Thanks for your prompt reply, Nick!
Did I somehow miss that step while reading documentation? I don't remember it being covered anywhere
I'll give it a go once I get home
I guess it is a connection problem, but i did nothing change to my config. The controlicz site only gives no connection message. No extra information. also when i go to the devices section on the controlicz site that does not seem to work? So no sure if it is really on my side.
Hi, if you can’t see any devices in your profile, then it’s a connection issue. Remind me, did you email me about this? If not, can you email from your Controlicz profile, and i’ll take a lookmodular wrote: ↑Wednesday 06 June 2018 14:08
I was the one contact you via email, but we resolved my problem as being a to restrictive hostname rule on my (pfSense) firewall.Madgeni wrote: ↑Thursday 07 June 2018 11:39Hi, if you can’t see any devices in your profile, then it’s a connection issue. Remind me, did you email me about this? If not, can you email from your Controlicz profile, and i’ll take a lookmodular wrote: ↑Wednesday 06 June 2018 14:08
So I'm still trying to find the problem. I have checked and I'm able to reach Domoticz from the Internet using the same port as I have used in my Controlicz profile. I don't have my own ssl certificate, I'm using the builtin from Domoticz, and have always used that. But is it not possible to use this anymore? Because the only problem I can see now is that I have to accept that the certificate isn't trusted, and then I can use the login as usual.raptorjr wrote: ↑Friday 08 June 2018 18:12 Everything was working until a few days ago. No I cant get it to work, test connection fails. I have not changed domain, or port. Tried to change the password and is able to login to my Domoticz manually with the same username and password.
If I press Devices in Controlicz page I get logged out, don't know if that means anything?
How can I find out where the problem is?
Magnifique !
HelloSo I'm still trying to find the problem. I have checked and I'm able to reach Domoticz from the Internet using the same port as I have used in my Controlicz profile. I don't have my own ssl certificate, I'm using the builtin from Domoticz, and have always used that. But is it not possible to use this anymore? Because the only problem I can see now is that I have to accept that the certificate isn't trusted, and then I can use the login as usual.
