pandemicz
Post by pandemicz »
For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
timh1004
Post by timh1004 »
pandemicz wrote:For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
Finally :-) thanks for notifying!
Edit: mine‘s not yet ready for the update
deennoo
Post by deennoo »
OK cool which mihome app version dis you have ?
http://domo-attitude.fr
pandemicz
Post by pandemicz »
deennoo wrote: Tuesday 19 September 2017 18:23
Currently on 4.3.11
deennoo
Post by deennoo »
Currently on 4.3.11
Same for me, update Fw isn't available on my side...let's wait
islandman
Post by islandman »
deennoo wrote: Tuesday 19 September 2017 18:50
pandemicz wrote:
deennoo wrote: Tuesday 19 September 2017 18:23 OK cool which mihome app version dis you have ?
Currently on 4.3.11
You need to update the firmware from the gateway not the APP ;)
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
islandman wrote: Wednesday 20 September 2017 16:28
pandemicz wrote: Currently on 4.3.11
What do you meen by that ?
I'm checking the firmware update by opening Mi Home app, then select the gateway, three dots then Check for firmware update.
deennoo
Post by deennoo »
Thx bro...not my First update, just need to check it...and be sure...app update can improve Fw update since their is no other way to ask for it...
DAVIZINHO
Post by DAVIZINHO »
hello!,
In xiaomi mihome app there is a easy scene that i want to replicate in domoticz.
Now i can create a scene with blocky that turn purifier on when detect movement in the sensor but i cant make this other scene:
"when move detector not detect move in 30 minutes, then purifier off"
Anyone can help me?. I tried with blocky but i cant :-(
thanks
-David-
pandemicz
Post by pandemicz »
DAVIZINHO wrote: Wednesday 20 September 2017 19:20 hello!,
thanks
-David-
Show what you got in Blocky
marcotini
Post by marcotini »
I just update to the version 3.8424 and... why the water leak doesn't appear to the unused devices?
borewicz
Post by borewicz »
Has anyone managed to start the (Xiaomi Aqara Temperature Humidity) pressure sensor with homebridge / edomoticz ?
EVE shows it as voltage sensor with "0" :/
Peggy
Post by Peggy »
chatainsim wrote: Friday 15 September 2017 10:14
xbox2610 wrote: Thursday 14 September 2017 22:17 Hi everyone I wanted to ask if by accident there are working problems with aqara human body sensor and domoticz?
I have some issue with body sensor (1st gen) that doesn't detect motion but it's not related to Domoticz has I also can't see the motion in Mi Home.
My feedback, as I use 4 of them for alarm purpose :
- One have been triggering some "false positive" alerts during 4 weeks. Now it is back to normal.
- The last one I received, I put it above my front door, in a dry place, facing the ground. It immediatly started sending continuous motion alerts, non stop for 24h. Now it is indoor, no problem. I will check whether the other sensors get crazy as well outside.
The other ones are working fine.
xbox2610
Post by xbox2610 »
Hi everyone I wanted to know if the aqara human body sensor work with domoticz?
Thank you
timh1004
Post by timh1004 »
xbox2610 wrote:Hi everyone I wanted to know if the aqara human body sensor work with domoticz?
Thank you
It does work! But the built in brightness sensor is not very accurate :-/
Last edited by timh1004 on Thursday 21 September 2017 18:38, edited 1 time in total.
timh1004
Post by timh1004 »
I was able to update the gateway firmware to 1.4.1_150.0134 with the latest iOS version of the MiHome App. Finally, the left button of the wall switches works again!!
DAVIZINHO
Post by DAVIZINHO »
pandemicz wrote: Wednesday 20 September 2017 20:29
thanks
-David-
i use this blocky to turn on the purifier.
But i want to create a blocky to turn OFF the purifier when not detect movement in "movement sensor" in 30 minutes :-(
deennoo
Post by deennoo »
thanks
-David-
Use LUA that the only way to do your script
DAVIZINHO
Post by DAVIZINHO »
deennoo wrote: Thursday 21 September 2017 21:35
ok, thanks for the info.
Can you tell me how can i make this on lua?.
I only need help for the "if" comand because i dont know how to program the "if sensor not detect move in 30min then"
Egregius
Domoticz version: v2024.7
Post by Egregius »
With pass2php:
if(timestamp('motion')<time-1800&&status('motion')=='Off'&&status('purifier')=='On')sw('purifier','Off');
Can it be more simple?
Let's see how much code you'll need in lua to do the same...
