Yes im sry, i got impression that it was allready added after jvdz presented code for itsafi78 wrote:That's correct. This project is 2 days live.tontze wrote:
Blinds still dotn have control over it, i have "blinds inverted" control
If you want to add it yourself, be my guest, otherwise add a request to the 'issues' page? Like suggested in the first post? That way we can keep track of all the work we still have to do, Rome wasn't built in 1 day
framb0ise v2 - awesome new dashboard!
tontze
- Domoticz version: Beta Ch
Re: framb0ise v2 - awesome new dashboard!
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
safi78
- Domoticz version: LastBeta
No prob. But we don't both don't have blinds inverted. Could you send a json file of that device? Then we can implement it for you?tontze wrote: Yes im sry, i got impression that it was allready added after jvdz presented code for it
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
No more config.js
qwerk
nicely done, where does framboise store the password?
and the thicks?
and the thicks?
tontze
safi78 wrote:No prob. But we don't both don't have blinds inverted. Could you send a json file of that device? Then we can implement it for you?tontze wrote: Yes im sry, i got impression that it was allready added after jvdz presented code for it
"ActTime" : 1493135755,
"ServerTime" : "2017-04-25 18:55:55",
"Sunrise" : "05:31",
"Sunset" : "21:13",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Open",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 6,
"HardwareName" : "RFLink",
"HardwareType" : "RFLink Gateway USB",
"HardwareTypeVal" : 46,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "00D04282",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-25 08:00:02",
"Level" : 99,
"LevelInt" : 99,
"MaxDimLevel" : 100,
"Name" : "Blinds",
"Notifications" : "false",
"PlanID" : "4",
"PlanIDs" : [ 4 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "BrelMotor",
"SwitchType" : "Blinds Inverted",
"SwitchTypeVal" : 6,
"Timers" : "true",
"Type" : "Light/Switch",
"TypeImg" : "blinds",
"Unit" : 193,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "966",
"YOffset" : "219",
"idx" : "162"
"status" : "OK",
"title" : "Devices"
}-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- jvdz
- Domoticz version: 4.107
Did you also put that host ( http://myddns:port) in config.js?marcotrumpet wrote:Hi
Just started yesterday with that awesome dashboard. No problem at all, but.. if I connect to http://myddns:port/framb0ise when I'm under wifi it's ok, if I go out I can connect to the page but nothing is listed.. It seems that I don't have any roomplans.. If I connect to domoticz main page with the same ddns everythings works fine.
Jos
- jvdz
@tontze ,
Am I correct to assume that this blind doesn't have an percentage option, but merely UP/DOWN ( and possibly STOP)?
Jos
Jos
marcotrumpet
Re: RE: Re: framb0ise v2 - awesome new dashboard!
Yes I did. But the domoticz local port and the external one I use eith ddns are different. If I set in config "http://ddns:domoticzinternalport" or "http://ddns:domoticzexternalport" nothing appenjvdz wrote:Did you also put that host ( http://myddns:port) in config.js?marcotrumpet wrote:Hi
Jos
Inviato dal mio SM-G950F utilizzando Tapatalk
EDIT
My bad.. using "http://ddns:externalport" work!
thanks mate-
Maikie
For my information, updating just by cloning from git again with this command?
git clone https://github.com/safi78/framb0ise-
qwerk
my smoke detectors are red again, without smoke or fire
- jvdz
Sounds great, but you do realize that this setup is using one single static setup at this moment, so it can either be the internal or external port.marcotrumpet wrote:jvdz wrote:marcotrumpet wrote:Hi
EDIT
My bad.. using "http://ddns:externalport" work!thanks mate
Maybe we should simply use the original URL's ip:port.
Jos
safi78
yes. with the new settings window your settings will be stored for future updates.Maikie wrote:For my information, updating just by cloning from git again with this command?
safi78
Something went wrong with our first Pull Request, some code got reverted to older state. I just fixed this for you (again)qwerk wrote:my smoke detectors are red again, without smoke or fire
safi78
All stuff is stored in 'local storage'. very safe and secure, only YOUR browser can access this, nothing is accessible for others or send over.qwerk wrote:nicely done, where does framboise store the password?
and the thicks?
It's like a very permanent cookie
CaesarPL
Good evening, first of all - great job, thank you very much!
Excuse me for silly question, but how can I configure Traffic and Weather? Does it work only for Netherlands?
EDIT:
Ahhhh, DarkSky is missing. But what about Traffic?
EDIT:
safi78
ThanksCaesarPL wrote:Good evening, first of all - great job, thank you very much!
And, if you can provide us with a good api for a source for Traffic and Weather in $yourcountry i'd gladly take a look?
safi78
What do you mean with your EDIT?CaesarPL wrote:Good evening, first of all - great job, thank you very much!
EDIT:
CaesarPL
Silly again and tired a bit. I thought that I don't have Weather as I haven't configured DarkSky, yet. Now I understand that Weather and Traffic works only in Netherlands. Duh, I always wanted to move to Netherlands from Poland...safi78 wrote:What do you mean with your EDIT?CaesarPL wrote:Good evening, first of all - great job, thank you very much!
EDIT:
safi78
dobry wieczórCaesarPL wrote:Silly again and tired a bit. I thought that I don't have Weather as I haven't configured DarkSky, yet. Now I understand that Weather and Traffic works only in Netherlands. Duh, I always wanted to move to Netherlands from Poland...safi78 wrote:What do you mean with your EDIT?CaesarPL wrote:Good evening, first of all - great job, thank you very much!
EDIT:
yeah I should doublecheck on the darksystuff an generate a warning ..
So, if you have a polish api, i can see what i can do? I'll need some help translating though, but a very close friend of mine is half Polish, that shouldn't be a problem
CaesarPL
+1 ! Even letters are fine!safi78 wrote:
dobry wieczór![]()
Unfortunately, I don't know any API that could work...safi78 wrote: yeah I should doublecheck on the darksystuff an generate a warning ..
