framb0ise v2 - awesome new dashboard!
tontze
Domoticz version: Beta Ch
Re: framb0ise v2 - awesome new dashboard!
Post by tontze »
safi78 wrote:
tontze wrote:
Blinds still dotn have control over it, i have "blinds inverted" control
That's correct. This project is 2 days live.
If you want to add it yourself, be my guest, otherwise add a request to the 'issues' page? Like suggested in the first post? That way we can keep track of all the work we still have to do, Rome wasn't built in 1 day ;)
Yes im sry, i got impression that it was allready added after jvdz presented code for it :)
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
safi78
Domoticz version: LastBeta
Post by safi78 »
tontze wrote: Yes im sry, i got impression that it was allready added after jvdz presented code for it :)
No prob. But we don't both don't have blinds inverted. Could you send a json file of that device? Then we can implement it for you?
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
Post by safi78 »
No more config.js :)
Screen Shot 2017-04-25 at 16.26.19.png (247.15 KiB) Viewed 2719 times
qwerk
Post by qwerk »
nicely done, where does framboise store the password?
and the thicks?
tontze
Post by tontze »
   "ActTime" : 1493135755,
   "ServerTime" : "2017-04-25 18:55:55",
   "Sunrise" : "05:31",
   "Sunset" : "21:13",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "RFLink",
         "HardwareType" : "RFLink Gateway USB",
         "HardwareTypeVal" : 46,
         "HaveDimmer" : false,
         "HaveGroupCmd" : false,
         "HaveTimeout" : false,
         "ID" : "00D04282",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-04-25 08:00:02",
         "Level" : 99,
         "LevelInt" : 99,
         "MaxDimLevel" : 100,
         "Name" : "Blinds",
         "Notifications" : "false",
         "PlanID" : "4",
         "PlanIDs" : [ 4 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "BrelMotor",
         "SwitchType" : "Blinds Inverted",
         "SwitchTypeVal" : 6,
         "Timers" : "true",
         "Type" : "Light/Switch",
         "TypeImg" : "blinds",
         "Unit" : 193,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "966",
         "YOffset" : "219",
         "idx" : "162"
   "status" : "OK",
   "title" : "Devices"
Do you mean this json ?
-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
jvdz
Domoticz version: 4.107
Post by jvdz »
marcotrumpet wrote:Hi
Just started yesterday with that awesome dashboard. No problem at all, but.. if I connect to http://myddns:port/framb0ise when I'm under wifi it's ok, if I go out I can connect to the page but nothing is listed.. It seems that I don't have any roomplans.. If I connect to domoticz main page with the same ddns everythings works fine.
Did you also put that host ( http://myddns:port) in config.js?
Jos
jvdz
Post by jvdz »
@tontze ,
Am I correct to assume that this blind doesn't have an percentage option, but merely UP/DOWN ( and possibly STOP)?
Jos
marcotrumpet
Re: RE: Re: framb0ise v2 - awesome new dashboard!
Post by marcotrumpet »
Jos
Yes I did. But the domoticz local port and the external one I use eith ddns are different. If I set in config "http://ddns:domoticzinternalport" or "http://ddns:domoticzexternalport" nothing appen
Inviato dal mio SM-G950F utilizzando Tapatalk
EDIT
My bad.. using "http://ddns:externalport" work! Image thanks mate
Maikie
Post by Maikie »
For my information, updating just by cloning from git again with this command?
git clone https://github.com/safi78/framb0ise
qwerk
Post by qwerk »
my smoke detectors are red again, without smoke or fire
jvdz
Post by jvdz »
EDIT
Sounds great, but you do realize that this setup is using one single static setup at this moment, so it can either be the internal or external port.
Maybe we should simply use the original URL's ip:port.
Jos
safi78
Post by safi78 »
Maikie wrote:For my information, updating just by cloning from git again with this command?
yes. with the new settings window your settings will be stored for future updates.
safi78
Post by safi78 »
qwerk wrote:my smoke detectors are red again, without smoke or fire
Something went wrong with our first Pull Request, some code got reverted to older state. I just fixed this for you (again)
safi78
Post by safi78 »
qwerk wrote:nicely done, where does framboise store the password?
and the thicks?
All stuff is stored in 'local storage'. very safe and secure, only YOUR browser can access this, nothing is accessible for others or send over.
It's like a very permanent cookie :)
CaesarPL
Post by CaesarPL »
Good evening, first of all - great job, thank you very much!
Excuse me for silly question, but how can I configure Traffic and Weather? Does it work only for Netherlands?
EDIT:
Ahhhh, DarkSky is missing. But what about Traffic?
safi78
Post by safi78 »
CaesarPL wrote:Good evening, first of all - great job, thank you very much!
And, if you can provide us with a good api for a source for Traffic and Weather in $yourcountry i'd gladly take a look?
safi78
Post by safi78 »
EDIT:
What do you mean with your EDIT?
CaesarPL
Post by CaesarPL »
EDIT:
Silly again and tired a bit. I thought that I don't have Weather as I haven't configured DarkSky, yet. Now I understand that Weather and Traffic works only in Netherlands. Duh, I always wanted to move to Netherlands from Poland...
safi78
Post by safi78 »
EDIT:
dobry wieczór :)
yeah I should doublecheck on the darksystuff an generate a warning ..
So, if you have a polish api, i can see what i can do? I'll need some help translating though, but a very close friend of mine is half Polish, that shouldn't be a problem :)
CaesarPL
Post by CaesarPL »
safi78 wrote:
dobry wieczór :)
+1 ! Even letters are fine!
safi78 wrote: yeah I should doublecheck on the darksystuff an generate a warning ..
Unfortunately, I don't know any API that could work...
