arkoko
Not (yet?) I hope and think @corbin will comment this.
- corbin
the plug should update automatically to the korrekt type when detekted, so a problem there.paszczus wrote:Thank you @arkoko, i thought it will be added to Switches automatically. After manually adding it to Switches i can turn it off and on!
Is there a way to see power consumption too?
no power consumption available, if/when it is, I will add to Domoticz
deennoo
I think paszczus didn't know that we have to add device after detection to saw it on switch tab. Everything looks to work.corbin wrote:the plug should update automatically to the korrekt type when detekted, so a problem there.paszczus wrote:Thank you @arkoko, i thought it will be added to Switches automatically. After manually adding it to Switches i can turn it off and on!
@paszczus can you confirm that plug status is update when switch from MiHome app ?
http://domo-attitude.fr
paszczus
Yes, the plug status is updating when i change if from Xiaomi Mi app and vice versa.
It will be awesome if there will be power consumption status. I have ordered 3 more plugs
deennoo
Can you share with us plug message (text on log tab) ?
StasDemydiuk
I found this repository with some documentation for Xiaomi devices:
https://github.com/louisZL/lumi-gateway-local-api
It looks like plug power consumption can be taken:
https://github.com/louisZL/lumi-gateway ... er/plug.md
- corbin
power consumption is not reported
from the docs - https://github.com/louisZL/lumi-gateway ... i/issues/5
paszczus
Do you mean this?deennoo wrote:Can you share with us plug message (text on log tab) ?
deennoo
No this :
But with plug message...Corbin just confirme that message doesn't looks to be provied.
paszczus
Ahh, right:
2017-01-15 13:22:59.726 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.791 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.794 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:22:59.814 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.816 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:22:59.822 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.824 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:23:01.924 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:23:01.926 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:23:01.945 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:23:01.947 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
deennoo
Cmd bla bla bla is the message send by the gateway, domoticz "just" hear it and translate to his language.
As you can read their no power information, did you get it on MiHome app ?
paszczus
Yes, it works pretty nice:
deennoo
Ok cool, just have to be aware of a futur fw update !
Mat2Vence
- Domoticz version: 3.7449
One quick question regarding the door sensor. There is a behaviour I am not understanding. In domoticz, it looks like when the door is open, it is considered as closed in the status 1 minute after it has been open, whatever the case. I the mean time, if I am looking at the status on the xiaomi app, it is still open.
Any chance to know where it can come from?
I am using those sensor to know whether my velux are open or not... so that a bit painful to see there are closed when they are not
If you have any idea on where to investigate?? thnaks a lot!
Mat2Vence
I have just uploaded the last beta version and it seems it has been fixed. I now have the same status on both Domoticz and xiaomi app.
murtadin
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
First check /usr/bin/emerge if file exists. Check permitions. You are trying it under root user? If not -corbin wrote:murtadin wrote: you can try compile from source for the start.
I tried "emerge -v git", and it didn't work:
looks like you have to install stage 3. Just download it and unzip to the system root.
I have installed missing liveusb library, required by precompiled binaries - now i can start ./domoticz, but still no luck. No device appear in device menu. Still need help to debug this case.
arkoko
Yes, it is (beta v3.6367). Domoticz "close the door" on this signal:Mat2Vence wrote:In domoticz, it looks like when the door is open, it is considered as closed in the status 1 minute after it has been open, whatever the case.
{"cmd":"report","model":"magnet","sid":"158d00011854aa","short_id":1082,"data":"{\"no_close\":\"60\"}"}-
deennoo
Be patient solution is here, corbin is working hard on it, just give him time to provid a full release with all devices aviablearkoko wrote:Yes, it is (beta v3.6367). Domoticz "close the door" on this signal:Mat2Vence wrote:In domoticz, it looks like when the door is open, it is considered as closed in the status 1 minute after it has been open, whatever the case.This behavior appeared after last firmware upgrade on the gateway.Code: Select all
- corbin
- corbin
This is already fixed after the last firmware update. Gateway LED control and Aqara switch support will be coming next. I got delayed on the weekend when friends turned up.deennoo wrote: Be patient solution is here, corbin is working hard on it, just give him time to provid a full release with all devices aviable
