If you have a backup of your installation with 2 gateway maybe you can use it, and remove the gateway who is on your baytrail.benj29 wrote:Hehe !!!!
Good idea !
I have a raspberry pi3, free of charge, because i move my installation to another Baytrail, more reliable!!!!
Now, i need to add all my sensors again... but if your idea will works it, it is perfect !
deennoo
http://domo-attitude.fr
deennoo
Second solution is to made a VirtualMachine with debian on your baytrail. And compile domoticz from source.benj29 wrote:Hehe !!!!
Good idea !
On mine i got exsi and some 3 virtual machine,
benj29
He
that is a good idea too !
In fact, i have removed on the Xiaomi software... so no backup inside !
I need to remove now and add it again... I expect to do it this weekend.
Raspberry idea is not stupid and i can use it for other thing or add extra services on the second raspberry
levynger
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Didn't try, but you can try also try to compile on the same machine 2nd domoticz in a different folder, from corbin's git, listening on different port.deennoo wrote:Second solution is to made a VirtualMachine with debian on your baytrail. And compile domoticz from source.benj29 wrote:Hehe !!!!
Good idea !
On the same macho you'll have 2 servers listening on different ports, different databases, etc..
Then set slave to the LocalHost on the relevant port..
Sent from my SM-N920C using Tapatalk
- vetalok
- Domoticz version: 3.6273
Hi, @corbin
After update from your repository, stopped working motion detector and door opening sensor.
When I update hardware, I see 2 new devices (switch). What is it ?
2017-02-07 10:09:40.492 XiaomiGateway: stopped
2017-02-07 10:09:40.492 XiaomiGateway: Worker started...
2017-02-07 10:09:40.584 XiaomiGateway: RGB Gateway Detected
2017-02-07 10:09:40.584 (XiaomiGateway) Lighting Limitless/Applamp (лампа gateway, переключатель)
2017-02-07 10:09:40.588 (XiaomiGateway) Light/Switch (N1)
2017-02-07 10:09:40.588 (XiaomiGateway) Temp (темп+вол, кімната 1 (Xiaomi))
2017-02-07 10:09:40.589 (XiaomiGateway) Humidity (вологість, кімната 1 (XIaomi))
2017-02-07 10:09:40.589 (XiaomiGateway) Light/Switch (N2)
benj29
I see a lot of "double" sensor on my installation but with the same feature.
Example for :
Example for :
32 XIAOMI-GARAGE 29CC40B2 1 Anneau lumineux Garage Lighting Limitless/Applamp RGBW Off
1 XIAOMI-GARAGE 0785A7CF 1 Xiaomi RGB Gateway Lighting Limitless/Applamp RGBW Off- corbin
if you are running a single gateway, maybe deleting the devices will stop the duplicates. multiple gateways will add duplicate items however.
murtadin
@Corbin - tried today last beta from your git V3.6635 - i have got semi working build without setting ip manual in XiaomiGateway.cpp. Detected all zigbee devices - but still have error with invalid key, when trying to switch zigbee plug or gatweway light for example.
In XiaomiGateway.cpp i see #ifdef _DEBUG - how can i see output?
- galadril
- Domoticz version: latest
Double click is not correctly matched to the selector with the latest beta..
The selector becomes state 'UNDEFINED'.
When i press long click.. it triggers long click + double right after eachother
lamouette
Does anyone tried to connect a remote Xiaomi Gateway to domoticz ?
With 9898 port open, it should be ok, right ?
- corbin
murtadin wrote:@Corbin - tried today last beta from your git V3.6635 - i have got semi working build without setting ip manual in XiaomiGateway.cpp. Detected all zigbee devices - but still have error with invalid key, when trying to switch zigbee plug or gatweway light for example.
cmake -DCMAKE_BUILD_TYPE=Debug .Question about the Xiaomi Gateway in Domoticz? Please check the Wiki first: https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
- corbin
Depends on your network setup - it will need to pass through the UDP multicast packets to begin with.lamouette wrote:Hi,
- corbin
probably just need to delete and re-add the switch, it has extra states now: Off|Click|Long Click|Long Click Release|Double Clickgaladril wrote:Double click is not correctly matched to the selector with the latest beta..
lamouette
Ok, so it should not be a problemcorbin wrote:Depends on your network setup - it will need to pass through the UDP multicast packets to begin with.lamouette wrote:Hi,
lamouette
Another question.
Yesterday, I tried to replace a 433 Temp/Hum device by the Xiaomi one and it didn't work at all.
In fact the Xiaomi has just disapeared instead of taking place of the 433 one.
Anyone already try this operation ?
woody4165
Hi deennoodeennoo wrote: Guys ! Corbin and you are the mens of Xiaomi In Domoticz Dev !
got a small teaser for you :
http://domo-attitude.fr/cube-xiaomi-teaser/
Xiaomi Cube + Yeelight : Rotative dimmer !
can you share the script to get dimming light with Cube, looks very nice?
Should it work also with a colored Yeelight, just for the dimming part?
BTW, just got one, but I'm not able to get these status:
tap_twice
swing
alert
free_fall
Can someone explain how to get those status?
deennoo
I promise i will, i m just waiting the next stable version, because this need a change about svalues for applamp/limitless device and need to be tested beforewoody4165 wrote:Hi deennoodeennoo wrote: Guys ! Corbin and you are the mens of Xiaomi In Domoticz Dev !
tap_twice
swing
alert
free_fall
You can try it be your own : idea is
check svalues of your dimmable device
check rotation svalues
if rotation value change then
dimmer svalues = previous dimmer svalues + rotation value
mKotek
+1woody4165 wrote:Hi deennoodeennoo wrote: Guys ! Corbin and you are the mens of Xiaomi In Domoticz Dev !
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
woody4165
Thanks deennoo.
How can I check rotation svalue modification? Just started to write a small script, but don't understand how to do it...
benj29
Working perfectly!deennoo wrote:I got your solution !benj29 wrote:Not sure to understand. Jeedom plug-in is in beta? Yes, same nightmare in this case lol!
I try to remove all my sensors from the second gateway to add on the first one, but I cannot add more than 31...
Envoyé de mon Moto G (4) en utilisant Tapatalk
Add a second domoticz+rpi/syno or anything else for the 2nd gateway and use the domoticz slave system to add the 2nd gateway hardware to your main
