pushover sound
tiga
pushover sound
Post by tiga »
im testing out pushover and have the following problem:
in blockly when specifying the sound(in whatever prioroty), i get the "standard" sound on my Phone.
via the pushover-website sending a test message it works perfect!
how to solve this?
thank you!!
Denny64
Domoticz version: 2023.1
Re: pushover sound
Post by Denny64 »
Is "Always use default tone" unchecked on the Pushover app?
For me it works properly. Domoticz 3.5877 on Rpi3.
tiga
Re: pushover sound
Post by tiga »
Yes it is unchecked
Denny64
Re: pushover sound
Post by Denny64 »
Which domoticz version do you have?
Has the same behavior in switch notification?
tiga
Re: pushover sound
Post by tiga »
Version: 3.8153
in switch notification i cannot chose a sound
tiga
Re: pushover sound
Post by tiga »
just did a test with sending a message in lua...same result
Denny64
Re: pushover sound
Post by Denny64 »
Try to set two different sounds in the app, not stock sounds, (one for normal level and one for alarm) and try to see If Domoticz works well. Don't forget to check "Always use the default tone".
If It works, then go back, uncheck "Always use the default tone" and test If different stock sounds are correctly played with Domoticz.
George
Domoticz version: V4.10717
Re: pushover sound
Post by George »
Hi, Same problem here.
No matter what i tried, I alway get the default tone (Even tried with a dummy switch):
Event test schakelaar (Dummy Switch).JPG (33.1 KiB) Viewed 1430 times
Played a lot with settings in App, but cant solve the problem.
settings 1.JPG (94.59 KiB) Viewed 1430 times
What am i doing wrong?
Raspberry Pi 3 Model B+ | Domoticz V4.9700 (Build Date: 2018-06-23 16:24:51) | Aeotec ZW090 Z-Stick Gen5 EU
settings 1.JPG (94.59 KiB) Viewed 1431 times
Event test schakelaar (Dummy Switch).JPG (33.1 KiB) Viewed 1431 times
Using: Domoticz V4.10717, Raspberry 3B+, Z-wave plus, Wemos
George
Re: pushover sound
Post by George »
Strange, but in case i choose:
Through subsystem "all", than the sound choice works.
But Through subsystem "pushover" I alway get the default sound and sound choice plays alway default sound, no matter what i choose.
Through subsystem all sound choice works but default sound when subsystem is pushover.JPG
Through subsystem all sound choice works but default sound when subsystem is pushover.JPG (34.54 KiB) Viewed 1425 times
Ofcourse I do not want to send it to all subsystems! Only to pushover.
tlkg
Domoticz version: 2021.1
Re: pushover sound
Post by tlkg »
Any new developments on this?
I have the same problem, when Pushover is selected, notification sound is always the "Default" regardless of what is specified.
Plantje
Re: pushover sound
Post by Plantje »
I have a similar issue with the notification sound of Telegram.
For some reason every movement detected on my multi sensor is seen as a complete new category by my phone.
See this: https://www.domoticz.com/forum/viewtopi ... 94#p203267
