deennoo
Post by deennoo »
benj29 wrote:Hehe !!!! :)
Good idea ! :)
I have a raspberry pi3, free of charge, because i move my installation to another Baytrail, more reliable :) !!!!
Now, i need to add all my sensors again... but if your idea will works it, it is perfect !
If you have a backup of your installation with 2 gateway maybe you can use it, and remove the gateway who is on your baytrail.
http://domo-attitude.fr
deennoo
Post by deennoo »
Good idea ! :)
Second solution is to made a VirtualMachine with debian on your baytrail. And compile domoticz from source.
On mine i got exsi and some 3 virtual machine,
benj29
Post by benj29 »
He :) that is a good idea too !
In fact, i have removed on the Xiaomi software... so no backup inside !
I need to remove now and add it again... I expect to do it this weekend.
Raspberry idea is not stupid and i can use it for other thing or add extra services on the second raspberry :)
levynger
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by levynger »
Good idea ! :)
Didn't try, but you can try also try to compile on the same machine 2nd domoticz in a different folder, from corbin's git, listening on different port.
On the same macho you'll have 2 servers listening on different ports, different databases, etc..
Then set slave to the LocalHost on the relevant port..
Sent from my SM-N920C using Tapatalk
vetalok
Domoticz version: 3.6273
Post by vetalok »
Hi, @corbin
After update from your repository, stopped working motion detector and door opening sensor.
When I update hardware, I see 2 new devices (switch). What is it ?
2017-02-07 10:09:40.492 XiaomiGateway: stopped
2017-02-07 10:09:40.492 XiaomiGateway: Worker started...
2017-02-07 10:09:40.584 XiaomiGateway: RGB Gateway Detected
2017-02-07 10:09:40.584 (XiaomiGateway) Lighting Limitless/Applamp (лампа gateway, переключатель)
2017-02-07 10:09:40.588 (XiaomiGateway) Light/Switch (N1)
2017-02-07 10:09:40.588 (XiaomiGateway) Temp (темп+вол, кімната 1 (Xiaomi))
2017-02-07 10:09:40.589 (XiaomiGateway) Humidity (вологість, кімната 1 (XIaomi))
2017-02-07 10:09:40.589 (XiaomiGateway) Light/Switch (N2)
benj29
Post by benj29 »
I see a lot of "double" sensor on my installation but with the same feature.
Example for :
32	XIAOMI-GARAGE	29CC40B2	1	Anneau lumineux Garage	Lighting Limitless/Applamp	RGBW	Off
1	XIAOMI-GARAGE	0785A7CF	1	Xiaomi RGB Gateway	Lighting Limitless/Applamp	RGBW	Off
corbin
Post by corbin »
if you are running a single gateway, maybe deleting the devices will stop the duplicates. multiple gateways will add duplicate items however.
murtadin
Post by murtadin »
@Corbin - tried today last beta from your git V3.6635 - i have got semi working build without setting ip manual in XiaomiGateway.cpp. Detected all zigbee devices - but still have error with invalid key, when trying to switch zigbee plug or gatweway light for example.
In XiaomiGateway.cpp i see #ifdef _DEBUG - how can i see output?
galadril
Domoticz version: latest
Post by galadril »
Double click is not correctly matched to the selector with the latest beta..
The selector becomes state 'UNDEFINED'.
When i press long click.. it triggers long click + double right after eachother
lamouette
Post by lamouette »
Does anyone tried to connect a remote Xiaomi Gateway to domoticz ?
With 9898 port open, it should be ok, right ?
corbin
Post by corbin »
murtadin wrote:@Corbin - tried today last beta from your git V3.6635 - i have got semi working build without setting ip manual in XiaomiGateway.cpp. Detected all zigbee devices - but still have error with invalid key, when trying to switch zigbee plug or gatweway light for example.
cmake -DCMAKE_BUILD_TYPE=Debug .
see https://www.domoticz.com/wiki/Install.txt#Installation
corbin
Post by corbin »
lamouette wrote:Hi,
Depends on your network setup - it will need to pass through the UDP multicast packets to begin with.
corbin
Post by corbin »
galadril wrote:Double click is not correctly matched to the selector with the latest beta..
probably just need to delete and re-add the switch, it has extra states now: Off|Click|Long Click|Long Click Release|Double Click
lamouette
Post by lamouette »
corbin wrote:
lamouette wrote:Hi,
Ok, so it should not be a problem :)
lamouette
Post by lamouette »
Another question.
Yesterday, I tried to replace a 433 Temp/Hum device by the Xiaomi one and it didn't work at all.
In fact the Xiaomi has just disapeared instead of taking place of the 433 one.
Anyone already try this operation ?
woody4165
Post by woody4165 »
deennoo wrote: Guys ! Corbin and you are the mens of Xiaomi In Domoticz Dev !
got a small teaser for you :
http://domo-attitude.fr/cube-xiaomi-teaser/
Xiaomi Cube + Yeelight : Rotative dimmer !
Hi deennoo
can you share the script to get dimming light with Cube, looks very nice?
Should it work also with a colored Yeelight, just for the dimming part?
BTW, just got one, but I'm not able to get these status:
tap_twice
swing
alert
free_fall
Can someone explain how to get those status?
deennoo
Post by deennoo »
Hi deennoo
tap_twice
swing
alert
free_fall
I promise i will, i m just waiting the next stable version, because this need a change about svalues for applamp/limitless device and need to be tested before
You can try it be your own : idea is
check svalues of your dimmable device
check rotation svalues
if rotation value change then
dimmer svalues = previous dimmer svalues + rotation value
mKotek
Post by mKotek »
Hi deennoo
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
woody4165
Post by woody4165 »
Thanks deennoo.
How can I check rotation svalue modification? Just started to write a small script, but don't understand how to do it... :oops:
benj29
Post by benj29 »
deennoo wrote:
benj29 wrote:Not sure to understand. Jeedom plug-in is in beta? Yes, same nightmare in this case lol!
I try to remove all my sensors from the second gateway to add on the first one, but I cannot add more than 31...
Envoyé de mon Moto G (4) en utilisant Tapatalk
I got your solution !
Add a second domoticz+rpi/syno or anything else for the 2nd gateway and use the domoticz slave system to add the 2nd gateway hardware to your main
Working perfectly!
