Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
Hi - just wanted to let you know that the native Alexa smart home skill is now live :)
This allows you to control on/off/dim lights, on/off devices, set/get temperatures and requires no installation or configuration on your Domoticz, other than adding devices to room plans (for the devices you want Alexa to control).
Simply register at www.controlicz.com then enable the Controlicz skill on Alexa
blacksn0w
Re: Easy Domoticz to Alexa Integration
Post by blacksn0w »
Madgeni wrote:Hi - just wanted to let you know that the native Alexa smart home skill is now live :)
Simply register at http://www.controlicz.com then enable the Controlicz skill on Alexa
And you are saving this credentials and in case of a leak someone could control all saved domoticz instances? Or is there some kind of protection?
Madgeni
Post by Madgeni »
all your data is encrypted, the site uses a public SSL cert and your password for the site is hashed
remb0
Post by remb0 »
Great work!
I registered an account.
I setup my external https address and discover.
but nothing found.
so I want to check my details but can't login, tried multiple times, am I blocked?
there is no option to reset account, no confirmation mail etc.
maybe you can help me?
Because this is very very nice if it works :)
diepatchworke
Post by diepatchworke »
getSurreal wrote:There are a few working methods already for integrating Domoticz and Alexa. The simplest I had found was using HA-Bridge https://github.com/bwssytems/ha-bridge. The nice thing about it, is that it simulates a Phillips Hue so Alexa can discover your devices locally without any cloud service. There are some limitations. You basically only have access to On, Off and Dim requests. You're not able to query the status or temperature of any device. To get some of the extra bells and whistles you can setup the Domoticz Alexa Skill viewtopic.php?f=38&t=9446&hilit=alexa#p65767, but that gets a lot more involved.
I've been satisfied with HA-Bridge for a while, but I would like it to be even simpler. I'm also not a java developer and I would really like to make tweaks. So I searched for alternative Hue simulators. I wanted one that would automatically look at my Domoticz devices and make them available to Alexa. I then found hueAndMe https://github.com/johnray/hueAndMe, a python based Hue simulator. It did exactly what I wanted but for Indigo instead of Domoticz. Duplicating what it was doing for Indigo to Domoticz was pretty straight forward. I have a pending pull request to add the Domoticz integration, but the code is available on my fork in a Domoticz branch https://github.com/getSurreal/hueAndMe/tree/domoticz.
i have to tries this second workaround : https://github.com/getSurreal/hueAndMe/tree/domoticz but my alexa diddnt find anything of my domoticz items.. alexa found nothing.
please can you tell me a step by step manual for me? i think i made a mistake in the config? and sorry for my english.
michaldobrotka
Post by michaldobrotka »
same by me. I am registered, skill enabled but after discovery noting was found. Is with IP meant my LAN IP ?
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
Madgeni
Post by Madgeni »
Hi - a silly Q, but are your devices in Room Plans in Domoticz?
michaldobrotka
Yes Madgeni,
I have 7 rooms, each with 2-7 devices. (I noticed that this is a term in your skill description).
Madgeni
Post by Madgeni »
Your Domoticz needs to be accessible via the internet - i would suggest implementing ssl https://www.domoticz.com/wiki/Native_HT ... SL_support
Then in the Controlicz site you just need to provide:
domoticz IP/dns name
port no:
domoticz Username
domoticz password
freijn
Domoticz version: Stable
Post by freijn »
I have an other silly question. Living in the Netherlands its impossible to order an Echo dot.
What's the trick to get one?
Apologies for hijacking your post :-(
Frank
Madgeni
Post by Madgeni »
hah, ebay?
michaldobrotka
freijn wrote:I have an other silly question. Living in the Netherlands its impossible to order an Echo dot.
Frank
Or even better amazon.de :D (maybe you'll need to make a request for order) and they send you bid. But from NL shouldn't be any problem to order it directly. And I registered a sale going on amazon right now.
Madgeni
Post by Madgeni »
I've increased the timeout on the lambda, to see if that resolves it - can people retest, also ensuring you use https - i don't want to drop down to http connections for your homes - i don't think anyone would thank me :)
blacksn0w
Post by blacksn0w »
Madgeni wrote:I've increased the timeout on the lambda, to see if that resolves it - can people retest, also ensuring you use https - i don't want to drop down to http connections for your homes - i don't think anyone would thank me :)
Maybe you should open a new thread for the whole "Controlicz" thing, currently there are two which are used for the same purpose :D
And another question: What about allowing only the Controlicz IP to connect to the Domoticz Instance from the outside?
There should be some ways with firwall rules and/or iptables, what do you think?
Madgeni
Post by Madgeni »
fair point on multiple threads :)
In terms of FW rules, that would be client side, and therefore dependent on what kit each person has
danpep
Post by danpep »
@madgeni,
I have now forwarded my external port to my Domoiticz SSL port and tested that this is working from outside my LAN. I am still not getting any devices in Alexa and now I don't even see the controlicz IP appearing in my domoticz log. Could it be because I don't have a SSL certificate? In a browser I can ignore this but I don't know if this will trip up your interface.
Perhaps an error message could be shown on controlicz.com to help with troubleshooting in future.
Thanks again for any help. Beers and a review coming your way if I get this working.
Madgeni
Post by Madgeni »
Hi - have you had any luck? Been trawling through the various logs, i can see some control & discovery requests
danpep
Post by danpep »
@madgeni,
I went back to the alexa web and my devices have appeared and are working via the echo. Thanks for your help! $10 in yor PayPal as promised.
Madgeni
Post by Madgeni »
Thanks Danpep, that's very good of you - really pleased it's working - i think i need to be *much* clearer on the documentation on pre-req of https
remb0
Post by remb0 »
@magdeni
I use: https://domain.nl
port 443
username and pass
my devices are in roomplans, also the domain is working in and outside of my home.
And On my dns server (pi-hole) I see connections with status oke from lamya amazon while discovering.
But no more devices then my hue and ha-bridge.
