Thanks for your prompt reply, Nick!
Did I somehow miss that step while reading documentation? I don't remember it being covered anywhere
I'll give it a go once I get home
I guess it is a connection problem, but i did nothing change to my config. The controlicz site only gives no connection message. No extra information. also when i go to the devices section on the controlicz site that does not seem to work? So no sure if it is really on my side.Madgeni wrote: Monday 04 June 2018 17:11 can you disable the skill in your Alexa app, and reenable it?
or have i misunderstood, and this is more of a port forwarding issue?
Hi, if you can’t see any devices in your profile, then it’s a connection issue. Remind me, did you email me about this? If not, can you email from your Controlicz profile, and i’ll take a lookmodular wrote: Wednesday 06 June 2018 14:08
I was the one contact you via email, but we resolved my problem as being a to restrictive hostname rule on my (pfSense) firewall.Madgeni wrote: Thursday 07 June 2018 11:39Hi, if you can’t see any devices in your profile, then it’s a connection issue. Remind me, did you email me about this? If not, can you email from your Controlicz profile, and i’ll take a lookmodular wrote: Wednesday 06 June 2018 14:08
So I'm still trying to find the problem. I have checked and I'm able to reach Domoticz from the Internet using the same port as I have used in my Controlicz profile. I don't have my own ssl certificate, I'm using the builtin from Domoticz, and have always used that. But is it not possible to use this anymore? Because the only problem I can see now is that I have to accept that the certificate isn't trusted, and then I can use the login as usual.raptorjr wrote: Friday 08 June 2018 18:12 Everything was working until a few days ago. No I cant get it to work, test connection fails. I have not changed domain, or port. Tried to change the password and is able to login to my Domoticz manually with the same username and password.
If I press Devices in Controlicz page I get logged out, don't know if that means anything?
How can I find out where the problem is?
Magnifique !
HelloSo I'm still trying to find the problem. I have checked and I'm able to reach Domoticz from the Internet using the same port as I have used in my Controlicz profile. I don't have my own ssl certificate, I'm using the builtin from Domoticz, and have always used that. But is it not possible to use this anymore? Because the only problem I can see now is that I have to accept that the certificate isn't trusted, and then I can use the login as usual.
