Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
giorgik
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by giorgik »
Madgeni wrote: Monday 04 June 2018 9:01 Add the device to a Room Plan in Domoticz
Thanks for your prompt reply, Nick!
Did I somehow miss that step while reading documentation? I don't remember it being covered anywhere
I'll give it a go once I get home
Madgeni
Post by Madgeni »
modular
Post by modular »
Madgeni wrote: Monday 04 June 2018 17:11 can you disable the skill in your Alexa app, and reenable it?
or have i misunderstood, and this is more of a port forwarding issue?
I guess it is a connection problem, but i did nothing change to my config. The controlicz site only gives no connection message. No extra information. also when i go to the devices section on the controlicz site that does not seem to work? So no sure if it is really on my side.
Dahl1632
Target OS: OS X
Post by Dahl1632 »
I have the same issue. Port forwarding works but controlicz times out...
My config has been working flawlessly for months but all of sudden it stopped working.
freijn
Domoticz version: Stable
Post by freijn »
disable the skill in your Alexa app, and reenable it? and it will work again. ( had same here )
Madgeni
Post by Madgeni »
modular wrote: Wednesday 06 June 2018 14:08
Hi, if you can’t see any devices in your profile, then it’s a connection issue. Remind me, did you email me about this? If not, can you email from your Controlicz profile, and i’ll take a look
raptorjr
Post by raptorjr »
Everything was working until a few days ago. No I cant get it to work, test connection fails. I have not changed domain, or port. Tried to change the password and is able to login to my Domoticz manually with the same username and password.
If I press Devices in Controlicz page I get logged out, don't know if that means anything?
How can I find out where the problem is?
RvdB
Post by RvdB »
Madgeni wrote: Thursday 07 June 2018 11:39
I was the one contact you via email, but we resolved my problem as being a to restrictive hostname rule on my (pfSense) firewall.
raptorjr
Post by raptorjr »
raptorjr wrote: Friday 08 June 2018 18:12 Everything was working until a few days ago. No I cant get it to work, test connection fails. I have not changed domain, or port. Tried to change the password and is able to login to my Domoticz manually with the same username and password.
So I'm still trying to find the problem. I have checked and I'm able to reach Domoticz from the Internet using the same port as I have used in my Controlicz profile. I don't have my own ssl certificate, I'm using the builtin from Domoticz, and have always used that. But is it not possible to use this anymore? Because the only problem I can see now is that I have to accept that the certificate isn't trusted, and then I can use the login as usual.
Controlicz can't handle that anymore?
Madgeni
Post by Madgeni »
Hi Raptorjr - can you mail me from your Controlicz profile, and i’ll take a look
raptorjr
Post by raptorjr »
I can't send a message, it is only stuck in the outbox. But my profile is my username here at hotmail.com
raptorjr
Post by raptorjr »
I got a new updated of Domoticz and now everything works again. Guess there were some problem there.
Damsee
Domoticz version: 4.10717
Post by Damsee »
Madgeni wrote: Tuesday 03 April 2018 14:58 French is now live :)
Magnifique !
Thank you so much Nick, Controlicz is working in french as well (i never used the english version as i was using ha-bridge before this weekend and the french release of Echo in France). Quite difficult to set the names as Alexa was confusing "bedroom 1" and "bedroom 2", any tips would be welcome lol.
I found out through the reading of that thread that selector switches are not supported yet by Alexa...
I have some heaters i tried unsuccessfully ; please let us know if that changes.
Many thanks for your work :D
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
skybehind
Post by skybehind »
I think the SSL certificate expired for Controlicz. My stuff stopped working and when I visited the site, I noticed that it expired today.
Madgeni
Post by Madgeni »
Urgh! Will refresh it when i get home from work - have new cert, just needs installing.
This won’t affect Controlicz usage, only the site
Scoobydoo
Post by Scoobydoo »
I wondered why I couldn't link in the Alexa app. Kept on getting unable to link error message. Its prob due to the certificate issue then.
Madgeni
Post by Madgeni »
Ok, all fixed :)
skybehind
Post by skybehind »
Hmm, I noticed it because my voice control stopped working, thought that may be the cause. It appears to be working now though, maybe it was just a coincidence.
Madgeni
Post by Madgeni »
well it *shouldn't* have affected it, but i don't like coincidences :)
Albynokwan
Target OS: OS X
Post by Albynokwan »
Hello
I have the exact same problem and it's been three days I've been fighting to connect controlicz, if someone can give me a hint of what you've done to solve it ?
Thanks in advance
