as well with my calender problem.
var calendars = {}
aeonfast
Just tried that, same result and error.
Lokonli
On my system your calendar is working. I see your three appointments:
var calendars = {}
calendars.test = {
icalurl: 'https://calendar.google.com/calendar/ical/mkpp6cdf62mluac13a65vf3jp8%40group.calendar.google.com/public/basic.ics'
If you still have issues:
Test 1:
are you running Apache?
Look for errors in the Apache log. Normally it's /var/log/apache2/error.log
Test 2:
In chrome, press F12 to open the developers window.
Refresh Dashticz.
Go to the network tab of the developers window. If you type 'ical' in the search field, then you should see the network requests to your calendar.
What is the status?
If you click on the request: Do you see anything on 'preview'-tab? and on the response-tab?
Lokonli
Sorry, I only just see your error message.Lokonli wrote: Friday 29 March 2019 23:03On my system your calendar is working. I see your three appointments:
Don't add cors-anywhere. Please double check that you tested without cors-anywhere.Code: Select all
var calendars = {} calendars.test = { icalurl: 'https://calendar.google.com/calendar/ical/mkpp6cdf62mluac13a65vf3jp8%40group.calendar.google.com/public/basic.ics' }
Test 1:
Test 2:
Refresh Dashticz.
What is the status?
Probably PHP reported an error. Test 1 (see above) should give a clue.
aeonfast
Okey, I double checked again for cors and deleted a couple in my config.js. Used the search function to delete them all. Still nothing happens and the same error stays.
I checked the error.log in the apache folder and it's empty.
I openened the developers window, and I see the network request to my calender. It says: this request has no response data available. If I try the complete link myself in the browser it says: 192.168.xxx.xxxx can't process this request.
Public link works fine. I ran the PHP installations once more, but they were all good.
sudo apt-get install php
sudo apt-get install php-xml php-curl
EDIT: I rebooted my Pi, and now it says: VM1426:5 Domoticz error!
Calendar requires a PHP enabled web server.
PHP not installed.
VM1414:685 PHP not enabled and default_cors_url not set.
VM1414:686 CORS proxy: https://cors-anywhere.herokuapp.com/
I'm completely lost now lol. Error log stills shows nothing.
PHP not installed.
Lokonli
Did you restart apache?aeonfast wrote: Friday 29 March 2019 23:23 Okey, I double checked again for cors and deleted a couple in my config.js. Used the search function to delete them all. Still nothing happens and the same error stays.
You copied the php version from the Dashticz->settings->info-tab? Because that would mean that PHP is working.
In the network request in the develop window you can see the url parameter. Can you try to open this url in a browser window? You should get a file-save dialog with an ics file.
Lokonli
ok, then PHP can not be found by Dashticz, and calendar won't work.aeonfast wrote: Friday 29 March 2019 23:23 Okey, I double checked again for cors and deleted a couple in my config.js. Used the search function to delete them all. Still nothing happens and the same error stays.
PHP not installed.
In some systems there where issues with permissions.
They can be set correctly with:
chmod -R a+rX /home/pi/dashticz_v2-
aeonfast
It finally works!
I think 'sudo apt-get install php libapache2-mod-php -y' did the trick. PHP is enabled and working properly now it seems.
Thank you for your time! I can now sleep peacefully
Lokonli
ok, good!aeonfast wrote: Saturday 30 March 2019 0:01 It finally works!
Thank you for your time! I can now sleep peacefully![]()
I will add that to the installation instructions.
- gielie
- Domoticz version: latest β
I have a problem adding one of my agendas.
The agenda url starts with
webcal://api.socialschools.eu/api/v1/icalfeed/?schoolId=1010&roleTypeId=1&userId
If I look in the console I don't get any error I only get [] No properties
does anybody have an idea how to solve this?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Lokonli
Try replacing webcal with httpgielie wrote: Monday 13 May 2019 14:00 I have a problem adding one of my agendas.
- gielie
I have tried that, also https but I can't get it to work nor do I get any errorLokonli wrote: Friday 17 May 2019 23:38Try replacing webcal with httpgielie wrote: Monday 13 May 2019 14:00 I have a problem adding one of my agendas.
I think it doesn't work because it seems that its not a public agenda or something because there is a userid involved.
This is the headers shows (not complete for privacy reasons)
url: https://api.socialschools.eu/api/v1/icalfeed/?schoolId=1010
roleTypeId: 1
userId: 11914d2b-5e9b-45f1-b8ea-09d45efa28f0
hash: wgsSgL4Dr11fTSF7J5piPB1H3- Aeon Labs USB Stick met Z-wave plus
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
nayonowe
I get stuck on the calendar to work..
Ik have domoticz and dashtics installed on an Synology nas.
Dashticz version: 2.5.11
Domoticz version: 4.10717
dzVents version: 2.4.19
Python version: None
PHP version: 7.2.13
The config:
When i open Dashticz, the calendar says: loading, Thats it nothing will show.
I tried the cors-anywhere in front op the url, but it didn't make any differance.
Tried different browsers, didn't help.
Can somebody please help me?
Edit: Problem solved:
Installed Dashticz on my Rpi and it works!
PHP version: 7.2.13
The config:
var calendars = {}
calendars.me = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/[email protected]/private-4bc44644146cea8d792714f5a90021e4/basic.ics' }
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_4','currentweather_big','weather','blocktitle_5',calendars.me]
columns[3]['width'] = 5;
JaOfBa
Goodday,
is there a way to get the text in the agenda aligned, so times aligned, agenda item aligned?
Lokonli
No, currently not. I'll add it to the feature request list.
misjel
I just added an outlook calender and see my appointments but time are 2hours off.
I read of this problem in this topic. Is this allready fixed or can this be an config issue?
- HansieNL
Problem should have been fixed. Can you try latest beta version?misjel wrote: Sunday 18 August 2019 20:51 I just added an outlook calender and see my appointments but time are 2hours off.
Blah blah blah
Lokonli
assuming the timezone on the Dashticz server has been configured correctly.HansieNL wrote: Sunday 18 August 2019 22:00Problem should have been fixed. Can you try latest beta version?misjel wrote: Sunday 18 August 2019 20:51 I just added an outlook calender and see my appointments but time are 2hours off.
misjel
I was using master branch. Switched to beta and no it is showing correctly. Thnx!HansieNL wrote: Sunday 18 August 2019 22:00Problem should have been fixed. Can you try latest beta version?misjel wrote: Sunday 18 August 2019 20:51 I just added an outlook calender and see my appointments but time are 2hours off.
