pushover sound
tiga
pushover sound
im testing out pushover and have the following problem:
in blockly when specifying the sound(in whatever prioroty), i get the "standard" sound on my Phone.
via the pushover-website sending a test message it works perfect!
how to solve this?
thank you!!
how to solve this?
thank you!!
- Denny64
- Domoticz version: 2023.1
Re: pushover sound
Is "Always use default tone" unchecked on the Pushover app?
For me it works properly. Domoticz 3.5877 on Rpi3.
tiga
Re: pushover sound
Yes it is unchecked
- Denny64
Re: pushover sound
Which domoticz version do you have?
Has the same behavior in switch notification?
tiga
Re: pushover sound
Version: 3.8153
in switch notification i cannot chose a sound
tiga
Re: pushover sound
just did a test with sending a message in lua...same result
- Denny64
Re: pushover sound
Try to set two different sounds in the app, not stock sounds, (one for normal level and one for alarm) and try to see If Domoticz works well. Don't forget to check "Always use the default tone".
If It works, then go back, uncheck "Always use the default tone" and test If different stock sounds are correctly played with Domoticz.
- George
- Domoticz version: V4.10717
Re: pushover sound
Hi, Same problem here.
No matter what i tried, I alway get the default tone (Even tried with a dummy switch): Played a lot with settings in App, but cant solve the problem. What am i doing wrong?
Raspberry Pi 3 Model B+ | Domoticz V4.9700 (Build Date: 2018-06-23 16:24:51) | Aeotec ZW090 Z-Stick Gen5 EU
- settings 1.JPG (94.59 KiB) Viewed 1446 times
- Event test schakelaar (Dummy Switch).JPG (33.1 KiB) Viewed 1446 times
Using: Domoticz V4.10717, Raspberry 3B+, Z-wave plus, Wemos
- George
Re: pushover sound
Strange, but in case i choose:
Through subsystem "all", than the sound choice works.
But Through subsystem "pushover" I alway get the default sound and sound choice plays alway default sound, no matter what i choose.
Ofcourse I do not want to send it to all subsystems! Only to pushover.
tlkg
- Domoticz version: 2021.1
Re: pushover sound
Any new developments on this?
I have the same problem, when Pushover is selected, notification sound is always the "Default" regardless of what is specified.
Plantje
Re: pushover sound
I have a similar issue with the notification sound of Telegram.
For some reason every movement detected on my multi sensor is seen as a complete new category by my phone.
See this: https://www.domoticz.com/forum/viewtopi ... 94#p203267
