For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
timh1004
Finallypandemicz wrote:For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
Edit: mine‘s not yet ready for the update
deennoo
OK cool which mihome app version dis you have ?pandemicz wrote:For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
http://domo-attitude.fr
Currently on 4.3.11deennoo wrote: Tuesday 19 September 2017 18:23OK cool which mihome app version dis you have ?pandemicz wrote:For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
deennoo
Same for me, update Fw isn't available on my side...let's waitpandemicz wrote:Currently on 4.3.11deennoo wrote: Tuesday 19 September 2017 18:23OK cool which mihome app version dis you have ?pandemicz wrote:For all those of us, who had a problem with left click on wireless switch, there's a .150 update rolling out, which is fixing the problem, just checked.
islandman
You need to update the firmware from the gateway not the APP
chatainsim
- Domoticz version: v4.11307
What do you meen by that ?
I'm checking the firmware update by opening Mi Home app, then select the gateway, three dots then Check for firmware update.
deennoo
Thx bro...not my First update, just need to check it...and be sure...app update can improve Fw update since their is no other way to ask for it...islandman wrote:You need to update the firmware from the gateway not the APPdeennoo wrote: Tuesday 19 September 2017 18:50Same for me, update Fw isn't available on my side...let's waitpandemicz wrote: Currently on 4.3.11
DAVIZINHO
hello!,
In xiaomi mihome app there is a easy scene that i want to replicate in domoticz.
Now i can create a scene with blocky that turn purifier on when detect movement in the sensor but i cant make this other scene:
"when move detector not detect move in 30 minutes, then purifier off"
Anyone can help me?. I tried with blocky but i cant
thanks
-David-
thanks
-David-
Show what you got in BlockyDAVIZINHO wrote: Wednesday 20 September 2017 19:20 hello!,
thanks
-David-
- marcotini
I just update to the version 3.8424 and... why the water leak doesn't appear to the unused devices?
borewicz
Has anyone managed to start the (Xiaomi Aqara Temperature Humidity) pressure sensor with homebridge / edomoticz ?
EVE shows it as voltage sensor with "0" :/
Peggy
My feedback, as I use 4 of them for alarm purpose :chatainsim wrote: Friday 15 September 2017 10:14I have some issue with body sensor (1st gen) that doesn't detect motion but it's not related to Domoticz has I also can't see the motion in Mi Home.xbox2610 wrote: Thursday 14 September 2017 22:17 Hi everyone I wanted to ask if by accident there are working problems with aqara human body sensor and domoticz?
- One have been triggering some "false positive" alerts during 4 weeks. Now it is back to normal.
- The last one I received, I put it above my front door, in a dry place, facing the ground. It immediatly started sending continuous motion alerts, non stop for 24h. Now it is indoor, no problem. I will check whether the other sensors get crazy as well outside.
The other ones are working fine.
xbox2610
Hi everyone I wanted to know if the aqara human body sensor work with domoticz?
Thank you
Thank you
timh1004
It does work! But the built in brightness sensor is not very accurate :-/xbox2610 wrote:Hi everyone I wanted to know if the aqara human body sensor work with domoticz?
Thank you
Last edited by timh1004 on Thursday 21 September 2017 18:38, edited 1 time in total.
timh1004
I was able to update the gateway firmware to 1.4.1_150.0134 with the latest iOS version of the MiHome App. Finally, the left button of the wall switches works again!!
DAVIZINHO
i use this blocky to turn on the purifier.pandemicz wrote: Wednesday 20 September 2017 20:29Show what you got in BlockyDAVIZINHO wrote: Wednesday 20 September 2017 19:20 hello!,
thanks
-David-
But i want to create a blocky to turn OFF the purifier when not detect movement in "movement sensor" in 30 minutes
- blocky_purifier_on.jpg (53.18 KiB) Viewed 3437 times
deennoo
Use LUA that the only way to do your scriptDAVIZINHO wrote:i use this blocky to turn on the purifier.pandemicz wrote: Wednesday 20 September 2017 20:29Show what you got in BlockyDAVIZINHO wrote: Wednesday 20 September 2017 19:20 hello!,
thanks
-David-
DAVIZINHO
deennoo wrote: Thursday 21 September 2017 21:35Use LUA that the only way to do your scriptDAVIZINHO wrote:i use this blocky to turn on the purifier.
ok, thanks for the info.
Can you tell me how can i make this on lua?.
I only need help for the "if" comand because i dont know how to program the "if sensor not detect move in 30min then"
- Egregius
- Domoticz version: v2024.7
With pass2php:
Can it be more simple?
Let's see how much code you'll need in lua to do the same...
if(timestamp('motion')<time-1800&&status('motion')=='Off'&&status('purifier')=='On')sw('purifier','Off');Let's see how much code you'll need in lua to do the same...
